Question about Intel Motherboard
Computer wont boot
Ok i just put my old intel board in a new case and i hooked it up the same but when i boot it up it shows the ''intel desktop boards'' screen
then my monitor shows ''no input'' and then repeats
whats wrong with my computer
  • 101 Answers
Possible reasons:
1) short circuit between board and case. Check fastening and screws.
2) Poor contact to RAM and video card. Clean the pins by alcogol.
Posted on Mar 07, 2009
Have old desktop PC. was running OK, then got new PC. Now the old PC will not boot up - the fan sputters like you are flipping its power off and on continuously. what could be the issue?
The most common issue with old computers is bad contacts, especially with the RAM modules. If the PC stopped booting when you upgraded the RAM, it might be imcompatible with the motherboard, try putting the 1GB stick back. If that is not the case, try cleanning the contacts of the RAM module and reinstalling it. If you never done this before, you may want to ask someone experienced to do it because if you do not fit the module correctly, you can damage the motherboard and the RAM. In case you do this and the computer still won't work, it might be another faulty component. The procedure normally is to test other components, to find the problem. It can also be a problem with the PSU.
Sep 24, 2016 | Gateway Computers & Internet
Hi, I got a new graphic card, GF FX 5500 AGP, 256M, 128B for an old computer, intel pentium 4 1,79 Mh, XP profesional, SP2 and my computer don't boot whit this card. My old graphic card was Nvidia GForce 4...
go back to the old one you are using,maybe your board doesn't support your new graphics card,,i think your new one is agp8x and your board supports on 4x.or maybe you can set it bios to adjust the graphics
Feb 12, 2011 | Computers & Internet
Intel D945GCLF - No post, No video Signal
Sounds like your wiring isnt right on the on off power. Make sure your power supply can handle this MotherboardAdapter cables are available that allow the incorrect use of older ATX or SFX power supplies in place of an ATX12V or SFX12V power supply. Intel does not recommend the use of these cables. These cables convert a standard 1x4 peripheral connector to the ATX12V 2x2 connector. An ATX12V or SFX12V with the 2x2 connector is required for all Pentium® 4 processor based Intel® Desktop Boards. Using the 1x4 converter cables can lead to system component or power supply damage and/or boot failures. The ATX12V and SFX12V power supply design guides (http://www.formfactors.org/)* recommend a minimum of 8A at 12Volts to properly power any Pentium 4 processor based Intel® Desktop Board. Standard ATX and SFX power supplies typically provide approximately 5A of current, which is not capable of reliably powering the Pentium 4 processor based Intel® Desktop Board. And I think the motherboards going to look for a formatted hard drive wired to the motherboard It wont boot off that USB stick.
Sep 22, 2009 | Intel D945GCLF Motherboard
How i have dell desktop optiplex 755, which
go to c drive and look for folder called documents and settings inside you will find all the old users from your old windows. in each user file there are more folders one for documents,favorites,music,videos. copy the contents to your new document folder or make a new folder and put all the stuff in it.
Sep 01, 2009 | Dell Optiplex 755 Ultra Small Form Factor...
On/off switch
Usually the power on button only has two wires. Then you have HDD led leads, reset leads, power led leads etc. These are all separate wires that fit onto separate pins in the Jpanel1 (front panel header).
Could be that the really old emachines grouped all these wires and made them into a plug to fit their own style motherboards.
If this is the case then that connector would not be on your newer motherboard, and it would have that Jpanel1 instead.
Hope this helps as I'm not very familiar with the old emachines.
Hank
Jul 08, 2009 | Intel Desktop Board D815EFV (BOXD815EFVLU)...
Computer wont boot
Check if you hooked all the plugs from the power supply. There is a small one people tend to forget
Mar 07, 2009 | Intel Computers & Internet
Intel® Desktop Board D915GUX
Yes it seems ur RAM are faulty..try to change it...
Dec 11, 2008 | Computers & Internet
Intel Motherboard Logo
Top Intel Computers & Internet Experts
Tony
Alun Cox
David
David
Are you an Intel Computer and Internet Expert? Answer questions, earn points and help others
