Question about Hotpoint RVM1425 Microwave Oven
My hotpoint rvm1425 is not heating anything up
  • DRBISHOP May 11, 2009
  • Hotpoint Master
  • 19,396 Answers
Est the high voltage capacitor,the rectifier diode.or the magnetron. If all this are fine, test the control board.
Thediode and capacitors can br tested. The capacitor must bealloweddischarge before testing, or you risk to get electrocuted, evenifpower is off. Capacitors can get discharged by shorting theirtwocontacts.
Before replacing the magnetron test also the control board.
Replace the magnetron if the checks and all of the high voltage component tests are good, but the unit still does not heat.
All locations, and description of this parts can be located using the diagram here: Counter top.
Parts must be tested to find out what is wrong.
Remember that microwaves are potentially dangerous devices if not repaired properly, the job must be done by a competent person.
A microwave energy leakage test must always be performed when the oven is serviced for any reason.
Regarding parts, contact the seller here to purchase parts.
Posted on Apr 27, 2009
Our microwave is not heating. When you turn it on it appears to be working, the dish rotates, the light is on, you can hear it running, it's just not heating the food. Is this repairable?
It sounds like the magnetron may have either failed or is not being supplied with the extremely high voltage required to run it.
Make sure the !!!!capacitor is discharged!!!!! before attempting any sort of repair.
Check the door interlock switches first then the high voltage diode with either an AVO model 8 on high resistance range for short circuit, the feed fuse on the primary of the high voltage transformer and then finally, the magnetron is best checked by substitution.
Hope that helps.
Dec 22, 2010 | Hotpoint RVM1425 Microwave Oven
Microwave oven will not heat? Could it be a fuse. The fan makes a louder noise than before it stopped heating. One side blows hot air the other side blows cold. Not sure what to do
Here is a tip that will help you to figure out what is wrong with your Microwave Oven....
Microwave Oven Troubleshooting Tips
Dec 15, 2010 | Hotpoint RVM1425 Microwave Oven
Wont heat, burning rubber smell, hotpoint microwave
If there is spark please do not switch on unless you have confirmed the fault. It is possible that the Magnetron is leaking and sparking to the ground. It is quite possible that insect can get into the oven and create soft spots. When you switch on these will create a short and make the voltage jump and in the long run damage the magnetron.
So Remove cover after disconnecting , check for dirt/moisture in the cabin, if so wipe clean and dry, check the magnetron and area clean and use an jet air to clean off.
Now keeping clear switch on , use a cup of water inside to test.
If you notice any buring smell shut off as the magnetron or the main HT capacitor can be faulty. replace with same type.
If there is no heating the magnetron/capacitor/temperature cut off is faulty
Sep 24, 2010 | Hotpoint RVM1425 Microwave Oven
Microwave has power, but will not heat
Here is a tip that will help you to figure out what is wrong with yourMicrowave Oven....
Microwave Oven Basic Troubleshooting Tips
Apr 25, 2010 | Hotpoint RVM1425 Microwave Oven
check the door safety switches ... remove the cabinet and check the micro switchs you find involving the door with a volt/ohm meter
Nov 03, 2009 | Hotpoint RVM1425 Microwave Oven
Will not heat
Oct 22, 2009 | Hotpoint RVM1425 Microwave Oven
Hotpoint RVM1425 Microwave Oven IT BEEPS, SHOWS F3 OR F4
F3 on a GE / Hotpoint microwave means you have a shorting membrane keypad.
If and when an oven is coming on or doing anything by itself, this is very dangerous and can result in a fire.
So until it is repaired, please leave it unplugged or leave the door open when it's not in use, and please do not leave it running unattended.
If you (or someone you know) might want to replace it yourself, I have uploaded a handy guide with pictures showing you what's typically involved.
You can find helpful exploded view diagrams and order parts by entering your full model number here.
There should also be a "mini-manual" hidden inside the unit behind the control panel or hidden on the left side behind the grille, which is very helpful when troubleshooting & testing.
At our Web site, we have a video available showing how to remove a typical over the range control panel assembly in under 5 minutes.
If you would like to have us do this repair for you, we do that for $39.95 plus part costs.
Feel free to contact me directly (and please remind me of your full model number from the tag on the unit) for more information & help.
William E. Miller, AS-EET
Mar 05, 2009 | Hotpoint RVM1425 Microwave Oven
Will not heat product
You can but for the safety aspect I would get a qualified engineer.
If it's too expensive buy a new one, don't take the risk to save a few £/$.
Mar 21, 2008 | Hotpoint RVM1425 Microwave Oven
Hotpoint RVM1425
The first thing I would suggest is to turn off the breaker or unplug it from the wall for a few minutes to "reset" it, then try again. If a reset doesn't fix it, I would think you may have a defective magnetron. When you heat something of very low moisture content, it can lead to microwave energy not being fully absorbed, but instead being reflected back to the magnetron. This can damage it. This is usually best left to a pro to repair. In case it might help, your owner's manual can be found online at:
Nov 21, 2006 | Hotpoint RVM1425 Microwave Oven
Open Questions:
See all Hotpoint RVM1425 Microwave Oven Questions
Hotpoint RVM1425 Microwave Oven Logo
222 people viewed this question
Top Hotpoint Microwave Ovens Experts
William Miller
William Miller
Jim Thurston
Are you a Hotpoint Microwave Oven Expert? Answer questions, earn points and help others
