Question about GE Profile Wizard DPSE592EAWW Electric Dryer
Replacing the felt seal on GE Dryer DHDSR46EE1WW
Not sure how it goes on as it came off before I took the panel off. Where would I find a HiTemperature adhesive and how does this seal go back on?
5 Suggested Answers
SOURCE: maytag performa dryer assistance
Hello, My name is Juan. I will need help to find the problem with some suggestions. My dryer won't start at all, even when I open the door the light bulb inside the drum did not turn on. I check the power source it is ok. Please help with alternatives for a solution. Maytag electric dryer Mod # PYET344AYW
Thanks,
Juan J.
Posted on Jun 17, 2008
SearsTechToo
  • 261 Answers
SOURCE: Replace felt seal on gas dryer door
Yuck, nothing like replacing the felt, removers will only give you brain damage.I would find something hard plastic to scrap it off to prevent scraping of the finish. Dont give up a burn it off, I know from experience. Try the red plastic scrapers from Ace Hardware, there cheap by a dozen just in case the person who installed the felt had a seizure with the glue!
Posted on Sep 16, 2008
SOURCE: front felt drum seal on ge came off---hard to repair?
No its not hard, just unplug first and then just take the front off and take note where the wires go to the door switch.,also check your drum to make sure you did not damage.
Posted on Nov 19, 2008
  • 686 Answers
SOURCE: need to replace the front felt seal - GE gas dryer
since you got the top opened, now look inside the front panel toward top remove screws or hex screws now you can remove the front panel. Undo the door switch wires before removing the front panel. The felt seal should be glued to the front panel aroun the opening to the drum you should be able to tell where it was.
Posted on Mar 02, 2009
SOURCE: replace the felt on a ge dryer part #we9m30?
You need to buy new felt. There is an upper and a lower piece. The upper piece has 3 glides to support the drum. When you buy the parts, make sure you have the dryer part number and there are some pictures that will help.
Make sure you uplug the dryer. Flip up the top lid of the dryer by sliding a large flat nose screw driver under the front corners of the top. Remove the front panel by taking out two phillips screws. Also remove the power cable to the front controls so you can completely remove the front panel. Strip off the old felt and clean the surface as good as you can. Glue on the felt (you should get a tube of glue with the new felt). Let is dry a bit before you put everything back together. It is a pretty easy job.
Posted on May 02, 2009
How do I get the front panel off a ge mod djsr473et6ww cloths dryer.
GE Dryer Repair - How to Take Apart, Open, or Disassemble ...
? 6:21
https://www.youtube.com/watch?v=AgsOwIwoygc
Feb 22, 2013 - Uploaded by canyonman1963
Tags: GE, General Electric, Frigidaire, Electrolux, electric, dryer, open, remove, take apart ...
Dryer Repair - Replacing the Lower Front Drum Felt Seal ...
? 9:42
https://www.youtube.com/watch?v=XoYP_YsGP68
Jun 7, 2011 - Uploaded by PartSelect
Dryer Repair - Replacing the Lower Front Drum Felt Seal (GE Part .... on this dryer....how do you remove the ...
Nov 03, 2015 | GE Dryers
DHDSr46ee1ww has new heating element and switch but will not start.
Have you checked the motor kill switch? Its located by the motor.When the belt comes off the idler pulley actuates this killing power to the machine. Sometimes the switch goes bad over time and needs to be changed. The part number is wd21x10261 and runs around $12
May 18, 2012 | Dryers
Im gettin 1/2 inch to 2 inch rust like streaks on my light clothing after drying. I took a wet white cloth and wiped them along the felt seals at the front and back of the dryer and got the same staining....
You are absolutely correct. Replacing the felt seals will definitely solve the problem and you have to look forward to replacing the same in another 4 years. The seals are sold as pair as you need to replace both but they are cheap and easy to replace. The only hard part is getting to the seals as you need to get the top and the front panels then the drum itself to get to the rear seal.
Aug 14, 2011 | Dryers
Replace the felt on a ge dryer part #we9m30?
Mar 13, 2009 | GE DBSR453EBWW Electric Dryer
Need to replace the front felt seal - GE gas dryer
Mar 01, 2009 | GE DVLR223 Dryers
Scratching noise coming from dryer
yes the felt is cushion and it sounds like it might be the blower fan sometimes they get off balance or just simply out off wack and the blades will rub on the housing
Feb 18, 2009 | GE DBXR463EBWW Electric Dryer
Front felt drum seal on ge came off---hard to repair?
Open the dryer door. At the top of the door opening, there should be two screws holding the top of the dryer down. Remove those screws and the top will rotate up, giving you access to the drum.
Nov 19, 2008 | GE DBXR463GB Gas Dryer
Frigidaire electric dryer; model # FDEB34RGS1
front drum seal needs replacing pop clips at front of dryer top ..lift top remove 1 secrew each side of front from the inside..remove wires lift panel off clips ckd front panel around door area for felt seal may also have embedded plastic drum glides a felt seal also goes around bottom half
May 05, 2008 | Frigidaire FGR341AC Electric Dryer
Felt tub seal
http://www.partselect.com/dryer+ge-open-cabinet+repair.htm
Here is a link that shows how to do this.
Feb 14, 2008 | GE DCCD330EDWC Dryer
GE Profile Wizard DPSE592EAWW Electric Dryer Logo
895 people viewed this question
Top GE Dryers Experts
John Tripp
John Tripp
Lawrence Oravetz
Are you a GE Dryer Expert? Answer questions, earn points and help others
