Question about Lexmark X8350 All-In-One InkJet Printer
Can't get the all in one center for X8350
Everything else works but when I try to scan to my computer I could not find the all in one center it has lexmark solution center, read me and uninstall . When I pushed scan it would not open anything on the computer. I just bought a new computer it is vista but the printer I have had for about a year. I have re installed the software but it still will not install the all in one center? Thank you for any help I can get.
  • Anonymous Mar 14, 2009
    i have the same problem.
  • kdennett527 Apr 02, 2009
    Please follow the steps given below to perform the WIA scanning:
    1. Click on "Start," and "Windows photo gallery."
    2. Under "Windows photo gallery" click on "File" and " Import from camera and scanner."
    3. Select the "Lexmark X8350 printer" and click on the import button.
    4. To begin the scanning process, click "Scan Now.
    I found this when I was looking around and it really worked for me and I can scan. I hope it works for anyone else that sees this. It is really easy.
SOURCE: Lexmark X1150 Will not scan or copy
Lexmark all in one solution software you used in XP doen't work with Vista.
But you can still scan and copy by using Windows Photo Gallery.
1. Click on files tab at the top in Window Photo Gallery.
2. Click on import from camera or scanner.
3. Highlight your scanner icon (ie lexmark 2300) then click import.
4. New scan window will popup, now you can preview or scan using this basic looking Vista utility.
Hope that helps.
I miss my lexmark all in one solution scanning software too.
Posted on Feb 26, 2008
  • 62 Answers
SOURCE: Lexmark X1185 won't scan.
I believe you have to push the scan button in order for it to scan and save. The copy buttons will only print either a black copy or a color copy.
Posted on Sep 15, 2007
rizla
  • 1463 Answers
SOURCE: lexmark x1200 all in one
try here Drivers and Downloads search your printer .
riz.
Posted on May 29, 2008
jmeredith
  • 417 Answers
SOURCE: lexmark 8350 won't communicate with computer
hi.
maybe the usb cable went completely, you can try to replace it with another, also Ive heard lexmark power supplies can go bad without notice, can you copy standalone with it? you should. if not then check power output with a multimeter. Is your new dell running on vista? you may have to download a driver specific for vista and lexmark from lexmark website NOT the XP driver the VISTA driver, I had to do that with mine. just a couple ideas. good luck
good luck
J
Posted on Aug 01, 2008
  • 684 Answers
SOURCE: scanner won't scan
Right Click on My Computer/Computer if Vista........ Click on Properties then click on Hardware click on Device Manager...... On that list u will see the Printer Name with an exclamation Mark........ Right Click on that click on update Drivers...... Insert the CD to the drive....... Select Browse My Computer for Driver software..... Click on Browse and then Double Click on Computer go to Lexmark X*****.......... Double click on Drivers and then click on scan and then click ok........ Now click next it will say the hardware is ready to use then u can just click on finish and scan..... Thanku
Posted on Jan 25, 2009
I have just bought a Lexmark X835 off a friend and it did not come with an installation disc (for Mac) and is missing the cable which connects to my computer. Could you please let me know where i can get...
Please visit the Lexmark website to download and install the Lexmark X8350 Driver on your computer. Select your operating system, download and execute the file. Follow the instructions on your computer screen.
The Lexmark X8350 printer does not come with a USB cable (to connect the device to your computer). You'll have to provide your own cable. You may contact Lexmark Technical Support Center for assistance.
Sep 11, 2011 | Lexmark X8350 Print, Scan, Copy and Fax...
When I scan a file to pdf and save it.....I can't get it to upload
Make sure the Lexmark OCR scan software is installed on your computer. The scan software can be downloaded using only the installation disc that came with your Lexmark printer. Just insert the disc into your computer hard drive and execute the file. If you lost the disc, please contact Lexmark Technical Support Center for assistance.
Jul 25, 2011 | Lexmark X8350 InkJet Printer
Can't get the scanner to work
Check if it's a hardware, software or a USB connection problem.
If you are able to make a copy using the Copy button on the printer operator panel, then hardware is good.
Try to disconnect and reconnect the printer into your computer.
Then send a print job. If print job is sent successfully, then USB connection is good.
Try to update your printer driver by reinstalling the printer software. If you are scanning a document for editing, make sure the Lexmark OCR scan software is installed on your computer. The scan software is avialable only on the installation disc that came with your printer.
If problem continues, please contact Lexmark Technical Support Center to further troubleshoot this problem.
Jul 06, 2011 | Lexmark X8350 InkJet Printer
Will print from computer but will not copy or scan
It could be a scanner hardware problem? Try to unplug and re-plug your printer into the power source to reset it. If problem continues, please contact Lexmark Technical Support Center for additional assistance.
Jun 28, 2011 | Lexmark X8350 All-In-One InkJet Printer
I have lost the CD to my Lexmark X8350 and need to install on a new laptop. I have trired the links to lexmark Driver Downloads but the printer still is not working
Try to uninstall any existing Lexmark X8350 printer software from your computer. Refer to this article on How to Uninstall Lexmark Printers. Reboot your laptop when prompted. To reinstall, use the updated driver available at http://bit.ly/eO4Y77. Select your operating system to download the driver. NOTE: Use the Vista driver in Windows 7.
Jan 17, 2011 | Lexmark X8350 Print, Scan, Copy and Fax...
Can I download the Lexmark X8350 without the cd to my new computer
you can install your printer to your computer by downloading the drivers from the Lexmark website
Dec 29, 2009 | Lexmark X8350 Print, Scan, Copy and Fax...
Lexmark X8350 "communication not available"
I fixed this by completely uninstalling the Lexmark software, then unplugging the USB and restarting. I then installed the new Lexmark software that I downloaded from their site, make sure not to plug the USB back in until it told me to. It then detected the printer properly and started working.
Jun 02, 2009 | Lexmark X8350 All-In-One InkJet Printer
Scanning as PDF
I see from Lexmark's site that your printer can scan to PDF Using the Productivity Suite buttons. The manual is here
But if that doesn't work for you...
I use PDF Creator.
It is a windows program that installs a printer driver that allows you to select it as a printer from any program and will create a PDF file.
For example, you can scan as an image, then open that image in an image viewer then print it to PDF.
Dec 08, 2008 | Lexmark X8350 All-In-One InkJet Printer
Scanner
Try scanning from the image software you are using, not from the front panel buttons. Go to the TWAIN options and make sure your scanner is selected, then go to Acquire and the scanner software will start. Scan from there without using the scanner front panel.
May 05, 2008 | Lexmark X8350 All-In-One InkJet Printer
Scanner won't scan
Apr 15, 2008 | Lexmark X8350 All-In-One InkJet Printer
Lexmark X8350 All-In-One InkJet Printer Logo
548 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
Don  Farrell
Don Farrell
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
