Question about Frigidaire FGF316 Gas Kitchen Range
Erratic/slow heating I have a frigidaire gas stove model fgf326asd that is very erratic in heating.....The temp will go up fine and then will drop sometimes to 250 and then climb back up again.....It seems to take a long time to fire at first and sometimes won't even get abobe 200-300.....If I set the temp at 500 it will usually heat up but it takes a long time....any help would be appreciated
  • 1 more comment
  • kahsha02 Mar 07, 2009
    I'm not sure the ignitor is the problem because I have watched and it glows brightly and is very consistent all the time
    Thanks......That makes sense to me and sounds like it will take care of the problem....Thanks again
  • jsheinz May 17, 2009
    I am having this same problem. fgf326asd Ignitor coil is red hot, ove turns on to 350 or so and then turns off..Coil stays on. What part needs to be replaced?
    President:
  • Frigidaire Master
  • 2,651 Answers
Sounds like an issue withthte ignitor in the oven cavity, part number 5303935066, easy to install comes with instuctions, be careful however teh parts pretty fragile
Posted on Mar 07, 2009
  • Ron Coons
    Ron Coons Mar 07, 2009
    I see this problem quite often, although oyou see it "glowing" its not glowing strong enough( pulling enough amps) to open thesafety valve and releas the gas. indicator(s) of this are,, too long to ignite( gas should ignite within 40-60 seconds after unit is turned on). inconsistant cooking times, as nwellas not being albe to maintain even temp if'when it ever does achieve desired temp, reason forthis is finally after struggling to get o 350 theunit shuts off ( too aintain temp) then when its time to relight its struggles to relight causing loss of temp in oven cavity.. I truely belive that this is your issue, the only other thing affecting oven temp is your thermostat itself, in which case only determines the temp and if this was issue your ove n would merely be off by a certain degree but consistantly off by that same temp no fluctuations..good luck!
My pc goes erratic when the ac temp drops to 22-23 degree Celsius. not as responsive when 1/ surfing the net, 2/ playing music via WMP, 3/ slow at loading of web page my system configuration is P4 (478...
Possible that there is some condensation within when the temperature drops down. When the set is powered or in action the heat is build up inside to keep the set working fine.
So it will be good to have the inside cleaned.heat up to dispere any moisture using a hair dryer.
make sure the air circulation is good but not taking in any moisture .
Oct 27, 2010 | Computers & Internet
I have a frigidaire gas stove model #FGF337AWJ.
I went through that once and believe it or not it was the ignitor. Instead of a thermocouple these new ovens use the amount of current going through the ignitor to prove the flame. Seems like after it gets ot a certain temperature the amps drop off enough to cut out the flame and then it will try to recycle. If it is not that it would be the thermostat but they very seldom go bad. I would reolace the ignitor first I think it will solve your problem.
Nov 14, 2009 | Frigidaire FGF337BC Gas Kitchen Range
Hi, It sounds like you need to change the on=ven ignitor. Even tho it glows, it is weak and will not open the gas valve consistantly. It is a very common problem. Please let me know if I can assist you with part# or how to replace the part.
Thanks
Vic
May 17, 2009 | Frigidaire FGF326AS Gas Kitchen Range
Temperature drop on freezer
Sounds like the thermostat is erratic.
Apr 20, 2009 | Frigidaire 14.1 cu. ft. Upright Freezer...
97 Grand Marquis Erratic Temp
Sounds like the thermostat may be sticking,Or the temp sensor is going out.Both very inexpensive.
Jan 10, 2009 | 1997 Mercury Grand Marquis
Service code EC?
CODE INDICATION
05 Refrig. Cabinet Thermistor read open or shorted for 10+ seconds, or repeatedly read erratic temp’s
06 Refrig. Evaporator Thermistor read open or shorted for 10+ seconds, or repeatedly read erratic temp’s
07 Freezer Cabinet Thermistor read open or shorted for 10+ seconds, or repeatedly read erratic temp’s
08 Freezer Evaporator Thermistor read open or shorted for 10+ seconds, or repeatedly read erratic temp’s
20 Defrost Under-heat with No Voltage Feedback Through Gray/White Wire at Defrost Start
21 Defrost Overheat
22 No Voltage Feedback Through Gray/White Wire at Defrost Start
23 Defrost Overheat with No Voltage Feedback through Gray/White Wire at Defrost Start
24 Defrost Under-heat
30 Excessive Icemaker Water Valve Solenoid Activation (Exceeded 15 Seconds)
40 Excessive Freezer Compressor Run
50 Excessive Refrigerator Compressor Run
Jan 21, 2008 | Sub-Zero 632 / S
Slow heating and control panel clicking
I have a similar problem with my Frigidaire FAM156R1A Air conditioner. The unit is stuck on a temp setting and occasionally makes a beeping sound. Repair tech came out and told me the control panel was broken and that this is a common problem. I wrote more detail here: http://www.epinions.com/content_404700761732
Sep 23, 2007 | Frigidaire PLCF489AC Dual Fuel (Electric...
Frigidaire FGF316 Gas Kitchen Range Logo
335 people viewed this question
Top Frigidaire Kitchen Ranges Experts
Dan Webster
Dan Webster
Ismael Rodriguez...
Paul Carew
Are you a Frigidaire Kitchen Range Expert? Answer questions, earn points and help others
