Just got a new epson cx9400 and when i went through the set up proceedure and put the ink cartridges in the on screen says cant recongnize cartridges.
  • Shadow1989 May 11, 2010
    make sure you are putting the black in the black carrier and the color in the color carrier.  Also make sure the cartridges are secured.  If that does not work, you may have faulty cartridges.
  • 928 Answers
Try removing and reseating the cartridge. If that still does not work return the unit to the store
Posted on Mar 07, 2009
I would like to refill Epson Stylus CX9400 old ink
You cant recode the cartridge it is programmed to die and fry. You can get chips but many DIY filling options are going to cause you other issues down the road, they are a cheap way to run your printer but eventually willc ause you issues such as ink leaks which leads to the in pad needing to be renewed not to mention some other horror stories. I would alays reccomend OEM inks, but if non OEM is hte way you want to go contact a retail outlet that specialises in refilling spent cartridges.
May 11, 2010 | Epson Stylus CX9400 Photo Printer
Just purchase and set up Epson Stylus CX9400 Fax Series. States "Cannot recognize ink cartridges." It also has a RED box with a Y and a YELLOW box with a Y both have same number (69) next to them Removed...
Make sure cartridges are part number 69 on all four or 68 on the black if its the high cap cart.
Also check the carts contacts and the machines contacts in the cartridge recetacle for contamination or damage.
Apr 27, 2010 | Epson Stylus CX9400 Photo Printer
I wouldn't recommend it because it will void your Epson warranty.
Color Ink prints are nice, but this cannot be an everyday printer --- the cartridges will put you in the poor house.
Buy a cheap monochrome laser printer (recommend the Brother brand) and save the purple ink for the elections.
Cheers!
Mar 19, 2010 | Epson Stylus CX9400 Photo Printer
Broke and can't buy new color cartridge can I print in black only
No, the printer will not work with missing or empty cartridges.
Jan 07, 2010 | Epson Stylus CX9400 Photo Printer
REPLACED TWO 68 CARTRIDGES IN CX9400 EPSON
Generic carts are sometimes not recognized. Epson's chips are the cause. I solved this problem for a small investment. I purchased a CISS system for about $75.00 [ink included], that's the cost of OEM carts that do not last very long. The CX9400Fax is an Ink Hog, which is why the printer is so cheap. If you want a CISS go to http://www.inkproducts.com/ink-store/ They are great if you need help and will call you back in less than an hour. Get the Waste Ink Kit when ordering the CISS.
Apr 05, 2009 | Epson Stylus CX9400 Photo Printer
Horrible ink issues..
Unless you are printing a lot in that color, my Epson Stylus photo color R300 uses black at about twice the rate as the color ones. Most packages or ink, I find, also come with two black and one of every color. All my color ones seem to emply at approximately the same time as the others.
Mar 08, 2009 | Epson Stylus CX9400 Photo Printer
Why won't my CX9400F recognize Epson ink cartridges
The Epson CX9400F printer seems to require replacement of all the color ink cartridges, even if only the Black is empty.
I print almost exclusively in Black, but with my first change of Black, I was forced to change all the color. At the time I thought Epson did not provide completely filled color ink cartridges.
Just yesterday, I replaced Black and the printer complained it did not recognize the rest of color cartridges. So I replaced all the other color ink cartridges and now it works fine.
You might want to check out www.clickinks.com for cheaper, mail order alternatives which are Epson ink compatible, if you are not in a hurry.
ew
Feb 23, 2009 | Epson Stylus CX9400 Photo Printer
HOW DO I CHANGE THE INK CARTRIDGE IN THE EPSON CX9400
CX9400Fax, All in one?  If so; download the manual and/or Q& A and /or trouble shooting guide for instructions:
Link
Feb 07, 2009 | Epson Stylus CX9400 Photo Printer
Ink cartridge replacement
Hi-
- If a cartridge is expended, you see a message on the CX9400Fax display screen. The icon on the screen indicates which color to replace. Press OK.
- If you're replacing a cartridge before it's expended, press the Setup button, select Maintenance, and press OK. Then select Change Ink Cartridge and press OK.
Hope this helps
Aug 04, 2008 | Epson Stylus CX9400 Photo Printer
New out of box!!
If you already have tried reseating all of the inks and and inks are still not recognized, Please contact Epson tech support for a replacement ink or if they find out after some diagnostics that it is the printer that is having an issue they would be replacing your printer.
Jun 22, 2008 | Epson Stylus CX9400 Photo Printer
jasbo
jasbo
