Question about OfficeMax 0M96431 Shredder
The shredder jammed (too much paper) then stopped and won't shred. It makes a noise, but when I insert paper, it won't shred. Is there a reset button? I picked paper out of the blades with a pair of tweezers. Thanks!
  • seafoamcotta Mar 08, 2009
    Model No.OMO 1287   Office Max
    Is that enough to go on?
    I got it for Christmas from  my husband and it has not been used very much.  Thank you!
  • anthonyzig May 11, 2010
    Please provide the manufacturer, model number and serial number and we'll go from there!
  • 35 Answers
Chances are, the overfeed caused the teeth of the gear that operates off of the motor to break.
This is very common in less expensive machines. I don't know if OM will let you return it because I don't know there policy. Most of the time retailers will attribute broken gears to abuse, which in turn is not warranted. These machines are mainly mass produced in China and obviously are very cheap. The labor and part (s) to repair are more expensive than replacing the machine.
If you do, look for a higher quality German machine i.e. Intimus, Olympia, HSM or Dahle. They cost more but they have a nationwide service arena and parts are always available.
Posted on Mar 08, 2009
WHERE I CAN FIND THE PLASTIC WHEEL FOR MY CROSS CUT PAPER SHREDDER MODEL;OM99733
Posted on Aug 05, 2013
Makes grinding noise and does not pull the paper in or shred. I have pulled out all bits of paper stuck between the teeth. I'm afraid this thing is toast
This type of shredder can get clogged so badly, the material has to be removed with a utility knife. This is especially true if someone has tried to shred coated stock or, worse yet, credit cards. The noise you are hearing is the mechanism bouncing over clumps of residue jammed in-between the grinding "teeth".
Apr 18, 2015 | Royal 1200MX 12 Sheet Strip Cut Paper...
What kind of oil is used on the royal orca 9512x?
The shredder does not use oil. The noise probably relates to something jammed in the shredding mechanism or one or more damaged shredding elements.
Mar 01, 2015 | Royal Office Equipment & Supplies
Do you have info on paper shredders that just stop
shredders have a small tag next to the cutter wheels that move when you insert paper to shred. This tag is easily jammed or damaged during operation. It is normally about the middle and will be positioned between two blades. If this is not moving when paper is inserted it will not switch the machine on. It is the same switch that wwhen jammed by paper will not switch off the machine after paper has been shredded.
Nov 08, 2014 | Office Equipment & Supplies
Why won't shredder turn off automatically?
turn off and unplug; then turn over to see if there is any paper jammed in the shredder. MAKE SURE YOU TURN OFF AND UNPLUG BEFORE YOU WORK ON IT.
Clean out any jammed paper or plastic with a bamboo skewer or something like that. DO NOT put YOUR HANDS near the blades.
Jul 15, 2014 | Destroyit 2603 SMC Shredder
Omnitech shredder model ot--exc10a , shredder runs but when insert paper to shred it stops, pull out paper and it runs non stop!
Sounds like there's blockage between rollers and it also jams the sensor so auto function stops working. You will need to clear out as much jammed paper as you can using tweezers. Inspect the centre of the feed opening, there should be sensor which must be clear of blockages and moving freely. So clear any stuck paper with tweezers, in addition you can soak any jammed paper with WD-40 and unit should be good as new. Although if sensor arm is damaged then replacement of such sensor is unavoidable.
Nov 04, 2013 | Omnitech 18-Sheet Cross-Cut Shredder
When you put paper in it starts to shred for about 1/4 inch then goes to reverse. No jams that I can see. Can run forward and reverse without paper with no problem. Sensor problem?
No mention of make or model however this holds true for all shredders.... especially if its a "cross-cut" shredder; put some shredder oil onto the cutting shafts where you insert the paper this will help get rid of some of the build-up that occurs due to the shredding process...also give the "eyes" in the middle of the "throat" a clan with a soft cloth( unplug the machine first or it will start to run and take your cloth in.) Occasionaly shrd a sheet of paper with some shredder oil poured directly onto the paper..this will help lubricate the cutting blades. Lastly...only shred up to about 70% of the rated cpacity..this will result in fewer jams an longer machine life.
Oct 19, 2010 | OfficeMax 0M96431 Shredder
Paper Shredder problem Royal JMD500 paper shredder makes a banging noise and paper only shreds about 1 inch in and then stops. You must put machine in reverse to take paper out.
Sounds like shreddder gears are not staying aligned or somethhing is caught in the cutters.
The shredder has a sensor to detect when somethine is insert. Hol the sensor swith down and check for paper clips or staples in the roller/shredding teath. Good Luck and use a match book on the switch to wedge it..
Sep 16, 2009 | Toastess International PV434995 Electric...
ROYAL RL170MX Shredder won't shred
Did you ever put shredder oil onto the cutting blades?????
The blades can clog with paper dust and then it can't shred as many papges as it should or even jam completely...you should occasionally shred a sheet of paper with shredder oil poured onto the sheet.
Aug 11, 2009 | Royal 1280MX Shredder
Paper shredder not working
sounds like the cutting wheels have something jammed inside them , can you take it bak and return it ? or open it up and see if anything looks bad inside ?
Jan 07, 2009 | World Office Products Papermate PM-600C...
Won't pull paper
I have the same shredder with a different problem. Maybe we can help each other.
It sounds like you have paper jammed in the shredding mechanism. I've cleaned paper jams out of mine quite a few times. The first and most important step is to make sure the shredder is unplugged. Hold the unit up to look through the shredding slot. Some of the openings between the opposing shredding wheels will be filled with paper. Using a small screwdriver (narrow blade at least 3 inches long) you can gently push the paper through. It works best if you can us a pair of needle-nosed plyers to pull the paper out the other side. It takes patience, but it works. Good Luck.
My problem is that after I opened mine up, I turned it over to shake out shreds of paper. When I did this, the entire works fell out of the case and all of the wires disconnected from the 3-way switch. Can you look in yours and describe how the wires are connected to the 8 contacts on the switch. (a digital photograph would be GREAT!
I hope we can help each other.
-- Wcbyers
Jul 13, 2008 | Tech Solution TS-2550 Shredder
OfficeMax 0M96431 Shredder Logo
766 people viewed this question
Top OfficeMax Office Equipment & Supplies Experts
ROCKIT957
Randy Schumann
Randy Schumann
Colin Stickland
Colin Stickland
Are you an OfficeMax Office Equipment and Supply Expert? Answer questions, earn points and help others
