Question about Sharp EL-520WBBK Calculator
How do I convert a decimal answer to a fraction
When I do Trig I have a numerical decimal form as an answer.How to I transpose it to a fraction.
  • Anonymous Mar 27, 2014
    In the fraction 5/9 which numeral is the numerator please help me
Enter in the equation, or what you need to solve. Press the equals button, and if your answer appears as a decimal, hit the button above the number '8'. It says something like 'a b/c'. Your number should now appear in fraction form. To get it as an improper fraction, simply hit the '2ndF' button and then hit the 'a b/c' button again.
Enjoy :)
Posted on Apr 05, 2012
I don't no
Posted on Mar 07, 2009
How do you convert an answer in the form of a decimal into a fraction?
The TI-83 can only convert a decimal to a fraction if the denominator has no more than three digits.
Try . 5 MATH FRAC
Does that give you 1/2?
Sep 17, 2012 | Texas Instruments TI-83 Plus Calculator
Error when converting complex numbers to fraction form With mode in a+bi form, when dividing two complex numbers, the answer is displayed in decimal form. The old operating system would allow the decimals...
Not quite true for OS 2.56 MP for the TINspire with Ti84 keyboard. To convert a complex decimal value, that you just calculated, into a fraction use the command Math [1:>Frac] and it will convert the value to complex fractions
See below.
Oct 27, 2011 | Texas Instruments TI-84 Plus Silver...
0.056-0.1 answer in decimal form
If the calculator give you an answer in fractional or symbolic form, you can convert it to numerical form by pressing diamond then ENTER.
To have all answers come out in numerical form, press MODE F2 then down-arrow to the "Exact/Approx" line, right-arrow, select either AUTO or APPROXIMATE, then press ENTER twice.
Sep 21, 2011 | Texas Instruments TI-89 Calculator
How do i get out of fraction form? -Whenever i try to do division, the answer is always in fraction form and i want it in decimal form
To convert a single value from fraction to decimal, press SD. To have all results come out in decimal, press SHIFT MODE 2 to select LineIO mode.
Sep 15, 2010 | Casio FX-115ES Scientific Calculator
I can't get the answer to display in decimals only fractions.
For converting answers in decimal to fraction or fraction to decimal there is a S<->D key above delete key.If the answers is in fractional form press this key and it will be converted to decimal form.
Jun 04, 2010 | Casio FX-115ES Scientific Calculator
I can't find this button on my calculator / this
A fraction is in fact a ratio of two number: a division of a numerator by a denominator. The key used for the division operation is the one above the multiplication sign and below the caret [^], and in thee rightmost column of keys.
Beware that this calculator converts any ratio of two numbers into a decimal value. To keep a fraction in a fraction form you must use the [|=>Frac] or [ToFrac] command. To convert a decimal result to a fraction, use the [|=>Dec] command.
These commands are accessible through the CATALOG or more easily by pressing [MATH] (under the ALPHA key) and selecting [1:|=>Frac], or [2:|=>Dec]
Ex: to keep 27/48 in fraction form you enter
27 [/] 48 [MATH][1:|=>Frac] [ENTER]. Result is 9/16
You will notice that the resulting fraction is reduced to its simplest form.
To convert the above result from fraction to decimal press [MATH][2:|=>Dec]
A fraction can always be approximated by a decimal value but the converse is not always possible.
Jan 23, 2010 | Texas Instruments TI-84 Plus Calculator
How to convert fraction to decimal
You can convert between Standard Form (with fractions and pi) or Decimal form by using the "S<->D" button. Use Mode 1 if you mostly prefer fraction answers and you can use the SD button to convert to decimal or use Mode 2 if you mostly prefer decimal answers and use the SD button to see the fraction.
I hope this helps and good luck!
Please remember to vote 51218db.jpg Thanks.
Oct 31, 2009 | Casio FX-115ES Scientific Calculator
How do you square a fraction with a negative number like (3/4)^-2
Place both the base and the exponent in parentheses
(3/4)^(-2) then press enter. Your answer will be in decimal form at first 1.777...
Press MATH
Select the 1: Fraction option and it will convert your decimal value to the fraction answer of 16/9.
Negative exponents flip the fraction. For instance, (3/4)^(-1) = 4/3. So for (3/4)^(-2) you could just square the numerator and denominator separately to get 9/16, and then flip the fraction to account for the negative. That will give you 16/9.
Jul 24, 2009 | Texas Instruments TI-83 Plus Calculator
Ti89 answers in fraction form not decimal form
This is what I did. Go to Math/ 9.Algebra/ 5.approx(
Jun 24, 2009 | Texas Instruments TI-89 Calculator
Sharp EL-520WBBK Calculator Logo
507 people viewed this question
Top Sharp Office Equipment & Supplies Experts
Anthony Karuku
jasbo
jasbo
Adorjani Laszlo
Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
