Frig was dead. checked main board,fuse blown. Replaced main board and got lights but nothing else.
SOURCE: LG Frig LFC23760ST 3 Door French Refrigerator : No power!
Little late, but the same thing happened to me. With a continuity tester you should be able to check to see if the fuse is good/bad, but make sure there is no power going to the board. Mine went bad but since the fuses are integral to the board, the entire board was bad. $20 later after a visit to RadioShak, I was able to remove the fuse, and install a fuse holder in its place. Never soldered on a printed circuit board before, but thought it worth a shot since the board is $200! I say try and trouble shoot it yourself. It worked out well for me.
SOURCE: I had a brand new
Usually when the first unit went back with a blown control board the tech should have adviced on the possible causes of a blown control board.
The main cause is usually a surge in the power supply which is received by the unit. What you should do is get a repairman to take a look at it again and if the control board is also blown request a replacement and get a voltage regulator for the unit. The voltage regulator should control power surges into the unit thereby ensuring that the power surge into the unit is minimized.
Hope this solution has been helpful?
