Question about Aiwa Audio Players & Recorders
Have a AWA Compact Disc Stereo System. While playing any CD it intermittent stops playing the CD. After a few seconds it comes back on and continues exactly where it left off. I've used a CD cleaner (disc) and it did not solve the problem. Sue
  • suehubb Mar 07, 2009
    Are there instructions for cleaning the lens?
    If not, what should I use to clean the lens?
    And, how do I open it up to get to the lens?
    I still have a question concerning the answer I was given.
    Have to figure out how to open the unit and what solution do I use to clean the lens?
    Thanks.
    suehubb@forumrsa.com
    Sergeant:
    Novelist:
  • 277 Answers
Its the lens problem.nothing can be done in this case.just the lens needs cleaning internally manually by opening the unit.if that does not helps then lens replacement as the lens reading capacity has gone weak.it has to be replaced.
Posted on Mar 07, 2009
  • top class Mar 07, 2009
    as normal lens cleaning cds are available in maket with the solution.you just have to spray the given solution on the cd and insert the cd in the unit.and play it.after a minute it will automatically come out.if the lrens gets cleaned the other cd will work.but if the lens is weak then it needs replacement *** the cleaning will not solve.
  • Aiwa Master
  • 19,396 Answers
You need to take the unit apart to clean the lens directly with a cotton stick and isopropyl alcohol, check also cd spinner grip.
Can't get cd to repeat
Press the 'play mode' button 3x, then press the CD play/.pause button.
Mar 19, 2014 | Sharp CD-DH950 5-Disc Compact Stereo...
CD stops at any title track but won't play
With all the problems you are having you would be further ahead replacing the compact stereo system.
Jul 23, 2012 | Audio Players & Recorders
I have a memorex stereo, turntable, 3 cd changer etc. The standby light comes on but no sound, it is only 2 yrs old..
Sometimes you have to unplug it for about 30 seconds, then when you plug it in press the power on button. If there is still no sound, check the speaker connections on the back they sometimes come loose.
Oct 17, 2009 | Electro Brand Nostalgic Stereo CD Music...
Mazda 6 Stereo Problems
is it a factory unit you have in the vehicle
Aug 07, 2009 | 2004 Mazda 6
CD's won't play on AIWA Compact Disc Stereo System
I have a Aiwa Compact 3 Disc Stereo Systen that will pick up the 1st CD, spin it for about 5 seconds, lower it and then go to 2, same thing, on to 3 and same thing. Please help.
Oct 30, 2008 | Audio Players & Recorders
I have a sa-gx770 techniques stereo reciever, have had it for many years. But the problem with it is, once you start playing music ( a CD) periodically it will shut off through out the song, and never...
There are bad solder connections inside the receiver that are causing the protection circuit to kick in. This is a simple resoldering job and should only cost the labor rate at a local service shop.
Dan
Jun 02, 2008 | Technics Audio Players & Recorders
My Technics SL-DV290 stereo has stopped playing dvd/cds, it just says 'no read' when it initially scans dvd/cd prior to play Please help!
This means that the unit can tell that a disc is present, but can not read it. Try opening up the top and cleaning the lens using a cotton swab and alcohol. Let us know if that resolves the problem.
Thanks,
Dan
Apr 02, 2008 | Audio Players & Recorders
Shelf stereo turns off by itself and stops working all together.
how loud u cranking it? cause i've tested my stereo to its max...and it suddenly dies...reason: its juss like a small scale car stereo system...the built in AMP cant handle the out-put..
Feb 04, 2008 | Philips FW930R Shelf System
Console will not read disc.
I had that same problem, Just purchase a cd lens cleaner and it worked.
Jan 04, 2008 | Sony PlayStation 2 (PS2) Compact System...
29 people viewed this question
Top Aiwa Audio Players & Recorders Experts
 Grubhead
Grubhead
Electro Med Services...
Are you an Aiwa Audio Player and Recorder Expert? Answer questions, earn points and help others
