Need to know how to hook up air handler wiring .
  • superiorserv Mar 07, 2009
    The info was helpful but the problem is i have a brown wire coming out of air handler and a gray, red and white wire. They do not all color match . Could you please help me
  • 700 Answers
R to red for the power to the tstat. g to green for the fan to operate. w to white for the heat to come on. y to yellow that is for cooling. common to the outdoor unit with y to pwer up the condenser.
Posted on Mar 07, 2009
  • 3 more comments
  • Todd Born
    Todd Born Mar 07, 2009
    r to red for the power to the tstat. g to green for the fan to operate. w to white for the heat to come on. y to yellow that is for cooling. common to the outdoor unit with y to pwer up the condenser.
  • Todd Born
    brn is commen grey is the faN AND AND THER REST YOU KNOW DUDE
  • Todd Born
  • Todd Born
    ONLY HELPFUL?
  • Todd Born
    Todd Born Mar 28, 2009
    the gray one is for g or the fan, the brown one is for the common wire for the condenser
On a good man air handler aruf61d14aa model we have trouble with low voltage wiring. Already blew one fuse so thinking I have wired it wrong.
Red is power green (or in a goodman might be grey) lands on g which is for your indoor blower white is for heat. Yellow from the tstat( which doesn't land in the air handler ) is for cooling and goes out to the condenser along with the blue which is common. First unhook all your tstat wires. Put red and green together to turn on blower. Turn power on and make sure it's good. Then add white for heat, turn power on and make sure you're good. This will ensure YOUR PROBLEM IS OUTSIDE the air handler. Then ONE WIRE AT A TIME add back your tstat wire, turning power off and on after each wire. First do red. Then do green then do white then do yellow. TURNING POWER OFF EACH TIME. IF AND WHEN THE FUSE BLOWS you will know what part actually blows the fuse. Let me know. It's possible your contactor outside is shorted and blowing the fuse. This will blow the fuse only when you hook the yellow from the tstat up to the wire going outside to condenser. Remember to unhook everything first. Let me know if you need more help.
Jul 30, 2017 | Heating & Cooling
Howto hook up th8320R1003 to heat pump
Byron, unless you have thoroughly familiarized yourself with the terminal designations on all three components, t-stat, air handler and heat pump you shouldn't attempt connection of the control. There are many variations of what will work and many more variations of what will NOT work.
No mention of outdoor sensors, so fine tuning of the electric heating stages to match the heat loss of your house (for most efficient operation) doesn't sound possible.
I know, this answer didn't help but there is no simple answer without having all the components in hand.
Mar 05, 2015 | Honeywell TH8320R1003 VisionPRO 8000 w/...
Hi I have a hb2400vd2m20 air handler and need to know what wires are needed to hook up to my thermostat its a Honeywell, as of the moment there is no heat pump it just the air handler running. I know there...
Honeywell 5000, 8000, 8000 iaq, prestige, round dial analog, digital Honeywell redlink. 1 heat 1 cool thermostat 3 heat 2 cool thermostat. does the stat u have do conventional a/c and heat pump. red wire is hot wire 24 volts not heating its your 24 volt control power. this will be r on your board and t-stat and red wire. y is for cooling mode and is yellow and will be noted y on both board and t stat. green is fan on the indoor furnace and will be g on board and t-stat and the wire is green. blue is the common side of the transformer labeled b on both board and t-stat. I did not see brown on your schematic I looked up I seen orange which is your reversing valve wire for the heat pump whether its calling for cooling or heat this is what changes the flow of Freon to make it to the indoor coil as warm Freon or cold when called for in heat or cool. the thermostat if a vision pro 8000 needs to be programmed in the installer mode which if this is the t-stat u have u need to read through the heat pump section. the green hooked to the orange doesn't look right on the print but that's the breakdown. http://www.manualslib.com/manual/277678/Haier-Hb2400vd2m20.html?page=11#manual heres your schematic
Oct 20, 2013 | Haier 2.0 Ton Multi-position Air Handler...
HE heat pump won't talk with old air handler?
The fact is, the air handler supplies the voltage, blower, and electric heat. In order for the heat pump to work correctly, the wiring from the thermostat and heat pump need to be hooked up right to the air handler. The thermostat is what tells which component to come on. If the fan stops, but the condenser keeps going, you either have a faulty fan relay on the air handler, faulty thermostat or wiring, faulty wiring at the heat pump, or the contacts on the new unit are sticking, which is highly doubtful considering it is working now. I hope I have helped you understand this a little more. Good luck and don't let them push you around, get someone that knows what they are looking at.
Jul 18, 2012 | Goodman Heating & Cooling
WIRING THE THERMOSTAT TO AC UNIT THEN FROM THE UNIT TO HANDLER
Generally, you would go from the thermostat to the air handler, and then, from the air handler to the outdoor unit. I don't know if you have a heat pump or not, so I will give you a simple diagram and you can contact me if you need more.
Thermostat : Y G R W and sometimes C
Air handler: Y G R W and C
Outdoor unit: two wires connecting to the contactor ( not heat pump)
Thermostat; Y--------------Y(air handler cooling)------------------one side of contactor, outdoor unit
G-------------G (air handler, fan)
R--------------R (air handler ,hot)
W-------------W (air handler, heat)
C--------------C (air handler, common)------------other side of contactor, outdoor unit
This is a typical wiring diagram. Just contact me if you have something different. Hope this helps. Stay cool. mark
Jul 10, 2011 | Heating & Cooling
I would like to know how to wire honeywell dt90e thermostat which wires where i have 5 wires from wall
It helps to know which wires went to the terminals on the old thermostat, if it had one. Otherwise, you would really need to know how they are hooked up inside the furnace/air handler. Some technicians hook them up differently, but I can give you the basics and most commonly used wires. R terminal- red/power wire G terminal- green/ fan wire Y terminal- yellow/ cooling or condenser wire W terminal- white/ heating wire C terminal- blue/black/ common or ground wire If you have a rc/rh terminal, they are usually jumpered with a small wire and your power wire still hooks to that. Hope this helps and good luck!
Jun 25, 2011 | Honeywell Heat/Cool Thermostat
Putting a mod#rth7500d1007 50033225-001 rev-a the wire inside house is only one wire outside has two four wire hook up do we need to chain to one wire only how maney wire do we need to hook up unit right
HI; A heat pump requires an 8 conductor wire for control low voltage wiring...Thats from the condensor to the air handler and from the t stat to the air handler...
Jan 18, 2010 | Carrier 38CKC042 Air Conditioner
My air handler fan will not come on during heating but will operate during cooling - Anerican Standard unit TWEO65E13FBO
Please check the thermostta first. Take the thermostat to the air handler and hook up on a short thermostat leash. The unit should work properly, then its for sure that the problem is going to be in your thermostat wiring. If problem persists then we are troubleshooting a thermostat.
Let us know if you need further assistance.
Thanks for contacting Fixya.com
Jan 12, 2010 | Heating & Cooling
Hi, I have an air handler motor made by GE Commercial motors. I think the motor number is N656 S. It's a 1/2 HP, 1075 rpm motor to replace my existing air handler motor. I want to install it in my air...
THERE SHOULD BE OR THE MOTOR SHOULD HAVE COME WITH A SCHAMTIC SOME TIMES THE PURPLE WIRE IS FOR A CAPACITOR TO HELP START THE MOTOR OR COULD BE A TWO SPEED MOTOR. THE NOTOR SHOULD TELL YOU THIS
Sep 05, 2009 | GE Heating & Cooling
Heating & Cooling Logo
136 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
