Question about Radio Shack Pro-95 Handheld Scanner
The frequencies on my scanner are not coming in
The frequencies were programmed to my scanner but now all I get is the weather channel
  • 120 Answers
While the weather channel is coming in hi LO (lockout) so that if its programmed into a regular scanning memory it will skip. If that dont work look for a lock button or keyboard lock and press that then scan.
Posted on Mar 07, 2009
Grecom psr-200 .when scanning weather chanel comes in .what is problim.
IF you have a weather frequency programmed in as a scanning channel, it will stop on it everytime, so you need to go to 'manual' on the weather channel, and press 'lock-out' so that it isn't on during scanning. You can still manually go to that channel, but it won't stop while scanning that way. Good luck.
Nov 17, 2012 | Grecom PSR-200 Desktop receiver, analog
My uniden bearcat 50 channel 800mhz stop the police,fire ect.. and only gives me weather.. why? can you help ?
  • You can try pressing "Manual" and then "Scan" or "Band" buttons from the weather setting to get you back to scanning the police, fire,etc.
  • Make sure you don't have a WX (Weather) frequency programmed into on of the regular 50 channels or the scanner will continue to stop every time around as it will pick up the WX frequency.
  • Make sure you have your scanner programmed as well.
Regards, Tony
May 27, 2011 | Uniden BC80XLT Handheld Scanner
MY RADIOSHACK NASCAR PRO-84 SCANS THREW CHANNELS BUT STAYS STUCK ON ONE CERTAIN WEATHER CHANNEL AND WONT CONTINUE SCANNING AND I NEED TO NO HOW TO DELETE THAT CHANNEL COMPLETELY.
The NOAA weather frequencies have constant broadcasts, so your scanner "locks" onto them. The only ways to prevent this are to either delete the weather frequency or lock it out. To delete, just program the frequency "0.0" (zero point zero) into the channel. To lock it out, press the L/O key while on the weather freq.
Bill B
Aug 06, 2010 | Radio Shack Pro-84 Handheld Scanner
My pro-82 scanner scans threw all channels but will not pick up any frequencies?
To verify that the scanner is working properly, program one or more of the weather frequencies(162.4, 162.425, 162.45, 162,475, 162.5, 162.525, 162.55, 161.65, 161.775, 163.275) into memory and then scan. NOTE: Not all frequencies are in use in all areas, so you may need to try several. If you receive the weather broadcasts, then you may need to adjust the squelch setting on your scanner to receive local signals. You also need to verify that the frequencies programmed into the scanner are valid, active frequencies in your area. For a comprehensive database of active frequencies in your area, and a lot of other useful scanning information, visit:
www.RadioReference.com
If the scanner fails to receive the weather broadcasts, you need to check the antenna connections inside the unit and/or have the scanner checked/repaired by a qualified technician.
Bill B
Jul 08, 2010 | Radio Shack Pro-82 Scanner
I need to reprogram my Realistic Pro-2023 police scanner. I do not have my local police codes nor do I know how to reprogram it. Help.
PROGRAMMING YOUR SCANNER
For a a comprehensive database of active frequencies in your area, visit:
1. Turn on your scanner by turning VOLUME clockwise.
2. Press [MANUAL], enter the channel number you want to program, then
press [MANUAL] and [PROGRAM]. The channel number flashes to indicate
you are programming the channel.
3. Enter a frequency.
4. Press [ENTER] to store the frequency. If you make a mistake in Step
3, ERROR appears on the display. Proceed again from Step 3.
5. If you want your scanner to pause after each transmission before
scanning to the next channel, press [DELAY] so that DELAY appears in
the display. See "Using the Delay Feature."
6. To program more channels, repeat Steps 2-4. If you want to program
the next channel in sequence, simply press [PROGRAM] and repeat Steps
3 - 4.
SETTING THE VOLUME AND SQUELCH CONTROLS
Use the SQUELCH control to decrease your scanner's sensitivity to weak
signals. This allows the scanner to receive only the strongest
transmissions.
1. Turn the SQUELCH and VOLUME controls fully counterclockwise.
2. Turn the VOLUME control clockwise until you hear a hissing sound.
3. Slowly turn the SQUELCH control clockwise until the hissing sound
stops.
SCANNING THE CHANNELS
To begin scanning the channels, press [SCAN]. Your scanner scans through
all the channels except the ones you have locked out. Be sure to read the
following sections to get the full benefit from your scanner's special
features.
USING THE DELAY FEATURE
Many agencies use a two-way radio system that might have a 2 second silence
(or more) between a query and a reply. To keep from missing a reply,
program a delay on the channels you identify as operating this way.
To program a delay, select the channel and press [DELAY] so that DELAY
appears on the display. Now when your scanner pauses at an active channel
when scanning, it waits for 2 seconds after the completion of each
transmission on that channel before it resumes scanning.
