Question about Lands Phones
BOTH OF MY UNIDEN HANDHELD PHONES SAY, 'OUT OF RANGE.' WHAT CAN I DO TO SOLVE THIS PROBLEM. THY ARE MODEL #DCX750. BOTH HAVE DIAL TONE AND ELECTRICAL POWER. WILL BE AWAITING YOUR REPLY. THANKS....SEND TO path@floodcity.net
  • path110 Mar 07, 2009
    this is a uniden/answering machine setup with 2 handheld units. There is no 'page' button on base. I get the message'Direct link mode--room monitor-handset' when i hit MENU button on phone. then 'to enter Direct link mode press (select)..If i press (select)...Directlink complete.......goes back to handset #2........but, when dialing it still reads "OUT OF RANGE"> WHAT IS GOING ON?
    Sergeant:
    Novelist:
  • 277 Answers
What does "Out of Range" mean on my  phone?
answers :---- The handsets are reading out of range because they have lost connection with the base. This happens mostly during peak power demands or power outages, but can also happen when the phone is unplugged for any amount of time. This can also cause, at times, the answering machine to stop picking up calls. To remedy this issue, reset the phone system. Please follow the instructions below:To reset the phone:
1. Disconnect the power adapter, phone line, and remove all batteries from the base and all handsets. Leave it disconnected for 30 seconds to reset the base.
2. Place the batteries in the handsets first and then plug in the power adapter and phone line. Do not place the batteries back in the base yet.
3. Put the handset in the charge cradle.
4. It may take up to 1 minute for the "Out of Range" to clear from the display.
5. Once the "Out of Range" is cleared from the handset place the back up batteries back into the base.
NOTE: If the handset is still not working properly please deregister and then register all handsets to the base.
To deregister go to the following link and select the FAQ and follow the deregistration steps for your model phone..
Deregister
Once deregisteration is complete go the following link and select the FAQ and follow the registration steps for you model phone.
Register
please rate the solution if helped.
thanks.
Posted on Mar 07, 2009
  • 6,784 Answers
Ok, remove all batteries if any and unplug the entire unit and let stand for 5 mins. this will preform a hard reset. after five minutes, reinsert the batteries if any and plug the unit back into the socket. this will fix the software scramble.
  • 19,396 Answers
Try re-sync the handset with the base, you need to press the button on the base.
Try also unplugging phone base from power and if battery is removable, also removing handset battery.
If that does not work, then either the handset or the base may be faulty.
  • 583 Answers
Check out the internal battery and get the frequency checked by connecting the external antenna at its top to check out the range.
  • 547 Answers
Return them to there base press page from base with phone next to base this should reset message thank you for useing fixya please rate me
The problem is with my uniden phone model D1364 can't hear the tone when dialing phone
If you can't hear the dial tone, try substituting another phone to detect it. Also, if your Uniden phone is defective it can disable the dial tone when connected to the line.
Mar 08, 2014 | Uniden DECT 6.0 Cordless Phone ID
No dial tone on line 2
CALL THE COMPANY OF THE PHONE OR CALL THE PHONE COMPANY THAT PROVIDES THE SERVCE OF YOUR PHONE
Feb 27, 2014 | Uniden DECT4086 Cordless Phone
My uniden says out of range but its been charging all night why?
Check the phone connection. Try another phone, Is there a dial tone?
Jan 25, 2012 | Uniden Lands Phones
How to get phone back to tone dial instead of pulse dial
Since you declined to specify the model of your Uniden cordless phone, I can only suggest you select it from the list beginning here to download a copy of the manual. The manual will explain how to switch between tone and pulse dialing.
Jan 19, 2011 | Uniden Cordless Phone
Model UNIDEN UCIS-225 - Phone suddenly dials like a rotary phone. Does anyone know how to make it return to the non-rotary dialing?
two places<br /> 1. Manual switch on back of phone Tone or Pulse<br /> 2. Menu-Set Dial Mode - DTMF (tone) or Pulse
Aug 05, 2010 | Uniden Lands Phones
I have a uniden dcx750-r cordless phone i need a user uide
GO TO UNIDEN.COM CLICK ON OWNERS MANUALS, THE SCROLL DOWN UNTIL YOU SEE DCX750 MANUAL.
Sep 02, 2009 | Uniden DCX750 Cordless Expansion Handset
Phone showing "unavailable" and there is no dial tone. I have tr
Unavailable and no dial tone usually means that there is a bad wire between the base and the wall or the wall jack is bad.
Jun 27, 2009 | Uniden Cordless Phone
Dial Tone but won't call out.
I just had the same problem. Try unplugging the plug from the electrical outlet for the home(base) unit and plugging back in. Fixed my problem right away.
Jul 26, 2008 | Uniden Cordless Phone
Cordless phone
press menu then globel setup and then press dial mode then change the the dial tone you want
Oct 19, 2007 | Uniden DECT 6.0 Cordless Telephone...
Lands Phones Logo
154 people viewed this question
Top Lands Phones Experts
Are you a Lands Phone Expert? Answer questions, earn points and help others
