Question about Dell 2300MP Multimedia Projector
Projector I have a dell 2300mp projector. I replaced the lamp with a brand new one. I plug the power cord and the green light on the power button comes on flashing. I press the power button and the light turns solid green but the lamp does not turn on and the fan does not turn on. After 4 to 5 minutes the amber warning light turns on. If the fan does not work does the lamp not turn on also? Help please. On light works, after a few minutes the lamp light comes on, but no fan, no light, color wheel does not spin.
    Brigadier General:
  • 8,619 Answers
Hi
If the fan is not working, the lamp will not fire. Kindly make sure that the panels are seated properly. Also chek if the outer cover is seated back 100% as if that is not seated back 100%, the unit will not work.
Posted on Mar 07, 2009
    Sergeant:
    Novelist:
  • 277 Answers
The lamp is either not replaced properly or its the problem of ballast also .after replacing the lamp there is a reset procedure that has to be done did you reset tted .if not aii the procedures are given try 1 by 1 how to replace the colour wheel with diagram and procedure
http://www.jangro.com/a/2006/07/24/samsung-dlp-replace-color-wheel/
how to replace the lamp in 5 minutes with diagram and procedure
http://www.jangro.com/a/2006/08/03/how-to-change-your-samsung-dlp-lamp-in-5-minutes
how to replace the ballast with diagram and procedure
http://www.consumermeet.com/entry/samsung-dlp-ballast.html
  • Dell Master
  • 19,396 Answers
Check that you replaced the lamp in the right way, and also that the unit is well reassembled, you may also need to reset lamp counter from menu on some model.
  • Ginko
    Ginko Mar 07, 2009
    If you can access projector menu, then chose management menu, and select reset lamp counter.
    if you cannot access the menu , then there is a fault, disassemble the lamp and put back in place , double checking that all procedure is correct.
    If still no luck, then usually the circuit that power up the lamp is defective.
2 Suggested Answers
SOURCE: projector
Same problem
When i turn the projector on it only comes on four about a minute until the temp lights go amber and it turns off, the fan is working but the air coming out is a little warm. what if anything is making my projector overheat, or is it not heating at all?
Posted on Aug 07, 2008
I have a Dell 2300MP DLP projector. It lights up for about a minute then the light goes out. Both the Temp and Lamp indicators are glowing after the light goes out. The fan is working. Will just replacing...
Looks like there is power supply problem as well as the lamp.
1 Clean all filters
2 Check out power supply (usually a few capasitors need to be replaced)
3 Wuld be a good idea to check the lamp in wokring projector, but if the "Lamp" light is constantly on it is more likely a faulty lamp as well.
Mar 01, 2011 | Dell 2300MP Multimedia Projector
Dell 2300mp
Replacing the lamp module requires special considerations:
  1. Turn off the projector.
  2. Wait 30 minutes for the projector to cool down and then unplug it.
  3. On the bottom of the projector, loosen the two screws on the lamp cover and then remove the cover.
  4. Loosen the two screws on the lamp module and pull out the module.
  5. Insert the new lamp module and tighten the two screws.
  6. Install the cover and tighten the two screws.
  7. Turn on the projector. If the lamp does not turn on after the warm-up period, try reinstalling the lamp again.
  8. Press enter on the projector or on the remote control to open the on-screen menu.
  9. Press the up (c00589410.gif ) or down (c00589411.gif ) arrow to select Setup and then press the right (c00589412.gif ) arrow.
  10. Press the up (c00589410.gif ) or down (c00589411.gif ) arrow to select Reset lamp hours and then press enter .
Jun 18, 2008 | Dell 2300MP Multimedia Projector
Dell 2400 MP projector lamp problem
could be a heat, fan - sensor issue or a power supply issue. Regards Kevin Andreassend http://www.iceav.co.nz iceavtech@gmail.com
Feb 03, 2009 | Dell 2300MP Multimedia Projector
Dell 2300MP Projector Lamp - "Orange Light"
I've heard it could be the ballast, check with Dell for replacements
-- Deft
Aug 21, 2008 | Dell 3200MP Multimedia Projector
Dell 2300mp projector
check this out...
http://www.ihatedell.net/forum/phpBB2/viewtopic,p,36316.html
have almost the same problem. lamp light turned on-->replaced the bulb, now when you turn it on tryies to boot and then the lamp light is on again (but the bulb is brand new).... and no light at all coming out of thing... I guess dell just don't know how to built projectors right way.... and theirs tech support guys are.... they just don't know about projectors more then manual
Jun 20, 2008 | Dell 2300MP Multimedia Projector
Projector
A couple of things...
If the fan is not working, the lamp will not fire. If you have the owner's manual, it should indicate what the flashing lights mean. Check to make sure that the panels are seated properly. When you replaced the lamp, the outer cover was removed. If that is not seated back 100%, the unit will not work. There are a number of safety "checks" built into the unit to prevent damage and possibly fire as the lamps get really hot.
Check the items above and let us know your progress.
Dan
Jun 19, 2008 | Dell 2300MP Multimedia Projector
The projector lamp comes on (amber color) no image
I was told by an expert that the fan should come on as soon as heat starts to come on. You should never turn a projector off with out the fan running for a while to cool the bulb down. Each projector is different but the fan has to operate on then all. There is so much heat in the bulbs that air has to keep them cool when they are operating as well have to cool gradually when they are shut down.
Mar 02, 2017 | Dell 2300MP Multimedia Projector
Dell 2300MP - no power
It looks like you may have a loose contact somewhere around the AC input. Try pushing the AC cord or wiggle it gently, if power comes back on; you have a loose connection.
Jan 16, 2008 | Dell 2300MP Multimedia Projector
No power to my dell 2300mp
The fuse is a short round maroon colored part to the left of the power plug looking at the power supply module from the direction that you would connect the cord to. it is labeled F1 and it is a 4a 250v. This is not the problem with my power supply though. I suspect one of the components under the heatsink is bad.
as you all know don't bother calling dell.
Nov 02, 2007 | Dell 2300MP Multimedia Projector
DELL 2300 MP NOT TURNING ON
Have the same problem here. Have two of these units. Took the bulb out of the one that had the Lamp light on, and put it in the other projector. The other projector worked perfectly. I have three bulbs, they all work in the one projector, they all cause Lamp Light in the other one. The manual states nothing about hard resetting the unit. Also note that, the fans do not power up instantly on power on, they come on about 5 seconds after pressing the power button.
Aug 30, 2007 | Dell 2300MP Replacement Projector Lamp -...
Dell 2300MP Multimedia Projector Logo
793 people viewed this question
Top Dell Office Equipment & Supplies Experts
jasbo
jasbo
Are you a Dell Office Equipment and Supply Expert? Answer questions, earn points and help others
