Question about IBM (49P1599) Motherboard
IBM Netvista MB 49p1599 Front Panel Pinout
I am looking for the front panel pinout for a Net Vista MB 49p1599.
I bought this on EBay and would like to install a generic case.
  • wwazman May 04, 2009
    same thing here. I have power and reset by trial and error, but the fp usb seems to be off a little. It'll bring up the power on my usb gamepad but not even sound a bell saying it sees it connect.
1 pw sw
2 pw sw
3 rst
4 rst
5 - pw led
6+ pw led
7+ hdd led
8 - hdd led
<== left 1. . . . . .8
ATX connector ==> right
Posted on Aug 14, 2009
  • Claudius Erwin Mulialim
    For More Details, then Please Visit the Link: "http://www.pcguide.com/vb/showthread.php?p=463556#post463556"
Hp e93839
~Somewhere, over the rainbow~
My understanding by a search on the internet, is that the HP XW4600, uses a version of an Intel X38 motherboard, and has the ID numbers - model fmb-0702 - on it, as well as - e93839 -
http://h30499.www3.hp.com/t5/Workstations-z-series-xw-series/XW4600-Motherboard-Control-Panel-Schematic/td-p/1007169
7th post down, - jondvd - 09-28-2008
http://www.ebay.com/itm/HP-XW4600-Motherboard-441449-001-441418-001-/360653087990?pt=Motherboards&hash=item53f89964f6
If this holds to be true, the BLUE header, below the CMOS battery, and close to the outside edge of the motherboard, is ONE USB header.
Indicates Internal.
The Yellow header to the right of it, is the Front Panel USB header.
EACH USB header has contact pins on it, for TWO USB ports.
Does not matter which USB header we are talking about here, on that motherboard.
To identify the pinout, look for the missing pin in the header.
This is the KEY pin.
http://www.motherboardpoint.com/front-usb-pinout-compaq-evo-d310-t153627.html
http://pinouts.ws/usb-pinout.html
Regards,
joecoolvette
May 14, 2013 | Computers & Internet
Need IBM motherboard 29R8260 front panel controls
John,
The front of your computer is the Front Panel.
The area of contact pins on the motherboard, that the main wires from the Front panel go to, is the Front Panel header.
What you need is a Front panel header pinout.
This I do not have. What I do have, is a simplistic method that may allow you to find out, what the pinout is.
http://www.ebay.com/itm/IBM-ThinkCentre-M51-29R8260-Socket-775-Motherboard-w-P4-3GHz-SL7PU-/390456414497?_trksid=p4340.m263&_trkparms=algo%3DSIC%26its%3DI%252BC%26itu%3DUCI%252BIA%252BUA%252BFICS%252BUFI%26otn%3D15%26pmod%3D260995444535%26ps%3D63%26clkid%3D1437936870868306373&_qi=RTM1062688
Looking at the Hardware Maintenance Manual for the ThinkCentre M51, (It also uses this mobo), the Front Panel header is to the right of the Ram Memory slots. (Processor to the left, Ram Memory slots at the Top)
Looking at the Ebay link, there are three views available. Click on the middle view. In the view photo the Front Panel header is the black rectangle below the Yellow ram memory slots.
Two rows of pins.
Power Supply plugged into power, use an LED light with two wires.
Go across the top row, and touch the first set of two pins next to each other.
No? Go on. Touch the next set of two pins. I'm willing to bet the third set of two pins is the Power On switch pins.
(Could be mistaken, however)
The contact made should be brief. The Power On switch is a Momentary Contact Switch.
Once the Power Supply comes on, wait a minute, then start testing the other pins.
LED light blinks? You have the HarDDrive activity LED pins.
LED light stays steady? You have the Power On LED pins.
Be aware however, that there may be 3 pins for the Power On LED.
Two Positive ( + ) pins, and one Negative ( - ) pin. This is for a dual color Power On LED. (Turbo mode/ Regular mode)
This would mean touching the first pin, or second pin, in the set of 3 pins, and the last pin in the set.
Computer restarts? You have the 2 pins for a Reset Switch.
(Do NOT touch the Power On switch pins again, or the computer may restart)
Not what I would like to state. Would like to state the exact pinout.
Perhaps if you get this figured out, you might take the time to post the pinout. Crude is fine, I can 'clean it up'. This way 100's to 1000's of people may be able to use your findings. Think how many people you would help.
Regards,
joecoolvette
Aug 19, 2012 | Computers & Internet
I'm looking for the pinout for the FRONT PANEL
DX-5150 Illustrated Parts Map Refer to Page-2 for Complete Motherboard Connections and Description
Actual Image of the Motherboard (Rotate it 90 Degree Clock-wise for a better view)
(The above illustration is at Page-2 of the Manual)
Please download the Manual and the Motherboard photo from the above links and make the Front Pannel Connections.
Hope it helps! Good Luck!
CreativeTECH
May 10, 2011 | HP Computers & Internet
Front panel
http://www-307.ibm.com/pc/support/site.wss/document.do?lndocid=MIGR-43033
for your specific model of the NETVISTA line of desktops.
Sep 16, 2009 | IBM (49P1599) Motherboard
I need a diagram that shows the pinout for front panel audio.
Could you be less specific as to what motherboard and front-panel, and why you couldn't download the manual from the maker if you pitched it out?
Then, to be sure, get a DVM with small probes, set it on continuity, and confirm the pinout.
Aug 24, 2009 | Computers & Internet
Power switch pinout for the 02R4087 motherboard Hi guys I have an old IBM motherboard IBM 02R4087 Netvista Motherboard which appears to be from a Netvista model (NetVista 8182, 8305, 8306, 8309, 8313 ). I...
Progerssed the internet and got a FREE note Free response. Did not have to spend money on your pathetic permium system. Why should you charge for what others give for free?? Parasites
Jul 09, 2009 | IBM (02R4087) Motherboard
I need to know front panel pinout values for IBM NetVista 49P15
THE VENDOR HAS THE PIN LAYOUT AND SOME OF THE PLACE WHERE YOU DO BUSINESS WILL HELP WITH GETTING YOU THE DIAGRAM PAPER WORK.
ROD
Feb 16, 2009 | IBM (33P0825) Motherboard
Front panel Pinout
the pins are usually labeld on the board itself or in the board manual
May 22, 2008 | IBM NetVista PC Desktop
Computers & Internet Logo
3,579 people viewed this question
Top IBM Computers & Internet Experts
Alun Cox
Are you an IBM Computer and Internet Expert? Answer questions, earn points and help others
