Question about Dell OptiPlex GX280 PC Desktop
Took hard drive out and put back in now green lights are on but m
Dell desktop
    Problem Solver:
  • 13 Answers
Are you getting anything at all on the screen or just a green light on the front of the PC?
IF the drive was removed make sure that the ribbon cable was not reattached with pin 1 on the pin 40 position, try turning the cable over 180 degrees and power back on, you will also have to reset the intrusion detection
Posted on Mar 07, 2009
Dell Dimension 1100 hard drive activity light on constantly and hard drive making noise, lagging
Try to create an other user and login with that user, then check if the issue still happen.
Jan 03, 2013 | Dell Dimension 1100 PC Desktop
My dell optiplex 330 fails to start. dignostic light 3, 4 blinks all the time the processor run and the hard drive is also fine please help solve problem
There is an issue with a fulty RAM module. Open up the case and remove one of the RAM modules. try restarting. If that doesn't work, put the one that you took out back in, and remove the other one. If that works, then you need to buy a new module to replace the one that was bad
Mar 04, 2011 | Dell OptiPlex 330 Desktop Desktop Computer...
Dell dimension 4600c won't turn on since we had a power outage
hi
if you CPU has a green light it meance your Power supplay is working fine chack back side of your CPU fan is working or not if it's working then just open case
folow the 2 step
1 remove RAM
2 CIMOS beetery which is on mother board leave your CPU for Some thime re fix both i hope you CPU will give you the disply
Jul 19, 2010 | Dell Dimension 4600 PC Desktop
My Dell Dimension desktop 9150 was running very slow so I shut down the computer. When I pressed the power on button I notice that it was flashing. I pressed the button even holding the power button in...
the constant Green, states that the motherboard is getting Power.
The red/yellow would possibly suggest, that the ethernet port has a fault or possible corruption.
Solution:- remove the Power Lead from the Computer Case.
Remove side panel. take out any ethernet-Cable from the rear.
Locate the CMOS battery, round silver Battery on The motherboard.
For 10 seconds, this should reset The bios, to it,s original Default Settings. Replace Battery, side Panel. And power Lead.
You could also try This. Boot with Hard-drive power Cable Disconnected ( this will Eliminate HD Fault ) same for CD/DVD drive et,c.
Mike @ Compurepair.
Oct 22, 2009 | Dell Dimension 9150 (DIM915MIN) PC Desktop
No display on the Dell Dem 520
IT SOUNDS LIKE HARD-DRIVE FAILURE, TRY REINSTALLING THE OPERATING SYSTEM, BUT IF IT DOES NOTHING THEN REPLACE THE DRIVE
Jun 16, 2009 | Dell Dimension E520 PC Desktop
Dell Dimension 5100, Doesn't Boot Up, Display Lights Up "!, 2 3"
2 green lights usually indicate a memory problem, however, when you get 3 lights, RAM is good, but the BIOS is unable to hand off to the operating system.
To test this, disconnect your hard drive (both ribbon and power) and connect the monitor. See if you get a display. If you get a display, try carefully reseating the cables to the hard drive and also to the motherboard.
If you lose the display again, disconnect the hard drive and connect your DVD/CD and put in a Windows or diagnostic CD to see if it will boot.
If it does, you have a bad hard drive.
Let me know if this helps or you have other questions.
Honest1abe
Jan 27, 2009 | Dell Dimension 5100 (D51L1) PC Desktop
Replaced 128mb with 512mb in Dell Dimension 4400. Plugged everything back in & turned on. Or at least think it is turned on; there is a green light for both the power button and hard drive lights. ...
If you have replaced the memory on a computer and it does not turn on normally that means that either the memory is defective or it is not compatible. Do you hear beeps when you turn on the computer?
Nov 26, 2008 | Computers & Internet
The motherboard cannot detect the hard drive/ hard disk
You cant install xp on one machine and then move the drive to another. By nature the xp install is tied to the hardware of the machine it is installed on
May 22, 2008 | Dell OPTIPLEX GX110/200 PIII-866MHz 256MB...
Pover up trouble
sounds like something is drawing down on your 12 volt supply drives or on board regulators. Try it without the drives connectged, and see if you can get the system to boot up(you'll just get a notice that your drives are unavailable, but you'll already know that, right?
got backup for your Dell?
Feb 15, 2008 | Dell Dimension 5100 (D51L1) PC Desktop
No power to my dell dimension 4550
It might be a couple of things bad powersupply or power button incorrect ram module or hard drive settings ,if not then lastly have a bad motherboard which we all hate. you said you have a a green light on motherboard? Did you upgrade or install any new ram ,harddrives etc check make sure they are seated properly in their sockets and free from dust check connection on the ram module make sure it shinny brass color if not you can use an eraser to clean them. If you have upgraded check make sure the ram is compatible to your machine sometimes the wrong ram install can cause no power up problem. Do you have four green lights in the back of machine? Dell new desktop has 4 green light in back of the unit . if all four light are green then system is ok but one out of the four light are orange then you have a problem. You can go onto dell web sight for your machine to check out these lights codes. I hope this help you out some.
Feb 12, 2008 | Dell Dimension 4600 PC Desktop
Dell OptiPlex GX280 PC Desktop Logo
56 people viewed this question
Alun Cox
