Question about Legacy Interactive Emergency Room: Disaster Strikes Legacy for Windows, Mac
I start my game and it tells me it needs 3 MB of virtual memory
I have Windows XP and I installed it in compatibility mode for Win98. So I know there shouldn't be a problem there, but how do I give it 3MB of virtual memory to run on?
    An expert whose answer gotĀ voted for 100 times.
    Sniper:
  • 66 Answers
FRIEND. you need to go to launcher.exe file and right click and properties and compatibility.and set as windows 98/NT .and click the icons downwards to enable virtual memory.
Posted on Mar 28, 2009
I cannot install School house rock 3rd and 4th grade
There are workarounds besides using an older version of Windows (dual boot or a separate machine). This requires a licensed version of the older Windows OS. However, if you have the most common version of Windows 7 - Home Premium x64, you'll have to spend some money.
School House Rock - 3rd and 4th Grade works with Win98-XP. So, you can run a virtual computer with the older version of the Windows OS. Then install the School House Rock program into the virtual version of Windows as if it were the only copy of Windows. If you have Windows 7 Pro or Ultimate, or upgrade to one of these versions, you can do this for free. Download and install Virtual PC and XP mode from Microsoft (in order). Other virtual computer programs are VMWare and Parallels. However, with those, you need to buy the program and have a licensed version of the Windows OS.
If you have the 32-bit version of Windows 7, you can try the compatibility mode. (To check your version, click Start > Control Panel > System and Security > System. If the title of the OS ends with x64, you have the 64-bit version. Otherwise, you have the 32-bit version.) If you have the 32-bit, right click on the installer for the School House Rock software. Select Properties and then the Compatibility Tab. Check the Run this program in the compatibility mode and an older version of Windows. Then click Apply and then OK. Right click on the installer again and select Run As Administrator. You may need to repeat this for the program itself.
I hope this helps.
May 09, 2012 | 2K Games SCHOOL HOUSE ROCK - 3RD AND 4TH...
I purchased Egames Lexicon. When I try to install it a message appears that says it cannot start or run due to incompatibility with 64-bit version of Windows. How can I get this software to work on my...
Right click on the executable file that starts the setup, typically setup.exe. Select Properties. Under Compatibility, set it to Windows XP SP3. If that doesn't work, it really won't work without you setting up a virtual machine and installing a copy of XP. If you're running Windows 7, you can download a Windows XP virtual machine to run. It's called XP Mode. Instructions can be found by searching for XP Mode in the Start menu's Help and Support.
Jul 06, 2011 | E-Games Lexicon Word Challenge for Windows
It says it cant start or run do to incompatibility with 64 bit versions of windows....any way i can make my mission think game work? :/
The Learning Company Super Solver Mission T.H.I.N.K. was released in 1999 for Windows 3 and probably Windows 95/98. It could run under XP in the compatibility mode.
For a newer Windows OS, you need a workaround. You can use a a computer (virtual, dual-boot, or true second machine) with an older version of Windows installed. If you have Win7 Pro or Ultimate, you can create a virtual XP computer for free. Download and install Virtual PC and XP mode from Microsoft. Install them in order. Then install the XP software in the virtual computer using the compatibility mode and it should work. (Other virtual computer programs are Parallels and VMWare.) All of the other options will require a licensed version of the older Windows OS. If your computer has a USB keyboard and mouse, you will need to use Win98 or newer OS. (However, the drivers may be an issue with Win98.)
For the compatibility mode, right click on the installer and choose Properties. In the compatibility tab, check the box for Run as compatible with an older version of Windows. Then launch the program.
I hope this helps.
(Windows 95b supported USB but it wasn't really ready for the USB)
May 14, 2011 | The Learning Company Super Solver Mission...
Backyard soccer won't work on my 64 bit windows laptop.
Are you using Vista or Windows 7?
