Question about Sears Craftsman LiftMaster Chamberlain Garage Door Opener Wireless Keypad Model 976LM Security+
Opener stuck in "lock" position
Garage door opener shows "unlocked" - no blinking lights, however, it only operates from inside the door. The remote openers and the keypad outside are not working. Any suggestions?
    Champion:
  • 244 Answers
Recode keypad and remotes
Posted on Dec 29, 2009
The unit is displaying a sequence of 5 flashes with the amber light. When I try to open the door, it will only go forward and backward aprrox. 1 ft. Any suggestions on what I should do?
Craftsmsman 1/2 HP opener indicator light blinks five times ...
? 0:29
https://www.youtube.com/watch?v=AvXJd-tYCJ0
Apr 28, 2012 - Uploaded by bship452
Then showing the amber indicator light blinking 5 five times, stops ... push remote to operate opener, you hear a clicking sound from the unit. ... Show more .... blink 5 times (looks almost alike) If I forced the garage door closed, ...Missing: sequence
Sears Garage door opener problem - Home Forums
ths.gardenweb.com > Home Forums > Garages/Workshops
Jun 27, 2006 - Now, I cannot get the light in the sensor at the door to come on. ... the green LED went OUT about 1/2 way up the door opening sequence. .... other is working (I don't recall if it's green or amber, but know that it is lit.) ... Their is also a green LEDflashing 2 times every 5 seconds or so at control center of unit.
Craftsman Garage Door Opener Problem - Home Forums
Jan 05, 2016 | Building Materials
Liftmaster security + remotes do not operate. I bought 2 new remotes and neither one of them will program to operate the opener either.
Yes it sounds like the board. Make sure the opener is not in lock. If the light in the wall control is blinking press and hold the lock button for 3 seconds.
Jul 29, 2012 | Sears Craftsman LiftMaster Chamberlain...
R garage door opener model 139.53640srt -remote car openers wont work suddenly. have to open using the house opener, whose light is blinking
Press and hold for 3 seconds the lock button on the wall control. The light should stop blinking and your remotes should now work.
Nov 07, 2010 | Sears Craftsman LiftMaster Chamberlain...
I have a 1/2 hp craftsman opener. Remotes work fine. Wired wall unit has a blinking light on the open button and will not work Lock pad and light pad work but not the operate pad.????
Try pressing and holding the lock button for 3 seconds to stop the light from blinking. Your wall control may be bad. Usually when that light is blinking it is the remotes that will not work.
Jul 02, 2010 | Sears Craftsman LiftMaster Chamberlain...
Door operates ok with indide panel but not remotes
Two possibilities right off the bat. One is the opener is in vacation mode. You can tell if this is the case by the rapid blinking of the light in the wall control. If this is the case press and hold the button with the lock icon for 3 seconds.
If not the case you have a bad logic board.
Sep 25, 2009 | Sears Craftsman LiftMaster Chamberlain...
Hi I have 1/3 hp liftmaster garage door opener that will not open from the remotes but will open with button on wall. I think it is a reciever problem?? any suggestions?/
reset your remotes and your main transmitter after removing and replacing the remote batteries (these use rolling codes that change each time you operate the door) the procedure for doing this is listed on the liftmaster website
Apr 30, 2009 | Sears Craftsman LiftMaster Chamberlain...
Remote not working
you will need to train (link) the remote to the garage door opener. to do this you will need to find the remote "train" button on the operator.
If you have the manual for the garge door opener this will show you where it is located.
push the train button on the operator, an LED light will start blinking. Then push one of the buttons on the remote. the LED light on the operator will stay on. push the button on the remote again and the light on the operator will turn off.
try the remote it should work now.
Apr 05, 2009 | Sears Craftsman LiftMaster Chamberlain...
How do I re-code my Raynor Garage door opener Model 61 rdg (on Remote) Serial # 17592 (on opener) Year 1992? I am a new resident in the house with this garage door opener. The remote control opener worked...
on the back of your garage door opener there is a colored learn button--press and release-the learn indicator light will glow for a short time usually 30 seconds. within thirty seconds press and hold the buton on the hand held remote that you wish to operate your garage door. release the button when the motor unit lights blink. if you don;t have a light, two clicks will be heard. it has learned the code. procedure will be different for multi function control.
Apr 03, 2009 | liftmaster Chamberlain Garage Door Opener...
Door opens on it own and light blinks
  • Stuck remote control button. Check all remotes. check LED on receiver.
  • Staples around Multi-Function Control Panel bell wire could be cutting into that wire. Remove wires from opener and test. Replace staples causing intermittent short.
  • Multi-Function Control Panel could have sticking door control push bar. Remove wires from control panel and test. Replace control panel if defective.
Dec 28, 2008 | Sears Craftsman LiftMaster Chamberlain...
Sears Craftsman LiftMaster Chamberlain Garage Door Opener Wireless Keypad Model 976LM Security+ Logo
386 people viewed this question
Top Sears Building Materials Experts
Glenn Mayer
Glenn Mayer
Mike
Are you a Sears Building Material Expert? Answer questions, earn points and help others
