Question about Gateway GT4022 PC Desktop
Randomly lost display on my pc.. and its not a faulty card.
So this gateway that i picked up had onboard graphics. Its running xp home with an amd cpu. I had a nice geforce graphics card that was pci express, and i decided to put it in. I loaded the card, and booted the system. Things went good until the first restart, at which point the monitor didnt come on. I switced the vga cable back and on it came. so after booting into windows, i restarted, and the monitor did it again, this time wanting the new pci express card. So I switched it back, and booted into windows. Now, to try to prevent this on each restard, I went into device manager and disabled the onboard graphics from the windows side. After restarting, it now favored the pci express card.
2 weeks goes by, and all is well until 2 nights ago. I shut down the pc, and when I wake up and go to turn it on, i get no display from the monitor. So, I climb underneith the desk and switch the vga cable back to the onboard graphics, and the monitor comes on. Only this time, after the windows loading screen, it just goes black (im assuming because i disabled the onboard vga in windows). No matter what I do, it wont boot to the pci express card, and everytime i boot to the onboard, they work until windows starts, then the screen goes black. I tryed to boot into safe mode a few times, and when loading the safe mode files, the pc freezes on mup.sys EVERYTIME. Oh, and I also put in a diff pci express card with zero luck. Still wont boot to pci express, and seems to favor the onboard everytime.
Any suggestions?
  • jake_michaud Mar 07, 2009
    I tryed that, been all through the bios, with no way to turn off the onboard graphics. It will allow me to disable the pci-e, but thats about it. I feel like im stuck between a rock and a hard place here!
  • 33 Answers
Try to set your PCI-E card as a first one in BIOS. There also should be an option to turn off onboard video.
Posted on Mar 07, 2009
I have a tower that's gateway and I have an aftermarket video card installed (Nvidia Geforce GT220) and i want to run dual mopnitors....one of the internal video and the other off the GeForce. both cards...
I don't think It's possible. Normally the Graphics card over rides the onboard Video. You would have to get another Graphics card with duel video ports.
Jan 19, 2015 | Gateway Computers & Internet
Adding a Video card
No, When you plug in the Discrete graphics card it causes a bypass of the onboard video chip. The only system that will use the onboard video is the new APU units, and these only give a boost to the graphics card.
Sep 20, 2013 | Acer eMachines Black EL1352G-41w Desktop...
Dualgraphics
Hello here is the homepage:
http://www.asus.com/Motherboards/AMD_Socket_FM1/F1A75M_LE/#specifications
To enable crossfire, you must have 2 identical graphic cards.
The onboard graphic can`t be used with the hd6670.
This means that you must buy another hd6670 to add on the mainboard.
The graphic cards homepage:
http://www.asus.com/Graphics_Cards/AMD_Series/EAH6670DI1GD3/
AMD CrossFire technology is the ultimate multi-GPU performance gaming platform. Unlocking game-dominating power, AMD CrossFire harnesses the power of two or more discrete graphics cards working in parallel to dramatically improve gaming performance.
You also need a large power supply min. 500 watt to have enough power.
Please disable the onboard graphic in the device manager.
Good luck
Jan 06, 2013 | Computers & Internet
Video Failure
When you took the battery out you reset the Bios... You need to go back into the Bios and select Load system defaults from the main menu and reboot.
Go into Bios again and select the PCI-X or PCI depending on what new graphics card you have, or select Auto if its an option from the selections.
Also, I know it sounds stupid, but don't forget to plug the video cord into the proper spot. You'd be surprised how many people accidentally forget to plug it into the new card instead of the onboard graphics.
May 14, 2012 | Gateway GM5045E PC Desktop
I have a gateway desktop gt5468 and i lost the onboard ethernet port and onboard display. also it has 2gig of ram but it only sees 1 gig.i would like to upgrade the ram but this is not upgradeble.what...
if the graphics or Ethernet is not working you can use an ad don card to make them work insert the graphics card in the prescribed slot and watch out which all slots you have graphics card are available in pciexp and agp for Ethernet card the slot is pci fix them and install the drivers as for the 2 GB showing GB it means the memory is sharing with the graphics card
Jun 28, 2011 | Gateway GT5468 Desktop PC
Hi I have problem with graphic card connected to PCI-E slot on my asus p5vd2-vm se motherboard. Graphic - radeon 2600 512 mb ddr3 Power supply -360W One HDD samsung 250gb After I power on PC i get...
HI
If you take out the graphics card and use the onboard graphics card does the pc power up then?
Also have you tried another graphics card on that pc? if it still does not work then it could be the pci-express port that is faulty.
Mar 07, 2011 | ASUS P5VD2-MX SE Motherboard
How do i disable the onboard graphics card on the GM5084?
You can go to the devices menu and at the top of the menu screen are two computer icons one is to activate and the other is to shut down or disable it. You can also right click and disable it. Devices is located XP on the desktop right click and go to properties. Select device programs or you can find it on 7 in the control panel.
Jan 30, 2011 | Gateway GM5084 PC Desktop
Turns on fan runs but no info to the monitor doesnt seem to boot
If the Monitor is displaying no infomation at all, your display signal from the PC to the monitor has failed.
1: Check the cable between the monitor and PC
2: If you are using onboard graphics then that display port is faulty.
3: If you are using a graphics card then remove it and try the onboard graphics.
4: Your monitor maybe faulty aswell so test it on another computer to be safe.
Its more likely to be option 2
Jan 15, 2010 | Gateway GT5220 PC Desktop
Unexpectedly lost graphics, but theres a story to the issue.
You mentioned that you disabled the on-board graphics card using the device mamager.
You should disable the on-board video card in the BIOS.
Go to the BIOS config and disable the Video.
Mar 07, 2009 | MSI RC410M-L Motherboard
Looking to replace processor
Athlon? 64 3000+ ~ 4000+ Athlon FX FX 55 ~ FX59 Athlon 64 X2 4200+ ~ 4800+ The above processors are supported on your board, i think you may have bought the bottom one, although check the model number as the HT means hypertheading, which is AMD version of the Intel Core Duo, which means the processor can manage two or more processor stressing programmes at once, but you should always purchase a suitable heatsink and fan to cool the processor. As regards the onboard graphics, there will be a setting in the bios (to get to it,F2 or Del on boot up) which will be in the advanced cmos settings menu or similair and look for words to the effect 'primary graphics controller' and set this at either pci or agp depending on your model graphics card. Save settings and exit the bios for a re boot.
Apr 26, 2007 | Gateway GT4010 (RBGT4010) PC Desktop
Gateway GT4022 PC Desktop Logo
335 people viewed this question
Top Gateway Computers & Internet Experts
Prashant M
Prashant M
Alun Cox
Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
