Question about Craftsman 17.5 hp 42 in. Deck Lawn Tractor - CA Model
Engine dies when clutch is released or PTO is engaged
Craftsmen 20.5 HP 42 in deck tractor
Ed in oregon had this solution:
"Flop the seat forward, locate the seat switch in the middle of the seat, push the connector onto the seat switch firmly, start it up and drive away"
I had worked this problem in the intermittent mode.
I tried "ed in oregon"'s solution and it work straight away.
Thanks Ed.
Posted on Sep 21, 2012
    Scholar:
  • 138 Answers
Posted on Aug 17, 2009
Mowers shuts off when I engage the pto switch, I jumped all of the safety switches,put new pto switch on, belt and pulleys are fine! Please help
Craftsman Garden Tractor 917.28746 Engine shuts off when ...
www.shopyourway.com > Manage My Life > Questions
Craftsman Garden Tractor 917.28746 Engine shuts off when engaging mower deck. 917.28746 ... Then start the tractor and pull the pto button out. If the engine ...
Why does my engine die when the blade is engaged ... - iFixit
https://www.ifixit.com/.../Why+does+my+engine+die+when+the+bl...
iFixitI have an older Murray riding lawn mower, whenever I engage the mower the engine dies, otherwise it runs .... My dr feild brush mower ... cuts off when I engage theblades. ... My Huskee only shut off once I put it in drive with the blade engage.
Riding Lawn Mower Problem - Dies when PTO engaged - GardenWeb
forums2.gardenweb.com > Garden Forums > Tractors
Apr 28, 2008 - When I pull the switch to engage the PTO, the engine bogs down real ...off I can keep the engine running with the mower engaged then it is fine ... Riding mower cuts out
May 18, 2010
mower dies when I let off the clutch
Sep 19, 2008
pto on Cub Cadet will not stay engaged...
Apr 6, 2008
Craftsman Mower deck (clutch) Won't engage
Jul 1, 2006
More results from forums2.gardenweb.com
Dec 29, 2015 | Garden
Craftman lawn tractor 20.0 HP 42" electric start blades will not engage
Check for voltage at the electric pto clutch connector if 12 +volts is there when the switch is on then the clutch is bad; otherwise, you need back through the wiring to find the problem.
Aug 08, 2014 | Craftsman 20 hp 42 in. Deck Lawn Tractor -...
Why does engine die when brake released or mower engaged?
The first thing I would check is to make sure the drive belt is not binding somewhere.
May 17, 2014 | Craftsman 20 hp 42 in. Deck Lawn Tractor -...
When the PTO switch is engaged the motor shuts down the same thing happens when the clutch is let out . I have replaced all the safety switches once before and that solved the problem. I replaced the PTO...
Be sure to check the back end of the seat switch wiring for loose or shorted wires. If the engine is shutting off when the brake pedal is released or the pto is engaged most likely the seat switch has failed. The seat switch connector has a shunt built into it. If the connector is not firmly plugged on the seat switch, it grounds out and when the clutch is released or the deck is engaged, the engine will die. Look closely at the connector and you will see a plunger that is pushed in when it is plugged on the seat switch. If the connector is on the seat switch securely, either the seat switch or the connector might be shorted internally. You need a meter to test this. The seat switch should read open when pushed. I hope this is helpful.
Aug 26, 2011 | Craftsman 20 hp 42 in. Deck Lawn Tractor -...
42" 15 hp craftsmen mower dies when let clutch peddle out
have you tried fitting a bypass wire to seat switch and retest then try disconnecting it completely and retest
if that does not work check that the blade engage switch is not stuck down.
check that catcher switch is not open if this nodel uses a catcher ?
have a look ?
cheers
Sep 01, 2010 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
My craftsman lawnmower dies when i let out on the clutch
make sure your not in reverse with the blades on. if so turn the key left to mow in reverse mode. else check pullies.
Jul 06, 2010 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
STARTS GOOD BUT ENGINE DIES WHEN CLUTCH RELEASED
cut the wires running to the switch...try again...if same, stripp back wires, and twist together...wrap in tape or use some sort of connector...it's electric and should be treated as such...try again...still ?? Start finding those switches and repeat the process til it works...theres usually 3 or 4...
Apr 18, 2010 | Craftsman 21 hp 42 in. Deck Yard Tractor -...
Blades don't engage
Check the drive belt for the blades
Jul 22, 2009 | Craftsman 42 in. Deck 19.5hp Lawn Tractor
Need to replace a clutch cable
i need a picture or explanation, how does the clutch spring attach
Apr 27, 2009 | Craftsman 20 hp 42 in. Deck Lawn Tractor -...
Mower dies when i try to engage blade
Hi, what you wrote is exactly what's is suppose to do. what is it about the mower that's not doing?
Nov 22, 2008 | Craftsman 20 Hp 42" Deck Lawn Tractor
Craftsman 17.5 hp 42 in. Deck Lawn Tractor - CA Model Logo
364 people viewed this question
Top Craftsman Garden Experts
Wade Mobley
Wade Mobley
Dean Gruber
Roland W VanLue
Roland W VanLue
Are you a Craftsman Garden Expert? Answer questions, earn points and help others
