Question about Westell Wirespeed VersaLink (A99-327W11-00) Router (A99327W1100)
Cannot Network printers on FIOS system
I was using Verizon DSL with my desktop (Vista) wired to the router and my laptop (XP) networked to choose any of three printers connected to my desktop. We recently changed to Verizon FIOS and they installed a wireless router in the other room. Both computers connect wireless to the internet OK. I cannot get the Home network to allow each computer to see each other. I have reinstalled the Home Network but still nothing.
  • 1 more comment
  • greenwell252 Mar 07, 2009
    Both computers use the wireless router and I have both set to printer and file sharing. I have also tried turning off the firewall on both and still no connection.
    I do not know how to try a ping to the other computer.
    With both computers firewall off, I tried ping from both computers and both time out with no response from the other one.
  • 928 Answers
If both computers are connected to the router. Try turning off the firewall on both computers first. normally its firewalls blocking file and printer sharing that block the connection.
Posted on Mar 07, 2009
  • 1 more comment
  • Thomas Lim
    Thomas Lim Mar 07, 2009
    Can you ping one computer from the other via the command prompt?
  • Thomas Lim
    Computer 1.
    Click start then run then type in CMD then click ok in the black window type in
    IPCONFIG then hit ENTER Copy down your IP address
    Computer 2.
    Type in PING IPADDRESS then hit Enter. Do you get replies or request timed out.
    Reverse the instructions and get the IP for computer 2 and ping from computer 1
  • Thomas Lim
    Then that means that there is still some other firewall on the computer. Or another option is uninstall the firewall. Sometimes with the firewall off it still runs in the background this is especially true of Norton
Windows Networking Issue
FIOS and DSL use different modems and or gateway devices. Sounds like you were using a DSL gateway device with networking setup and when you moved to FIOS, the tech did not duplicate your network on your new FIOS gateway. OR you had a 3rd party router e.g. Linksys that was removed from the setup when FIOS was installed.
Either way, Verizon is who you should contact. Just tell them your network went down after you moved from DSL to FIOS. Dont mention Microsoft or Livewebtv.
Sep 21, 2009 | Dell Inspiron 1525 Notebook
Network Vista Wireless Laptop to XP Desktop & Print Documents
On the desktop machine - go to the printers folder, right click the icon for the Laserjet and choose sharing (enable print sharing). You should be able to name the printer and make it accessible to anyone within the workgroup. If needed you can run the network setup wizard to change the workgroup names on both machines.
On the laptop go to add new printer and choose network printer, you should be able to browse to the desktop machine by name and choose the Laserjet as a printer (whether you want it to be the default is up to you). The laptop will download and install the drivers from the desktop pc to the laptop and set the correct network path automatically.
It goes without saying that the desktop machine must be on in order to print from the laptop in this scenario.
Feb 21, 2009 | Dell Inspiron 1525 Notebook
Installed XP Pro and system doesn't recognize network adapter
Whenever you format a laptop, you always need to install the drivers for the chipset, audio, graphics, wifi, LAN etc
Click on this link and, from the drop down menu, choose pronet81266 for wifi and the LAN one at the bottom:
http://support.acer-euro.com/drivers/desktop/aspire_t180.html
Install the chipset and the audio too. The one on the list that says ati is for your graphics card.
Fixya!
Chris (ziraffa)
Jan 04, 2009 | Acer Aspire™ T180 PC Desktop
FIOS Internet connectivity problem with Toshiba Satellite 105
Is your laptop running Vista and the desktops running Windows XP or they all running the same software??? Also your problem is the fios router they come set up to be on a automatic channel search so there always searching for the best channel and you probably live in a brick house....Go to the settings for the router you can get to them easy with the software they downloaded to your computer its the fios help icon on your desktop and you can change the routers channel go to 7 or 11... If you have any questions just let me know also please rate me if you get a chance..
Thanks,
Steve
Dec 17, 2008 | Toshiba Satellite A135-S2246 Notebook
Create a local area network
you can get a HP x175 printserver. (not expensive.) and connected it between the printer and the router. that way you don't have to have the desktop on all the time.
Dec 02, 2008 | Computers & Internet
How do i build a local area network in windows xp?
On the machine that the printer is connected to go to Start>Control Panel>Printer and Faxes>Right click the Printer that you want to Network and Left Click Sharing> Select the Option to Share the printer and Name it something that you wil remeber. On the Laptop go to printers and Faxes select add new printer and select Network Printer. And Choose the second option Put the Name of the Computer that the printer is connected to and then printer name. Example \\Desktop\HpPhotoSmart 8100. Also you will need to check to make sure that both machines are on the same Domain\Work Group. Go to Start>Control Panel >System>Computer Name Tab ( Here verify the Machines Name)> Join or Change Domain>Put the machines on the same Workgroup if they are not, Do the same on the laptop. To test this, on the laptop go to Start>run and type \\Desktop Name and you should see what is able to be shared. Walk thru the steps above to install the printer on the laptop and have the intall cd in the laptop to install the drivers and you should be good to go. I hope this is understandable. If not feel free to email me at smichael@phoenixschool.net and I will see if I can clarify this for you. Happy networking!
Cannot connect to the internet with my laptop
To connect to the router wirelessly using a Windows XP, right click on the wireless network connection icon on the lower right corner of the screen and choose view available wireless networks. Select your existing network and click on the connect button. If you are using Vista, go to network and sharing center of your control panel then select connect to a network. If you still having problems, please provide details of the problem like your Internet service provider and if there are already other computers online with your WRT54G2.
Jul 11, 2008 | Linksys Ultra RangePlus Wireless Routr...
The battle: Acer Vs. Verizon FiOS
Verizon needs to apply a firmware update for the Atheros wireless adapter in your notebook. I work for Acer and I end up having to tell people this all day long. If you take this to a wireless router that is not from verizon you will have no problems with your connection. Maybe if enough Fios customers complain they will provide a firmware update for this.
Mar 06, 2008 | Computers & Internet
Trying to network xp pc to wireless laptop
Right click on the drive you want to share. Ex: C:\Vol-xx = name. In the pop up window click Sharing & Security. This needs done to all the drives you want access too. To share a printer. Everyone must have the printer drivers installed. The Pc that has a direct connection to the printer must also Share the printer on the network. Open Printer & Faxes, highlight the printer you want to share. Click File than click Sharing follow windows instructions.
Small suggestion regards to the wireless side of the network. Suggest you setup security so others close too you can not tap into your network. (common).
Feb 14, 2008 | Linksys Wireless-G WRT54G Router
Westell Wirespeed VersaLink (A99-327W11-00) Router (A99327W1100) Logo
190 people viewed this question
Top Westell Wirespeed Computers & Internet Experts
Prashant M
Prashant M
Michael Galve
Michael Galve
Are you a Westell Wirespeed Computer and Internet Expert? Answer questions, earn points and help others
