Question about Zebex ZB 2200AM
My scanner scans different numbers to what is on
My zebex scanner scans different numbers to what is on the barcode
  • Anonymous Apr 03, 2009
    can you send me the barcodes
    Problem Solver:
  • 5 Answers
Firstly, You must be reset scanner.
for reset,
to find programing manual.
if you don't have it.I can send to you.
1. scan start of configuration barcode
2. scan reset barcode
3. scan end of configuration barcode
best regards
Ufuk
Posted on Apr 02, 2009
I HAVE 5 SCANNERS, FOUR OF THEM SCAN AS THE ITEMS PASSES IN FORNT OF THEM AND THE FIFTH ONE NEEDS TO PRESS THE BUTTON. HOW DO I CHANGE THE FIFTH TO SCAN AUTOMATICALLY
If you look in the manual, you will see the code to place the scanner in to "stand" mode which should do as you request. This mode is restricted to certain models however. Near as I can tell, there are a few variants of the Z-3051HS model that support this. Reference the manual at the link below. Please update this with any other questions you may have.
Thanks,
Dan
Link: http://www.zebex.com.tw/old_website/documents/users_manual/handheld/z_3051hs.pdf
Apr 02, 2011 | Zebex ZBA Z-3051HS Barcode Scanner - P/N...
How to use zebex barcode scanner?
Click below for a link to the support site. Click on the User's manual for you model scanner.
Zebex Manuals
Hope this helps.
Zeppelinx12
Mar 11, 2011 | Zebex Computers & Internet
Installing the Zebex z-3010
Normally, these scanners need no software, as they simply send a series of digits to the active text box. Try opening notepad or word and scanning any barcode. It should type the number itself.
Apr 14, 2010 | Zebex Z-3080 Handheld
WHERE CAN I DOWNLOAD ZEBEX Z-3080 SCANNER SOFTWARE?
This device needs no software. You first need to set it up with the configuration card (http://www.zebex.com/old_website/documents/quick_program_card/z-3000.3001.3010/Programming%20Card_U_090202.pdf). Then it should scan the barcode number in to the selected text area.
Mar 24, 2010 | Zebex Z-3080 Handheld
Alpha 70 Series is not working after disconnecting PC and recnctg
Hello Suzanne. The problem you are going to find here is that Zebex doesn't make this model anymore and haven't for some time. If the unit has power and emits a beam, I have the Zebex generic Programming Card and Programming Guide available on my company's website. Have a look at the sections that include the "reset default" barcodes. Print out that page and try scanning them with your scanner. Resetting the scanner to it's default programming may get everything ironed out. If the scanner doesn't have power or emit a beam, then unfortunately you will be looking at getting a replacement scanner. I can recommend several different scanners what would work fantastically and be quite cheap. If you still need help, please feel free send a message or email me. I hope this helps. Good luck!
Dec 28, 2009 | Zebex ZB 2200AM
Barcode scanner
please get programing manual for Z-3080 then
scan start of configuration barcode then USB emulation barcode then end of configuration barcode
probably your problem wiil be solved.
Nov 01, 2008 | Zebex Z-3080 Handheld
Stopped scanning
I seldom do this ...but I will comment on the Zebex scanner. This is ...errr ... not the best choice for future scanner needs. I will never forget commercial Zebex experience. They should have stuck to anti freeze (just kidding).
However if it did work and now doesn't there is one problem that is so obvious no one thinks of it ... check the clear plastic protector on teh front and see if it need cleaned. Greasy environments usually fog it over time.
I have the Zebex default codes somewhere in the shop ... but you can replace that scanner with a nice PSC, Mot, or Intermec for about 120.00 why not do that?
Jan 07, 2008 | Zebex Alpha-70 Handheld
No code appear after I scanned the barcode.. Please help!
First of all,have you tried using a notepad ? just to verify that your scanner connected correctly to your pc If it's fine then you should find out if there's an enabled properties of your object such as text box, combo box, that was set to False,change it into true.
Aug 22, 2007 | Zebex 90940-RS232-9 Handheld
Zebex ZB 2200AM Logo
405 people viewed this question
Top Zebex Computers & Internet Experts
David Payne
David Payne
Are you a Zebex Computer and Internet Expert? Answer questions, earn points and help others