If you do not want your scanner to pause, select the channel and be sure
that DELAY is not on the display. If DELAY appears on the display, press
[DELAY] to turn it off for that channel.
LOCKING OUT CHANNELS
You can make your scanner scan more efficiently by locking out channels
that you have not programmed. Manually select the channel and press [LOCK
OUT] so that LOCK OUT apperas on the display. This is also handy for
locking out channels that have a continuous transmission. You can still
manually select locked-out channels for listening.
To unlock a channel you have locked, manually select the channel and press
[LOCK OUT] so that LOCK OUT disappears from the display.
NOTE: You cannot lock out Channel 1.
USING THE PRIORITY FEATURE
Channel 1 is designated as your scanner's priority channel. You can turn
on the priority feature so that you do not miss transmissions on Channel 1,
even if you are monitoring another channel.
Press [PRIORITY] so that PRIORITY appears on the display. Now your scanner
checks Channel 1 every 2 seconds, and stays on the channel if there is any
activity.
MANUALLY SELECTING A CHANNEL
You can continuously monitor a specific channel without scanning. This is
useful if you hear an emergency broadcast on a channel and do not want to
miss any details-even though there might be periods of silence-or if you
want to monitor a specific channel.
Follow these steps to manually select a channel.
1. Press MANUAL.
2. Enter the channel number.
3. Press MANUAL again.
Or, if your scanner is scanning and stops at the desired channel, press
MANUAL one time. (Pressing MANUAL additional times causes your scanner
to step through the channels.)
LISTENING TO THE WEATHER BAND
The FCC (Federal Communications Commission) has allocated several channels
for use by the National Oceanic and Atmospheric Administration (NOAA). We
have preprogrammed your scanner with all of the frequencies available to
NOAA. To hear your local forecast and regional weather information, simply
press [WX]. Your scanner begins scanning through the weather band, and WX
SEARCH appears on the display.
Your scanner should stop within a few seconds, and you hear the local
weather broadcast. If the broadcast is weak, you can press [WX] again
to scan through the rest of the weather band.
Bill B
Feb 21, 2010 | Radio Communications
How do you program a bearcat bc55xlrt scanner with a code?
There are no codes, only frequencies. For a comprehensive database of active frequencies in your area, visit:
To program your BC55XLT:
Turn on radio.
It will be in scan mode. Press Manual (orange button) to stop scanning.
Press Manual button to step through channels to get to the one you want.
(Or press channel number and then manual button)
If "LockOut" is displayed it means this channel isn't being "Scanned."
You will want to lock out constant "broadcast" services such as NOAA or airport weather. Pressing Lockout will toggle the feature on and off.
Select a channel to program. Use the keypad to enter frequency. Use "E" for Enter
key. If the radio displays an E this means Error. Usually, the
frequency you typed in is outside of the capabilities of the scanner.
Once you hit the E you will immediately start hearing anything that's
out there on the frequency you entered.
Push the "Review" button and the scanner will display the frequency
that is programmed for the channel. A "-" will be displayed for the
decimal point.
Jan 12, 2010 | Radio Communications
BC370CRS Scanner will not work
Are you certain that the frequencies you programmed are active in your area? Does the scanner work on the weather band, service search, or AM/FM?
Dec 31, 2009 | Uniden BC370CRS Base Scanner
Need to unlock our radioshack pro 2018 200 channel desktop scanner
Easy to use right out of the box!
Explore preset frequencies used for non-trunked police/fire, aircraft, marine, NOAA weather and more. Just attach the antenna, switch it on and touch one of five buttons. With just two keystrokes, you can store a frequency you find in the 200-channel memory for later scanning or monitoring. You can also search for activity in frequency ranges you specify or program known "action" frequencies on the keyboard.
  • 1-touch search lets you find police/fire, HAM radio, marine and 7 NOAA WX frequencies fast
  • Built-in weather receiver sounds an alarm when your NOAA weather station sends an alert
  • 50-frequency search skip locks out undesired frequencies
  • Programmable by computer (requires Scanner PC Programming Kit #20-048)
Aug 06, 2008 | Computers & Internet
Programming the BC244CLT
Hi, If I'm reading correctly, that scanner is listed as a 30 channel scanner only. You can pick freq's from 10 different bands. Here's just some of the features listed, hope this answered your question.
Mechanic
FEATURES:
  • Clock/Alarm - Large backlit LCD displays time and features "any button" snooze.
  • 30 Channels - You can program each of these memory channels to store one frequency.
  • 10 Bands - Including all public service bands, 4 "HAM" bands, federal and military land mobile bands.
  • Weather Scan - Automatically scans all national weather service frequencies.
Jan 17, 2008 | Uniden BC244CLT Base Scanner
Radio Shack Pro-95 Handheld Scanner Logo
101 people viewed this question
Top Radio Shack Radio Communications Experts
John
John
Greg Cann
Greg Cann
Jason
Are you a Radio Shack Radio Communication Expert? Answer questions, earn points and help others
