Question about Sharp Notevision XG-NV6XU Multimedia Projector
Works but prdominantly green, can't ajust with color controls
THe projector gives a sharp image but the screen is predominately green although I can see red and blue. The color controls don't change it.
  • 3 Answers
The lcd polerizer(not sure this is proper name ) is bad.It has three: red,green,blue and one of them is bad. I also have a similar issue but only on the left side. Took it apart and found the bad one.
Posted on Apr 05, 2009
Hi there, my dell projector 1800mp is not projecting an image on screen and it only black lines across. what should I do to fix it?.
After turning on the projector, press "+" and "-" buttons on the control panel
simultaneously for 3 seconds and release the buttons when screen goes blank.
2 Press "+" and "-" buttons again to exit the diagnostic mode.
3While in Self-diagnostic mode, the screen will run a seven-color-cycle test as
following:
Red--> Green--> Blue--> White--> Watchet Blue--> Dark Green--> Yellow.
Ensure that the colors of the test pattern are correct. Contact Dell if the colors are
not displayed correctly.
Mar 02, 2011 | InFocus LP 250 Multimedia Projector
Missing blue region
It sounds like the bulb overheated at some point. Time to replace the bulb.
Oct 31, 2007 | Sharp Notevision XG-NV6XU Multimedia...
Image is bright but there is a slight issue - on the left hand side a purple line displays vertically. Anybody knows why is this fault appeared and how could it be solved.
There is three LCD in the projector red, green and blue. If green LCD make any fault mean line or dot or dots then screen show these line or dot in purple color:
If line is very straight and sharp edges then green LCD is faulty and need to be replaced.
If line is not straight and faded edges then some thing in LCD block so your projector need service
Feb 22, 2011 | Sony VPL PX40 Multimedia Projector
Green and red spot in projector image
its' not your bulb. it could be the color wheel. Nothing you can see by opening it up and physically seeing anything. You will need to send it off for repairs.
May 29, 2010 | Sharp XG-C430X LCD Projector
I have a TRV-35G and the colour is predominately green which I cannot correct across the whole screen with the joystick control. Where the colours of the picture have been corrected (across 2/3 of the...
Try turning colour correction OFF. (button in up position). See what affect the iris control has. This control will changed the color of the slide from deep red at nearly closed to washed-out blue and white. at full open. I adjust the controls for each slide. The color temperature of the 8549 lamp varies with the brightness. lower level warmer, higher cooler.
Dec 02, 2009 | Elmo Projectors TRV-35H Slide Projector
Abnormal picture
if it's an xr-32x (as it shows on this pic), it's a dlp projector, not an lcd. therefore no green filter. it has only a colorwheel and a dmd chip to affect the color. if it's not an xr-32x, and it's an lcd projector, replace the green filter. sharp sells the parts for the optical engine. but if it was your service tech that did it, have them replace it.
Jul 28, 2009 | Sharp XR-32X Projector
Sharp projectors color all green
how is the vga cable?
is the green color coming in the sharp menu with any signal?
Jun 15, 2008 | Sharp (BQCPGC20X1) Projector Lamp for...
Tinted image
If you are plugging in a monitor cable, it is most likely a cable issue. I would try another cable and make sure the cable is seated firmly into the projector. If that doesn't help, check the port on the projector for bent or missing pins because it seems that not all of the video information is reaching the unit.
Feb 02, 2007 | Sanyo PLC-XT16 Multimedia Projector
Sharp Notevision XG-NV6XU Multimedia Projector Logo
366 people viewed this question
Top Sharp Office Equipment & Supplies Experts
k24674
CheckitRight
CheckitRight
Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
