Question about HP LaserJet 1022 Printer
My shared printer will only print a test page and nothing else!
I just set up a new Dell computer (WinXP) and had to re-share a HP Laserjet 1022n printer. Now when I try to print to the shared printer from another computer it will not print my document. I can only get it to print a test page so I know it's communicating with the printer. I have tried to print from Word, email, nothing else prints. No error messages just nothing comes out of the printer and the job is not sitting in the print que. I have deleted the printer and have reconnected to it through our network and I am sure that print sharing is on and the printer is shared. I have this one printer shared out to two other computers and it's happening on both so I am overlooking something. Help! all remote systems print on the network printer, but the local machine just sends out blank pages, tried on word and other programs
3 Suggested Answers
  • 477 Answers
SOURCE: Printer Not Woking In Network
1. check that not any firewall or antivirus software blocking your printer.
2. try to look in paper settings what format you sending to the printer. is it letter format or A4 or what ? it should be A4.
have you tried to connect the printer with USB? or have you connected the printer with a network cable.?
Posted on Jul 03, 2009
  • 461 Answers
SOURCE: My shared printer will only print a test page and nothing else!
When you say 're-share' do you mean you had it configured previously on another machine? Also have you re-installed the printer on the network machines or changed the port ie: //PCName/PrinterName as this could be different now with the new setup. Also check that the users have been granted access to the machine connected to the printer.
Posted on Dec 15, 2008
I cant print shared printer but can test print
If you're trying to connect to another computer, make sure that computer is on, that you have enabled file and printer sharing on both computers, and that file and printer sharing can communicate through your firewall.
For more Help Read... Troubleshoot file and printer sharing and HP Printer Installation
Thanks
Jun 27, 2014 | HP LaserJet 1022 Printer
Hp laserJet 1022n printing multiple copies when copies are set to 1
Had this same problem found a working solution here http://www.tomshardware.com/forum/59912-3-1022n-printer-stop-printing.
Just disable bidirectional support in the printer properties worked for me
Jan 06, 2012 | HP LaserJet 1022n Printer
My Hp Photosmart C5820 all in one printer is connected to my HP Pavilion dv6000 laptop (Windows XP). How do I share this printer wirelessly with my new Dell laptop (Windows 7)?
Any printer that isconnected to a computer and is connected on a LAN can be configured so allother computers on the same network can print to this printer. This means thecomputer with the printer attached to it MUST be booted up at all times whenother computers want to access the printer. You need to install theprinter driver on the computer and configure it as a Shared printer. The other computers on thenetwork need to add this printer to their computer. Follow these steps toset-up a shared network printer :- 1. Connect the printer tothe computer and install the printer driver. 2. Open Printers and Faxes- right click on this printer and click Sharing - click Sharing tab and click Share this printer, and then if you wish you could change theShare name, then click OK 3. Right click on theprinter - click Properties - click Print Test Page to confirm printerinstallation.
Follow these steps toconfigure the computers on your network :- 1. Open Printers and Faxes- click Add a printer - Next - select a network printer, or a printer attached to another computer - Next. 2. Select Browser for aprinter - Next 3. Click on and expand theMicrosoft Windows Network down to the computer with the printer - Next 4. Select Yes for - Usethis printer as the default printer - Next - Finish 5. Right click on theprinter - click Properties - click Print Test Page to confirm printerinstallation. b>
Mar 04, 2011 | HP Computers & Internet
Hi, I rested my HP 1022n Printer, now with old IP address its not printing, how can get my printer new IP address ? and please tell me how can take Test report of same printer, i tried pressing Green(go)...
Every network printer or print server has a unique IP address associated with it. This address is either configured manually or set using an automatic network protocol such as the boot protocol, reverse address resolution protocol or zeroconf. You can normally find the IP address of a printer on the printer's control panel or by printing the configuration page. Select the printers and faxes tab from the control panel. Right click on the printer those you want to find the IP address and click properties. Then click on the ports tab to display the IP address of your printer.
Nov 25, 2010 | HP LaserJet 1022n Printer
How to add NIC in HP color laserjet CP1215 Printer?
If this model HP does not have an expansion slot for a HP Jetdirect Print server, then to use this printer on your network you have two options.
1. Connect the printer to a desktop computer on your network and set it uo as a shared printer. This means this computer and printer needs to be powered up for the other computer on your network to print to the shared printer.
