Question about Gemini XL-100 Turntable
I'm missing the tonearm counterweight for a Gemini XL-100 turntable. Does anyone have one of these they are parting-out?
i'm too missing the tonearm counterweight for my Gemini TT01. if you haven't figuered out where to buy one, do you know at least what is the weight that is needed to counter the weight of the tonearm or how to measure the tonearm so as to make a counterweight of my own???
thank you in advance
Posted on Jul 16, 2010
Missing the counter weight on my Gemini PT 2100... Anyone know how to replace it and where to get the parts?
Well this website is showing the picture of it, but you will have to enquire if they are still selling it.
It will just slide on and a screw will tighten it up.
http://www.trusound.co.uk/P/409/Gemini+TWMT-3601604+Tonearm+Counterweight+
I can't find on the net anyone else selling parts for this model, still.
Aug 23, 2016 | Gemini Audio Players & Recorders
I have an Gemini XL-100 ( only the turntable itself) , and I am wondering what are the missing parts I need to make it work properly.
I don't understand what you mean. Are the electronics parts missing does it have a power supply or is it just the cartridge that's not there?
Aug 13, 2013 | Gemini XL-100 Turntable
Faulty power transformer
Hi, remove the old transformer and take it to your local electronics parts store. They will be able to supply a similar unit. Failing that search parts suppliers on the net. Cheers john. styluscity.com
Dec 04, 2011 | Gemini XL-100 Turntable
How do you adjust the tone arm on a Denon DP-47F turntable? Thanks Cosmicharlie
Basically, like almost any other turntable.
Look up the recommended tracking force for your cartridge/stylus.
Unplug the power to the turntable.
Using the tonearm elevation control, raise the tonearm.
Manually move the tonearm in toward the platter.
Manually rotate the platter ClockWise a few turns to disengage any cueing mechanisms.
Set the Tracking and Anti-skating controls to 0.
Disengage the tonearm elevation control. The tonearm will either float or drop. This is why we have no power, just in case it hits the platter.
Adjust the counterweight until the tonearm floats exactly horizontal. Use the flat portion of the tonarm rest as a gauge.
Return the tonearm to its rest.
Dial in the prescribed tracking force and anti-skating. Play records.
Register with http://www.vinylengine.com/ and find the manual here...
http://www.vinylengine.com/library/denon/dp-47f.shtml
Apr 14, 2011 | Denon DP-47F Turntable
I just set up my audio technica AT-PL120 for the first time, and I can't stop the tonearm from drifting back to the rest. I can't get the stylus to stay straight unless I add more on to the counterweight,...
KEEP THE ANTI SKATE AT 0 FOR NOW,then you need 2 balance the tonearm with the rear counterweight so it just hovers at around the height of the platter.now you need to zero the gauge on the rear counterweight being carefull not to turn the counterweight,then check again that the tonearm still hovers.then screw counterweight inwards untill the dial on counterweight reads between 1.5- 2 grams dependin on tracking weight of cartridge.then adjust antiskate 2 whatever u set the tracking weight to.i would also double check with a spirit level ur level surface
Oct 12, 2010 | Audio Technica AT-PL120 Turntable
Counterweight on my technics 1200 wont catch to screw on. Threads inside the weight look fine but there seems to be a small "bump" on the under back side of the tone arm. This "bump" doesnt stick out as...
It doesn't screw on, it pushes on....
"With the tonearm locked in place, put the anti‐skate
dial on "0" and push the counterweight onto the rear of
the tonearm. Make sure that the numbers face to the
front of the turntable. Turn the weight until you feel it
"click" into place.
Unlock the tonearm from the rest, and move it
toward the middle, about one inch from the edge of the
platter. Hold the arm off the surface with your right
hand on the finger lift. Begin turning the counterweight
one way or the other, until the arm seems to just
"float".
As seen in the picture, the arm, when properly
floating, will not face up nor down.. it will stay
with the platter. It may take a few tries to get
correct. Lock the tonearm back on it's rest.
Holding the rear, silver, section of the counterweight
with one hand, use your other hand to turn JUST the
number ring. It doesn't matter which direction you turn
it, but you will want "0" to face up when you are done.
Using just one hand, turn the entire counterweight
(the silver part) COUNTERCLOCKWISE until the
recommended tracking force is achieved. New
cartridges will tell what the ideal number is. As a rule of
thumb, however, most "hi‐fi" cartridges track between
1 and 2 grams, while most DJ cartridges track between
3 and 5 grams.
Set the anti‐skate dial to coincide with the tracking
force... in other words, if the tracking force is 2 grams,
set the anti‐skate dial to "2". The exception is for DJ's
who scratch and back‐cue. Your anti‐skate must be left
on "0". "
Feb 16, 2010 | Technics SL-1200MK2 Turntable
Missing clip
Parts for that turntable are nearly impossible to find. As far as I know, Pacific Parts is the only place that stocks these kind of parts.
Apr 07, 2009 | Audio Players & Recorders
Missing Parts
You need a headshell unit (which is needle etc for the front of arm)
also the felt pad.. also known as a slipmat, you can pick up at dj supplies shops or on ebay..
I need a counterweight myself as my ION turntable also had missing parts when I got it as a gift.
I found a headshell on ebay which is perfect...Turntable Cartridge and Headshell Black DJ DISCO USB on eBay (end time 08-Sep-09 00:11:01 BST)
I havent yet found a counterweight..I hope I will!
Hope this helps in some way..
Kate
Feb 26, 2009 | ION Audio iTTUSB Turntable
50Hz noise appears at the end of the disc
HAVE YOU GOT ANY OTHER EQUIPMENT CONNECTED IF SO DISCONNECT THEM THEN JUST USE THE AMP,DECK AND SPEAKERS AND MAKE SURE THERE IS NOTHING ELSE PLUGGED INTO THE SAME CONNECTING LINE
THEN ADD THE OTHER ITEMS ONE BY ONE
DEREK
Nov 16, 2008 | Philips gemini XL-500 II Turntable
Muffled sound
HELLO!
I don't think the problem is the actual stylus (needle), it sounds like the magnetic cartridge has become faulty in some way (it does happen). My advice is try another cartridge and stylus (borrow if you can). If the audio stays the same then it MAY be the wiring in the arm going through the plinth (deck) and these wires terminate to pins or a small pcb board in the turntable where the phono cables and arm wires are connected. There may be a bad connection inside.
Also, make sure your tonearm counterweight and anti-skate are set up properly as well as this can have an effect on audio.
I hope this helps as I have been into audio since I was a kid!
Apr 18, 2008 | Gemini PDT-6000 Turntable
Gemini XL-100 Turntable Logo
780 people viewed this question
Top Gemini Audio Players & Recorders Experts
 Grubhead
Grubhead
Vito Vacirca Jr.
Don Hart
Are you a Gemini Audio Player and Recorder Expert? Answer questions, earn points and help others
