Where did you hook up the jumper cables to the ion? I would start checking fuses. Hooking up the number cables in the wrong spot will blow fuses.
I’m happy to assist further over the phone at https://www.6ya.com/expert/jeremy_d728a59f986299fa
SOURCE: Saturn Ion
Sounds like your Horn Relay is fried. That relay should be in the fuse box under the hood just pull it out and see if you can find a replacement directly from Saturn.
SOURCE: My 2003 Saturn Vue won't
Without knowing if there are more things happening, noises, clicks, whirr sounds, or even how hard you drive it...
It typically sounds like a bad or clogged fuel filter... Although I've had some cars do this in the past, once they were heated up and had to wait an hour ow two to start again... that generally meant the fuel pump needed to be replaced.
This is called a Vapor Lock... and try as you might, they will not start
So, before you start going through quite a few external sensors, idle air control motors and egr valves and etc, etc at 85 dollars a pop...
Considering changing the FUEL filter and pour a bottle of gas drier in your fuel tank. You could have some condensation in your fuel and it may be as simple as that.
However if this dont help or the problem starts happening again, I would replace the fuel pump.
Good Luck and Happy Motoring
Respectfully
SOURCE: My 2003 Saturn Ion remote trunk release won't
Check to make sure the button on the trunk latch is turned from manual unlock...they made that feature so only the key will work to open the trunk that way if someone breaks in the front of your car they can't hit the trunk release and get into the trunk...may be the same thing for your remote. Hope that helps.
