Question about Bissell 9500 ProHeat 2X CleanShot Upright Deep Cleaner, Red Berends Vacuum
My bissel has a upolsty cleaner on it, I used it to clean my couch then shut it off to emty then went to clean the other couch now it wont spray cleaner or ****? can anyone help me?
  • 360 Answers
Things to look at...
  • Tank is properly seated (remove and reinstall)
  • Tools are selected (not floors)
  • ensure the handle is in the full upright position
If these don't correct the problem let me know, if this does correct the problem, please take the time to give this solution a fix ya rating.
clarkco
Posted on Mar 07, 2009
Why can't I use the attachments to clean my couch?
You may want to check for a pinched hose. Unwind the hose completely and lay it out and try your sprayer again. If that doesn't work than try reseating the tank (turn the unit off, remove the tank and then replace it, wait 1 minute and turn the unit back on.) AND, if you haven't been cleaning the filters now would be a good time to do that. In the tank there is a lint filter on the lid and there is another filter under the flow indicator (turn flow indicator cap counter-clock wise, remove rotor, remove filter. clean filter and replace everything in reverse manner. Hope that helps. If not Bissell Consumer Care number is 1-800-237-7691.
Nov 30, 2015 | Bissell Carpet Cleaner Powerbrush Deep...
My Bissell Proheat carpet cleaner/hose for cleaning will not spray anything
My ProSeries Carpet Cleaner won't spray. What ... - Bissell
www.bissell.com > Support > Helpful Resources > FAQs
BissellLet's start by figuring out where your carpet cleaner can spray. If you have no spray at all, start below. If you have no spray at the floor but can spray from the hose, scroll down for the ... Turn the unit on after cleaning and see if water sprays to the floor now. IV. .... My ProHeat® Self-Propelled's Powerdrive isn't engaging.
Bissell Carpet Cleaner Won't Spray. Easy Repair - YouTube
? 1:48
https://www.youtube.com/watch?v=nccdrjpGp34
Dec 20, 2013 - Uploaded by Cecil Argue
You may have a bad pump, clogged hoses or a clogged heater. ... Just want to tell you that this was the perfect ...
Nov 30, 2015 | Bissell Vacuums
Water wont spray from cleaner how to fix
Try cleaning the Flow Indicator Filter. Turn the Flow Indicator Cap counter-clockwise to remove, lift rotor and filter. Clean filter and replace in reverse order. Bissell's Consumer Care # 1-800-237-7691
Sep 16, 2015 | Bissell 9500 ProHeat 2X CleanShot Upright...
Bissell proheat2x 8920 wont spray water
Hey Patti, spray is important when you want to clean. Here's a link to toroubleshooting steps to assist you.
http://www.bissell.com/FAQDetail.aspx?id=1122
Jan 26, 2013 | Bissell 9500 ProHeat 2X CleanShot Upright...
Bissell 1623 sprayed used water from tool
Hi Beverley, you may want to have your machine inspected by a Qualified Technician at one of our Authorized Service Centers.
Here's a quick link to locating an Authorized Service Center in your area. http://www.bissell.com/service-centers/?cid=ccsocial
Jan 26, 2013 | Bissell 1623 Steam Cleaner
Can I use the Bissell 2x ultra on micrfiber?
Before using your Bissell on a microfiber couch, make sure to check the tags on the couch. Microfiber couches come in different "flavors." There's S, W, S/W and X. Using the wrong cleaning method can damage your couch. Here's an article that goes into more detail on what each code stands for and how to clean each one. Tips on Purchasing and Cleaning Microfiber Couches
Apr 24, 2012 | Bissell 9500 ProHeat 2X CleanShot Upright...
Wont spray
Here is a tip that will give you all the information you need to fix your BissellProheat Vacuum Problem.
Bissell Proheat Upright Wet/Dry Vacuum Problems
heatman101
bvnvn
Jul 18, 2010 | Bissell 9500 ProHeat 2X CleanShot Upright...
I have a bissel pro heat carpet cleaner that doesn't spray cleaner solution, everything else works, but I don't know whether it's the pump or the heat unit.I'm assuming that the pump unit must be bad since...
If you still have spray through the attachments then its the heating element. If not and your sure the belts are good ( if there intact but are a year or more old they need to be replaced ) then its probably the pump
Jun 27, 2009 | Bissell 1693 PowerSteamer Upright Vacuum
I have a Bissell pro heat carpet cleaner, the water spray wont come out to clean the carpet.
Bissel proheat turbo 2x ipx4.
I don't have the instruction the this machine if you could help me with where to put the water and cleaning solution and how much, also how to use it.
Thankyou,
Please email me at carolynsst@yahoo.co.uk
Mar 01, 2009 | Bissell 9500 ProHeat 2X CleanShot Upright...
My Bissell shampoo machine will not spray either water or soap
heatman101
yuet
Oct 28, 2008 | Bissell 9500 ProHeat 2X CleanShot Upright...
Bissell 9500 ProHeat 2X CleanShot Upright Deep Cleaner, Red Berends Vacuum Logo
106 people viewed this question
Top Bissell Vacuums Experts
Jim Parker
Jim Parker
Are you a Bissell Vacuum Expert? Answer questions, earn points and help others
