Pink screen says system update required
If you receive a connection error, try using the Xbox LIVE Connect Solution.
Console update did not install successfully?
If her system says that she needs an update then likely her connection should be getting to Live. You might need to clear her cache first and then try the steps above. Here is how you will clear your cache:
To clear the system cache
(It doesn't matter which storage device you select; the cache will be cleared for all storage devices.)
