Question about Canon XL1S Mini DV Digital Camcorder
Canon XL1 Viewfinder has snow
The viewfinder has a white snow. You can faintly see the subject however it is not visible enough to focus and shoot.
    Novelist:
  • 154 Answers
If the recording is ok and output from the body is also looks good, VF unit needs repair. Make sure the brightness control on the VF is tested before seding for repair. -James. For further assistance by email, go to www.camerarepairjapan.com
Posted on Mar 27, 2009
My E 620 shutter does not work when using viewfinder, but works when using screen
While using the viewfinder, does any warning come in the viewfinder?
Not sure, but if you are shooting in a different mode, it could be there is not enough light, or the camera can't focus.
Using the viewfinder the camera will use a different way to focus as when using the display.
Perhaps the autofocus, does not work correct. Looking through he viewfinder, wait till the AF confirmation mark lights up. (bottom left)
If it won't light up, something is wrong with the AF.
Feb 22, 2014 | Olympus EVOLT E-620 Digital Camera
Canon 1d mark 4 camera viewfinder problem
Adjust the viewfinder diopter to match your eye. Remove the rubber eyecup by grasping both sides and sliding it up. Turn the little knob to the left of the viewfinder until the focus points or center metering circle appear sharp. Replace the eyecup.
Mar 16, 2013 | Cameras
Canon 450D viewfinder out of focus due to loose element within viewfinder, is this repairable
There's a diopter adjustment knob above and right of the viewfinder. Turn the knob while peering through the viewfinder until it comes into focus.
Jul 29, 2012 | Canon EOS 450D Digital Camera
Some of my pictures are blurry using a cannon rebel 3. how can i fix this problem?
There are several possible causes for blurry pictures.
1) Camera motion. If everything is blurry, it's most likely because the camera moved while the picture was being taken. Make sure your shutter speed is fast enough if you're handholding the camera (longer lenses require faster shutter speed). Alternatively, put your camera on a stable surface, such as a tripod or a tabletop.
2) Subject motion. If the subject is blurry but the background is sharper, then the subject may have moved while the picture was being taken. Use a faster shutter speed. Raise the ISO if needed. There are limits, of course. If you're trying to photograph a fast-moving object in the dark, you probably won't be able to.
3) Improper focus. If the subject is blurry but something else in the picture is sharp, then the camera probably focused on the wrong object. Move the focus selector to the subject you want in focus. Alternatively, center the viewfinder on the subject, press the shutter button halfway to lock focus, then reframe and shoot.
Without any more specific information as to what and how your pictures are blurry, I'm afraid the above is all I can give you.
Jan 13, 2012 | Canon Cameras
Hi there, I don't know if it's a problem or not (I can live with it :) ). I just got a Canon EF 50mm f1.8 II lens, and I really love it. But: When I'm using the eye-level viewfinder (and not...
You may just have the left auto focus points selected. You don't say which camera model you have. If on the back of your camera you can see a button with an icon showing 5 small white blocks in a plus sign in a white box press this to select the auto focus points. It should show the available auto focus points and then use the left/right (wheel) button to change the selection
Jul 01, 2011 | Canon EF 50mm f/1.8 II Lens
Canon rebel eos When trying to take a picture the autofocus won't work up close
Close up and macro photography require special lenses chances are you are to close for the lens to see what you are attempting to focus on. Another thing if you are hand holding the camera the chances are extremely good you can't hold it steady enough for the camera to lock on to the subject.
When shooting macro the depth of field is extremely shallow to you need to stop down the lens to maybe F11 or even F22 so now you have a light problem. You didn't say how close the subject was to the front of the lens. So to get started on this close up photograph mount the camera to a tripod switch the lens to manual and slowly focus on your subject. There is a small green dot in the lower right corner of the viewfinder that will come on sold green when your subject is in focus. If it doesn't you are to close to the subject for the lens you are using.
Dec 16, 2010 | Canon EOS Rebel XSi Digital Camera
Appears in focus in viewfinder, but isn't
Change your focusing setting to spot focus. Then, focus on your main subject, keep the button half-way pressed while you re-compose the shot and then press it the rest of the way. Does that improve the shot?
Sep 21, 2009 | Nikon D100 Digital Camera
Canon XL1 recordings are dark--the room is dark, but there are stage lights..Yet the recording came out extremely dark--what are we rookies missing?
"stage lights" may still not be enough- there should be alow light indicator in the viewfinder (amoung the many things being displayed)- Also, the camera manual should tell you the minimum illumination that the camera will record in (usually listed as LUX or Footcandles, or sometimes in EV), but unfortunately you would want an old fashion light meter to check the light level of the stage ahead of time
Aug 20, 2009 | Canon SI-XL1 System (0002v410)
When take photos it looks in focus through the viewfinder, but the pictures come out slightly out of focus
I'm not sure what camera you are using. But I believe you are taking pictures like the old Kodak Instamatic which you just literally point and shoot. Even then people took blurred pictures. There are 2 reasons I can guess. First is you are pressing the shutter button too fast. When you press the shutter, it should be like squeezing the trigger of a gun. You SQUEEZE slowly. Not press the button and let go. After you hear the camera has done all the sound it wants to make that means you picture is being recorded. And hopefully it will be clear. If it still isn't then it means your camera take a little bit longer to focus on the subject. That's what happened to my wife. She thinks she can point and shoot and that's it. You need to camera a few seconds to focus. I know the Casio's have a little beeping sound that tells you it has focused and is ready to shoot. My Konica Minolta does the same but I see a box on the screen (I took the sound out). You need to listen for that tone that tells you you camera has focused on a spot and is ready to shoot. In order for the camera to do this you need to press the shutter only half way. When you hear the tone then slowly press all the way and don't move till all the clicks are done. That's usually 0.5-1.5seconds only. Hope this helps.
Nov 19, 2008 | Canon Cameras
Diopter adjustment and viewfinder problem
Hi
I would not attempt to open the camera for any sort of fix. It has weather seals in place and would recommend sending it in to Canon. If you have any warranties left it would void these. Lastly this is a high proformance bit of kit and you want to get is seen to by an Authourised Canon Dealer.
As for the diopter adustment. To be able to see through the view finder and see your subject clearly, take of the lens cap aim the camera and turn the little dial until the screen inside the viewfinder is clear it should not be fuzzy. You are only looking at the screen/gring and not the image beyond. This does not affect your image but does effect how clearly you see your subject through the viewfinder.
Hope this helps
Regards
Jun 03, 2008 | Canon EOS-1Ds Mark II Digital Camera
Canon XL1S Mini DV Digital Camcorder Logo
207 people viewed this question
Top Canon Video Cameras Experts
Pieter Vleeshouwers
Pieter Vleeshouwers
Steve Mason
Are you a Canon Video Camera Expert? Answer questions, earn points and help others