2. Connect the printer to a print server that is connected to your network.
Nov 24, 2010 | HP LaserJet P2015 Printer
Jul 03, 2009 | HP LaserJet 1022 Printer
Hi phall124
Have you made the new connected printer on 2 other PC's the default printer. Try selecting the printer in word by not just clicking on printer icon but using the following:
1.File
2.Print
3.Select printer from drop down box
4.Print
Regards
Go-Tech
Dec 15, 2008 | HP PSC 1315 All-In-One InkJet Printer
Laserjet 4250dtn Duplex problem
How is the printer connected.
Please upgrade the firmware of the printer.
Please upgrade the firmware of the printer:
1. Download the firmware file from the following website and extract it.
http://h20000.www2.hp.com/bizsupport/TechSupport/SoftwareDescription.jsp?lang=en&cc=us&prodTypeId=18972&prodSeriesId=412144&prodNameId=412158&swEnvOID=54&swLang=8&mode=2&taskId=135&swItem=lj-25065-13
Expecting that the printer is connected over the network:
Remote firmware update by using FTP through a browser
Complete the following steps to update the product firmware by using file transfer protocol (FTP) through a browser.
NOTE: The following instructions can be used on Windows or Macintosh operating systems.
Take note of the TCP/IP address on the EIO-Jetdirect page. The EIO-Jetdirect page is the second page of the configuration page printout.
Open a browser window.
In the address line of the browser, type ftp://<IPADDRESS>, where <IPADDRESS> is the TCP/IP address of the product. For example, if the TCP/IP address is 192.168.0.90, type FTP://192.168.0.90.
Locate the downloaded .RFU file for the product.
Drag and drop the .RFU file onto the PORT1 icon in the browser window.
NOTE: The product automatically restarts the firmware to activate the update. At the end of the update process, the Ready message appears on the control panel.
The following describes how to upgrade firmware in the LaserJet 2400, P3005 and 5200 Series Printers using a USB connection only.
To send the firmware upgrade via USB, you will need to know the name of the computer the printer is connected to, and the printer will need to be shared.
To find out the name of your computer:
Click the Start button, Programs, Accessories, System Tools, then choose System Information.
You will find your computer’s name in the right window-pane next to System Name.
Write down this name as it will be needed later.
To share the connected printer:
Click the Start button, Settings , then choose Printers ("Printers and Faxes" on WinXP).
Right click on the printer you need to send the upgrade to and then choose Sharing.
On WinXP, if you encounter the following link "If you understand the security risks but want to share printers without running the wizard, click here.", click the link.
Select "Just enable printer sharing" and click OK .
Select Shared As: ("Share this printer" on WinXP) and type a name for the share.
Click Apply and write down the share name as it will be needed later.
To send the firmware upgrade using a USB connection:
Go to a DOS Command Prompt and locate the directory where you saved the firmware file. (To open a Command Prompt inWindows 2000 or XP, go to the Start button, then choose run, then type CMD and hit Enter, in Windows 98 or ME, go to the Start button, Programs, Accessories, then choose MSDOS Prompt). This will bring up a small black screen as displayed below:
If connected to a USB port, Type: copy /b filename \computer nameshare name (for example, copy /b ozfw.rfu \computer1printer).
Press ENTER .
The control panel displays receiving upgrade followed by performing upgrade . The download may take several minutes.
The control panel displays processing job .
The download is complete when the printer reboots and "READY" message is displayed on the control panel.
Oct 20, 2008 | HP LaserJet 4250n Printer
Duplex printing hp laserjet 4250n
Press ENTER .
Jul 23, 2008 | HP LaserJet 4250n Printer
HP 3100 LaserJet All-in-one Print Driver for Vista OS
It doesn't work in share mode either...It prints the pages incorrectly. I have the hp3100 connected to my xp pc and my vista laptop connects to it via printer sharing on my network. the xp prints fine but the vista doesn't print ok due to lack of driver support for it.
I have to resort to print to pdf and then take the pdf to my xp for printing. Its a half *** solution but if anybody out there made his/her own driver please post.
Jan 25, 2008 | HP LaserJet 3100 All-In-One Printer
HP LaserJet 1022 Printer Logo
1,362 people viewed this question
Ben Johnson
