Question about Maytag Dryers
Maytag stackable dryer, start button just makes a humming sound but dryer will not start john s
    President:
  • Maytag Master
  • 2,651 Answers
Either you have abad motor assy, or somethinghas gotten dowenin the blower wheel preventingfree spin of the blower threfore holding back the motor from starting
Posted on Mar 07, 2009
Maytag lse7804ade
Buy the right size fuse. Too big of a fuse can cause a fire.
Aug 23, 2014 | Maytag Washing Machines
I have a maytag dryer that sometimes when I hit the start button will start and run for only a few minutes and stop and wont start again for a while and does a humming noise when it does star why?
Sounds like the motor is going into thermal overload (Getting hot) it may be caused by the motor itself, or could be overloaded by bearings or fan etc
Jul 28, 2014 | Maytag Dryers
When pushing the start button dryer hums but does not spin. when u release start button dryer shuts off
Sounds like a bad motor. Check to make sure the drum isn't stuck, if you can spin the drum put some tape on the door switch and press the start button while you spin the drum. If the drum continues to rotate, you have a bad motor.
Mar 10, 2011 | Maytag Washing Machines
Maytag stackable dryer will not run. When the start button was pressed, there was a sound of the motor trying to turn, but there was not turning. When pressed repeatedly, there is a burnt smell
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
There can be many reasons why your dryer will not start or turn...
The most common causes are the belt breaking or jumping off, or the motor going bad...
Here are a couple of tips that I wrote will help you to figure out why your dryer will not run...
Dryer Repair - The Dryer is not Turning
Dryer Repair - The dryer will not start
heatman101
Aug 23, 2010 | Maytag Dryers
Maytag MDE3000ayw. When I press the start button, there is a humming sound, but it won't start. Is this likely a problem with the start button, or the motor? The belt is fine.
It's not the start button if it responds to the button. Make sure the motor spins freely. If so, make sure you have voltage going to the motor. If so, check the start capacitor (if equipped) Good luck.
Mar 10, 2010 | Maytag Neptune MDE5500AY Electric Dryer
When I push the start button the drum seems to be stuck but I can pull on the belt and it goes around.
It could be that you have a drive motor problem, Ive seen this before. Sometimes the dryer will make a buzzing or humming sound when you push the start button.
Feb 14, 2010 | Maytag Dryers
Maytage MDE3080DAYW
Hi, it sounds like you have a bad motor. You can try and open the door, hold the door button while having someone push the start button. Try turning the drum with your hand while these buttons are pushed and see if the dryer starts. It sounds like the start winding has gone bad.
If the drum will not turn, remove the front panel of the dryer and see if something has gotten into the blower wheel to stop it.
I hope this helps you. Please let me knwo if I can assist you further.
Vic
Jun 13, 2009 | Maytag MDE308DAYW Electric Dryer
Maytag electric dryer when i set dial to desired setting i here a humming sound prior to pushing start button it has never done this before also the clothes is VERY hot when i take it out model ...
it sounds like a shorted heater element, this would also cause the heat to stay on at 110 volts which would make the clothes very hot since the element doesn't completely shut down. if it is a loud hum it could be a stuck motor switch but in this case the dryer usually won't start.
Jun 08, 2008 | Maytag Dryers
Maytag Neptune Dryer humming but not running
This sounds like the motor is siezed or burned out. I wish I knew how much a motor is, but the Neptune is a good dryer so it would probably be worth it to get a new motor if indeed that's the problem.
Jan 21, 2007 | Maytag Neptune MDE5500AY Electric Dryer
Dryers Logo
66 people viewed this question
Top Maytag Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a Maytag Dryer Expert? Answer questions, earn points and help others
