Question about GE (PSS26MSRSS) Side by Side Refrigerator
Clicking noise in back freezer stopped working when i turn the dial to 0 clicking noise stops
  • Al D Mar 10, 2009
    whats a 3 and 1?
  • Anonymous Mar 28, 2009
    clicking, fan stops
  • 700 Answers
Sound like the start components are going on the nit. you will neede a three and one to make it work properly again.
Posted on Mar 07, 2009
  • Todd Born
    Todd Born Mar 26, 2009
    a 3-1 is a start componenet that replaces the parts that start up your compressotr. avaoilable at appliuance stores near you.
I have a small magic chef fridge that just stopped working. Can seem to get the motor going at all - if just defrosted by itself. Inside is a dial and a red button - we've clicked that a few times to try...
Many times a freezer and/or refrigeratordo not work right because of a dirty condenser coil...there are also many otherthings that can go wrong. If you are hearing a clicking or buzzing thencheck out the last two tips.
If your refrigerator is running but warm, then...
Check out these tips that I wrote about that... it is a great place to starttrouble shooting your unit...and something that you can do rather then callinga repair person to do a simple thing for you...
Refrigerator Condenser Coil Cleaning Refrigerator Repair
Refrigerator Troubleshooting Refrigerator Compressor
Refrigerator Compressor Start Capacitor and Start Relay
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Apr 03, 2011 | Magic Chef MCBR445S1 Stainless Steel...
GBS20HBSBWW BOTTOM FREEZER, MAKING LOUD NOISE WHEN I TURN THE ADJUST KNOB IN THE REFRIGERATOR TOP TO 0 THE NOISE STOPS.
It sounds like your fan is hitting something. Usually there will be an ice block or something in the freezer pushed in on the back and cased the fan or wire to move ect... I hope this helps
Aug 11, 2010 | GE GBS18HBR Bottom Freezer Refrigerator
GE bottom freezer began making a clicking noise, will not run
The clicking could be the start relay.If the start relay is bad, the compressor will not start and you will hear a clicking noise in 2-5 minute intervals. The clicking noise is the overload cutting the compressor off when it overheats from trying to start with a bad start relay. To find out if this is bad first unplug the refrigerator. Remove the lower cover from your refrigerator. Then take the cover off that is on the side of the compressor,you will see wires going to this. Now you should be able to see the start relay plugged on to the side of the compressor and unplug it. Now the best way to tell if it’s bad is to shake it. If it rattles, it’s bad and needs to be replaced. If not, most of the time it’s ok. But rather than saying the compressors bad, you might want to replace it anyways because it don’t cost much in most cases (less than $25). If you replace it and it doesn’t work then the compressor is bad and you’ll need you call a repairman. (Note that compressors are very costly and are normally not worth fixing). You can also enter your model # at www.appliancehelponline.com for diagrams and illustrations.
Apr 09, 2010 | GE GDS20SBS Stainless Steel Bottom Freezer...
The unit stopped dispensing water, makes clicking nose
If you would like to do this yourself and save the fee of a service tech I ill tell you the motherboard and compressor start components have been affected. Just replacing the board is not always the answer. These refrigerators are sensitive to electrical surge, fan failure, compressor start component failure and eliminating the cause is the best and less expensive way to approach this, I will return later and discuss parts and I do need you to confirm your model is the GSH25JFR, Thanks, Sea Breeze
Feb 08, 2010 | GE GSH25JFR Side by Side Refrigerator
Maytag refrigerator clicking noise and stopped working
either inside fan out of alignment or defrost timer could be bad
Jun 02, 2009 | Maytag MSD2756G Side by Side Refrigerator
Freezer stops freezing
How long has this happened and when did it begin. Your refrigerator has a control board located on the back inside a panel. You may need to unplug and look for burns on that board. Let me know for sure that the model is HSM25GFTSA
Thanks, Sea Breeze
Mar 22, 2009 | GE HSM25GFTSA Side by Side Refrigerator
the clicking noise is from thermal overlaod protection, this happens when the supply voltage is less than the rated voltatge or if there is any mechanical problem the compressor.
Mar 10, 2009 | GE Refrigerators
Frigidaire Chest 5 cu ft Making Fan noise & will not turn on...6 yrs old.
at 6 years old it certainly aint new!
from what you describe, sounds like a compressor fault
Oct 09, 2008 | Frigidaire 13.7 cu. ft. / 388 liter...
My westinghouse freestyle freezer model number FJ3830-L*13 stops working now and then. On the back down the bottom left corner is a box. On this box is a small dial I turned this 1 click and the freezer...
hi i have a fj383, red light comes on and the fan doesnt circulate the cold air, only the bottom half stays cold, have tested the fan and does work, have put a new defrost timer in but no different, what activates the fan ? is it the timer or the t/stat or the element, hope you can help, thanks wayne.
Mar 15, 2008 | Refrigerators
GE (PSS26MSRSS) Side by Side Refrigerator Logo
168 people viewed this question
Top Refrigerators Experts
Gere knutson
KJ4QOB
Da Doc
