Question about Whirlpool GD2SHGX Refrigerator
I have a Kenmore side-by-side refrigerator and there is no water coming thru the Dispenser. However it makes ice. The model # is 25355689408 Thanks brian
  • 1 more comment
  • Brian Gozmao Mar 11, 2009
    Can you let me know how I get to the tubing ?
  • Brian Gozmao Mar 20, 2009
    Thank you , I was able to find the tubing. How long should I use thehair drier? I used it for 5 mins but no success. Any other help? Orshould I use it for a longer period. I am concerned as it is plastictubing! and should not cause a bigger problem
  • Brian Gozmao Mar 26, 2009
    Thankyou for your response on 3/21. I was wanting to know 'how long' do I use the dryer 2" from the tubing? Also, are there any other 'checks' I can do to confirm if the water is clogged anywhere else? thankyou
  • 700 Answers
The water tube nside of the refrigerator is frozen up. take a hair drier and locate the roll o tubing and thaw it out.
Posted on Mar 07, 2009
  • Todd Born
    Todd Born Mar 14, 2009
    you have to remove the bottom drawers to the refrigerator and then remove the light cover and then you will see the tubing all coiled up.
  • Todd Born
    Todd Born Mar 21, 2009
    if you hold the heater back around 2 to three inchs you should be fine.
Kenmore coldspot water dispenser stopped working. Ice maker works. What could be possibly wrong?
On the rear of your refrigerator there is a dual water control valve. One side for ice maker and one side for water dispenser. I believe your side for the water dispenser has failed and they come as a set. Send the Kenmore model number and I will find you one. The number will look like this, 326.256489 for example only. Found near the bottom of the fresh food section door. Thanks, Sea Breeze
Nov 29, 2009 | Kenmore 55612 / 55614 / 5561 / 655619 Side...
Kenmore Elite refrigerator ice and water dispensers not working
check for a child lockout button it will look like a tiny padlock ,press and hold for 3 sec.(could be the freezer door light switch)
Jul 24, 2009 | Refrigerators
Only crushed ice comes out of dispenser
your model # is incomplete but here it goes.
1.take your ice container out and run hot water thru it. you want to defrost all of the ice build up inside of it's housing.
2. make sure the long lever under the container moves up & down when you press on it.
3.w/the container removed, you will see a fork like object and next to it amn openning w/a small plastic square part inside. make sure that part moves freely up & down. that solenoid is what gives cubed ice.
let's start there first
Jul 14, 2009 | Whirlpool ED2FHEXN Side by Side...
Freezer does not make ice
You need to check and see if ice maker has any water init. if not check the fill tube that goes thru the back wall for stoppage while you have it out rin the maker thru a harvest mode and listen for the sounds of the solonoid opening. If tube is full you'll need to replace the slow leaking valve a common problem. for parts call 704-819-6557
Mar 14, 2009 | Whirlpool 25.6 cu. ft. Side-by-Side...
Kenmore refrigerator Model No. 106.56839600 water dispenser
Hi
The water is kept cool in reservoir in the fridg. Remove the inlet tube push for water check pressure better worse? Work your way back to valve
good luck
Apr 12, 2017 | Kenmore 21.7 cu. ft. Side-by-Side...
Ice does not dispense through door of kenmore elite side by side
take ice bucket out, dump ice, clean with hot water and let dry ,,,, put ice back in and try it ,,, bucket is most likely frozen up thru ports
Nov 28, 2008 | Kenmore 53642 / 53644 Side by Side...
Need help with ice maker
thr tube leading to the ICM may be frozen. this can be removed through the back and cleaned. if it continues to freeze up it is likely the water valve.
J
Jun 12, 2008 | Kenmore 21.7 cu. ft. Side-by-Side...
Ice and water dispenser lock light stays on and comes back on quickly after pushing and holding. No water or ice dispensed while light on. Kenmore Elite 23.1 ft side by side refrigerator
I resolved the problem on my Kenmore Elite model 106.55616400 by removing the drip tray, taking out two screws that hold the panel, and disconnecting and reconnecting the wires from the panel to the board. Unplugging the refrigerator did not work.
May 28, 2008 | Kenmore 25.1 Side-By-Side Refrigerator...
Whirlpool GD2SHGX Refrigerator Logo
115 people viewed this question
Top Whirlpool Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Dan Webster
Dan Webster
Are you a Whirlpool Refrigerator Expert? Answer questions, earn points and help others
