Question about Refrigerators
Our rv refridgerator/freezer was turned on for the first time since we bought our rv and when the freezer was opened it had a terrible smell of amonia that about knocked me over. Is that smell free on or what do you think it was? And how do I fix the problem? If the previous owner cleaned with amonia would the smell stay in the freezer when I turned it on. One more question does the rv have to completely level for the fridge to work properly. It say so on the lable but how you keep it level when your driving.
  • lggrswife Mar 07, 2009
    Thank you for your help
  • 120 Answers
The unit is filled with amonia , and when you smell it that signals the begining of the end for the unit.No amonia no cooling.as far as level it must be level while parked but while going down the road this isnt a problem. Be prepared to replace the fridge or the cooling unit soon..
Posted on Aug 12, 2009
  • 700 Answers
Thats because yoiu have a amonia system thats why they say to keep it level to opoerate properly. the smell may be a leak from where someone punctured the evaporator.
Posted on Mar 07, 2009
How do I get rid of this terrible fishy smell from my freezer/refrigerator?
Hello Heather.
Have you had anything wrong with fridge that caused the smell.
Try charcoal in both fridge and freezer.
Hope it will help.
Fish smell is hard to get read off
May 21, 2015 | Kenmore Elite 22.4 cu. ft. Bottom Freezer...
What makes my RV refridgerator work on electricity and warm up 10 to 15 degrees on gas? Freezer warms up slightly, but only a couple of degrees.
look at the flame. Is it yellow on the tip of the flame? The air mixture might be off adjustment. RV refrigerators will always be cooler on electricity but not by 10-15 degrees.
Aug 20, 2014 | Refrigerators
Chemical smell coming freezer
You may check to see if you have a Freon leak.
Dec 23, 2013 | Refrigerators
Lhave a rm 2601 rv refrigerator and when I cut it on the freezer coil gets warm instead of cold.Also it is making a gurdling noise. when I open the door to refrigerator the it has a ammonia bad...
Shut it off and get it checked. Ammonia is dangerous as I am sure you are aware. Ammonia smell is an indication of a leaking cooling unit. Time for a new fridge. Sorry.
Oct 14, 2011 | Dometic Rooftop RV Air Conditioner
Stinky smell
the drains/vents need to be cleaned out with clorine bleach solution.(leave the doors open to dissipate the gas after)it is very common for the drain hose to get a black moss residue blocking it,and people pay a fortune for a callout to fix.lovely........
May 29, 2010 | Frigidaire FRS3R5EMB Side by Side...
Ice maker in refridgerator freezer won't make ice. It seems as if the water is going up into the freezer but no Ice is being produced. The ice tray has frozen ice in it, but it will not dump it in the ice...
Sometimes icemakers get all frozen up, such that the motor cannot turn to eject the ice. Also, in some cases the water supply line freezes up, although that does not sound like your problem.
Try leaving the freezer open to defrost it manually and see if it starts working by itself. Also, the icemaker motors can and do fail. In some cases you smell an acrid burning smell when the motor fails.
Oct 16, 2009 | Kenmore 50522 / 50524 Side by Side...
RV freezer cools, but fridge section doesn't
Sir, To solve this problem, you must open the compressor area at the back bottom of the refrigerator and chek the temperature of the pressure line. If the temperature is between 55celcius to 60 than its ok. Or else you need to change the refrigerant. I suggest you to contact the service authority.
Thanks for contacting Fixya.
Sep 09, 2009 | Thetford Norcold RV Cooler/Freezer
My Dometic trailer refridgerator is warm but freezer is freezing.
Brandi4723,
Unfortunately, you have a bad cooling unit in your refrigerator. Then ammonia smell means that you have a leak in the unit. TURN THE FRIDGE OFF!!! Do not use the fridge on AC or Gas until you have the cooling unit replaced or buy a new fridge. Depending on the model number and serial number of the fridge, it may be under recall by dometic and you might be able to have it repaired for free. If you will provide me with the model number, serial number and the serial number of the cooling unit (found on the outside of the unit in the fridge compartment, lower tank of cooling unit), I can then tell you the pricing of the repairs or whether it is under recall.
Again, TURN THE FRIDGE OFF and do not use it...RISK OF FIRE!!!!
Hope this helps,
Jeff
Jul 03, 2009 | Dometic RM2652 Refrigerator
Gassy smell in upright freezer
Is this a refrigerator in a household or an RV?
The reason I ask is that RV refrigerators use ammonia, which you can smell. If you read the article you probably read that Freon does not have an odor, in extreme cases you can smell burnt refrigeration oil when a system with a large leak has been left running, but by then the unit wouldn't be working.
If your refrigerator did in fact have a leak it wouldn’t be working, due to such a small amount of refrigerant present. ( typically about 5 ounces )
So, your gassy smell is likely from something else. I find this happens most often when potatoes or carrots are stored for long periods of time in the refrigerator, usually in the crispers. When starchy vegetables wilt ( get smaller with age ) they give off a gas. The smell eventually comes not from the starch, but from the bacteria that starts growing on it. All this happens on a microscopic level so you won't see anything. good luck
Dec 13, 2008 | Freezers
NOt keeping food cold
Good posibility that some thing is wrong with the defrost system. This is not as expensive to repair as a compressor. Is it worth it? The compressor and having it replaced and recharged will run much more than 250 a lot of the time or very close to it. Unplug it for a few hours with the freezer door open. Then plug it back in and see if it starts freezing again. This would tell you if it is something with the defrost cycle. The low motor noise may be the fan in the bottom of the unit. It would be good to know if the compressor is running or not.
Jan 28, 2008 | Kenmore 52642 / 52644 / 52649 Side by Side...
Refrigerators Logo
322 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