As far as i remember Backyard soccer is kind of an old game. It likely only works on Windows XP
May 04, 2011 | Computers & Internet
I have the cd rom disc stratego and I am trying to install it on windows 7 and it will install but it will not let me play it.. is there somewhere where I can buy the cdrom for windows 7 or somehow that I...
This game won't work on Windows 7 in any of the compatability modes. The only way to get this game to work is to run it in windows xp. The good news is that you can get free software from Oracle called virtualbox. Using virtualbox if you have a xp installation disk, you can create a virtual windows xp that runs within your windows 7. Stratego plays fine from within a virtual windows xp, provided that you play from the cd-disk not the virtual hard drive. Install the game normally in the virtual windows xp environment. After installation, to play the game, you must be in virtual windows xp, then double click the CD/DVD drive icon that looks like a bomb. If you try playing from any of the shortcut Stratego (also looks like bombs) launchers or the stratego.exe file installed on your virtual hard drive, the game will not work.Just go to My Computer in the virtual windows xp, and double click the cd/dvd bomb icon, and the game starts up fine.
Feb 18, 2011 | Infogrames Stratego for Windows
I have a copy of starcon 3 but it won't install on my computer my os is windows 7 but it says that the game isn't compatable with my version of windows
Hi, welcome to Fixya. I hope my info helps you.
What it said is true. Starcon 3 is an OLD game, with compatability with win 95, and DOS. I think there may be a way for you to get to work though, right click on the installer program, and put the program in compatability mode, and tell it win 95 for the o.s. If that doesn't work, then download a program called DOSBOX, and run the installer with it, Dosbox is designed for just this sort of thing.
I hope that you do get it to work, as Starcon 3 was a really good game when it came out.
Jan 20, 2011 | Computers & Internet
I had my comp. fixed and they put windows vista home premium on here and i can't play my old games that need xp what can i do
You can do 2 things:
1 - try to run them in XP mode  - right click on its icon, then Properties, then Compatibility, check 'Run this program in compatibility mode for' and select Windows XP in the drop down menu and finally at the bottom of the compatibility tab, check 'Run this program as administrator'.
2 - install http://www.microsoft.com/windows/virtual-pc/ , configure it and in it install XP and all the soft with problems, starting with the games.
Mar 07, 2010 | Microsoft Windows Vista Home Premium...
I have MS Money 1999 operating with Windows 98 which will no longer open except in safe mode. Can I download a version of MS Money to use with my back up disc - using Windows XP Home
You can in fact run it in Win 98se Mode in XP, you simply have to set compatibility for win 98, right click the install, sertup, install, .exe and choose properties, then set the compatibility tab for Win 98. also do as Administrator, and also install as Administrator too. You may also need to alter some of the "other" setting on that tab too, you may have to experiment a little to get it to go... Failing that you could use MS Virtual PC, and set it up running in that, you could make a Win98 Virtual machine and load it and run it on that?
Feb 18, 2010 | Computers & Internet
Drakan order of the flame engine crashes when i start a new game. i have windows 7 but im running as admin and in compatability mode for win xp sp2. what else can i try?
You could try installing the DirectX version the game uses. (probably on disk)
You can also try to download this Windows Virtual PC.
Windows Virtual PC emulates Windows XP on your Windows 7 PC, so that you can run older applications that won't run on Windows 7 otherwise.
You will however need a processor capable of virtualisation.
Virtualisation check and download here: http://www.microsoft.com/windows/virtual-pc/download.aspx
After installing Windows XP Mode you will need to install the game again in this XP emulator, but after that it should run fine.
I hope this helps,
Yannick.
Dec 08, 2009 | Activision Drakan: Order of the Flame for...
Legacy Interactive Emergency Room: Disaster Strikes Legacy for Windows, Mac Logo
151 people viewed this question
Top Legacy Interactive Video Game Consoles & Games Experts
James Wishart
Are you a Legacy Interactive Video Game Console and Game Expert? Answer questions, earn points and help others
