Question about Crosley CDE6000 Electric Dryer
How do you take the back cover off? - Crosley CDE6000 Electric Dryer
  • Crosley Master
  • 8,205 Answers
Their is no back cover on a Crosley dryer. You must work from the front. You start by removing the power. Use a standard putty knife to press against spring clips which hold the top down to the front panel.
how do you take the back cover off? - 0c0a1bb.jpgOnce the top is flipped up you can remove the 2 screws holding the front panel on.
Once you get that out your way you can remove the drum and clean out the lint from the dryer. The heater is in the rear. The limit is mounted on top of the heater, it will shut down the heater at 250 f. the fuse is mounted on the side of the heater and will BLOW if the temp exceeds 300f. The main problem on these dryers is the plastic blower wheel which will get loose from the heat an make it take longer for the clothes to dry. Much longer. Also a ball of lint will get into the filter housing. The glides and rolers need to be inspected before you reasemble the dryer. It is reccomended you use temp resistant zoomspout oil to lube the wheels and idler. This is a well builtsimple design that is well worth repairing.
Posted on Apr 12, 2009
Removal of engine cover
Pry apart the back cover by guiding the flat-head screwdriver along the separating line between the front and back covers of the iPhone. When the back cover is apart from the front cover, flip the back cover off the iPhone, but be careful because a flat cable that goes to the motherboard connects the two covers.-----------------------------------------------------------------------------------
NEXIQ 125032 USB Link Plus
Jan 17, 2013 | 2007 Pontiac G6
Tip
Nokia battery
<b>Remove the back cover</b><br /> Place the phone with the back of the phone facing you. Pull up the back cover from the finger grip at the top of the cover.<br /><br /><b>Note:</b> Always turn off the power, and disconnect the charger and any other device, before removing the cover. <a></a><span>Avoid touching electronic components while changing the cover.</span> Always store and use the device with the cover attached.<br /> <b>Remove the battery</b><br /> After you have removed the back cover, insert your finger into the finger grip, and lift the battery from its compartment.<br /> <b>Replace the battery</b><br /> <ol> <li>Insert the gold-colored contact end of the battery into the battery slot. </li> <li>Push down on the other end of the battery to snap it into place. </li></ol> <b>Replace the back cover</b><br /> Place the back cover on the phone bottom first so that the cover tabs align with the slots in the phone and press the cover moving from the bottom to top until the cover is securely in place.
on Mar 09, 2011 | Cell Phones
My battery wont charge and i can't get the cover the battery off. how do I get it off?
To get the direction to take off the back cover of the phone depends on the type of the phone you are trying to get the back cover off. But for all phones, it is either you press down the back cover then slide it down as you press it down.
Another way is that there used to be a hook by the top of the back cover, press it down and gently slide down the back cover. Or you look around the back cover to see where it is being hooked so you release it from there and lift off the back cover.
If this does not help, please state the exact type of motorola phone you are trying to get the back cover off. Also, try out the charger on another phone to see if the fault is not from the charger.
Hope this helps.
Dec 22, 2010 | Motorola Cell Phones
How to put back the back cover of caio watch MTP-2144
mcdevito75 Here, That back cover should have 4 screws to hold the back cover onto the caseing. Donot apply pressure to that back cover or you may destroy the LCD face of your Casio. Use a tweezers to place the screws and gently screw down back cover.
Sep 24, 2010 | Casio Watches
Back Cover Open Close The Back Cover Is Message I'm getting. What is the Problem?
Open the front cover and remove the drum and toner(cartridge).
There should be a paperjam in the machine. It reads back cover open because the piece of paper is covering the sensor for the back cover.
May 31, 2010 | Brother IntelliFax-2820 Laser Fax
It says close back cover but back cover is already closed
Open the front cover and remove the drum and toner(cartridge) There should be a paperjam in the machine. It reads back cover open because the piece of paper is covering the sensor for the back cover.
Apr 19, 2010 | Brother MFC 7420 All-In-One Laser Printer
Fax display says, close back cover even with back cover closed.
Apr 15, 2010 | Brother IntelliFax-2820 Laser Fax
Brother MFC-7420 Fax Scan Copy
Maybe there is broken at the back cover try to check again the back cover,inspect the cover very well .
Nov 09, 2008 | Office Equipment & Supplies
Back cover error on LCD won't go away
This is most likely caused by the back cover switch. It is either broken or the lever on the back cover is broken off.
Sep 14, 2007 | Brother DCP-7020 All-In-One Laser Printer
Crosley CDE6000 Electric Dryer Logo
192 people viewed this question
Top Crosley Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a Crosley Dryer Expert? Answer questions, earn points and help others
