Question about Whirlpool LCR7244H Top Load Washer
Hoover 750LB top load washing machine - water won't shut off
When filling the cold water won't shut off to the selected water level, continuing to fill to over flow. I thought it may have been the shut of valve, which I replaced to no avail. Has anyone experienced this problem and advise what was done to overcome.
SOURCE: The duet washing machine fills up with water in between loads. What is Causing This?
Dont want to endorse a commercial site, but you can by a generic part for a bit over $10 for this problem, so do some seraching for a reasonable site (other sites are charging 40-50 dollars for a fill valve.
Posted on Aug 09, 2007
faggly
  • 74 Answers
SOURCE: Maytag performa washer hot water runs continuously
Littleone.. please check your instructions.. some washers now dont need Hot water connection to them...they heat their own as part of the efficiency settings on the wash programmes themselves!
Regards Faggly
Posted on Mar 19, 2008
Healeyman
  • 1198 Answers
SOURCE: Whirlpool model LSR7233EZO / doesn't fill fully
The fill switch is a very sensitive device. You can test it by blowing into the tube, listen for the switch to click, or use an ohms tester. They are actually adjustble, the adjuster screw usually has glyptol (thread lock) on it. I would replace one before trusting an adjusted one.
Posted on Jul 29, 2008
  • 62 Answers
SOURCE: water will not shut off keeps filling and overflows
This is a fill valve gone out
Posted on Oct 20, 2008
jumptrout51
  • 3361 Answers
SOURCE: My maytag washer will fill up with water but not start washing
Replace your lid switch.
Posted on Mar 08, 2009
Hoover 705 , overfills and fllods laundry can it be fixed
On my hoover 200m (top loader) I had a similar problem. I turned off the machine & unplugged it. Closed water taps both hot & cold. Manually emptied machine with large cup. Undid bottom outlet hose by unclipping.The residual water will come out! I undid the 3 screws on the control panel. Tilted the control panel forward. The water level is manual control using a diagaphram pressure control to set water level. This had a hose. I disconnected both ends and used a bicycle pump to blow air thorough it. Underneath I disconnected where the hose goes into machine (clips) and also blew air from the top to check it was clear. After reconnecting everything the machine now does not stop filling and does not overflow anymore. Hope this helps.
Jul 28, 2012 | Hoover HTC243 Top Load Washer
We can only use hot water in our Whirlpool 7.5kg WFE1070BD 1000RPM - how to we shut off the hot water and use cold water? We have tried only cold but the machine will not operate. Please help. Many...
Turn off the water to the machine. Disconnect the cold water hose from the back of the machine and put it in a large bucket. Turn on the water to see if you get full-pressure cold water from the hose. If not, the shut-off valve or other plumbing has a problem.
If you do get cold water from the hose, check the strainer inside the hose fitting on the back of the washer. Clean it if it is clogged. If you still don't get cold water in the machine, you have a problem with either the solenoid valve or the cold water fill contacts in the timer (the timer won't start until the tub is up to the selected level, but if the valve isn't opening or the supply line is otherwise blocked, the machine will never fill). Sometimes in this case you can hear the solenoid valve humming (normally the sound is masked by the running water).
If the problem is a clogged strainer, clean out the hot water strainer also.
I find I get better wash results with warm water (runs both hot and cold for the wash cycle). The soap is more active than in cold water, so I don't need quite so much, and the machine doesn't take as long to finish a cycle since it fills faster. Of course, the cold water has to be running to get the energy savings compared to hot only.
Jun 06, 2011 | Whirlpool Ultimate Care II LSQ9549L Top...
I put in a load. The machine filled up but did not stop filling. The dial did not proceede to next step, it stayed at the 10. Overflowing EVERYWHERE. When we moved the dial manually to spin, it drained...
your fill switch is either bad or "gllitched" and the timer cannot move until this switch senses the right amount of water for the load unless its an electronically sensed water/load capacity filled machine,when it starts,the water fills the unit and the pressure switch shuts the water fill off when at selected water level and powers the timer to continue the wash cycle,it works off a "bellows" on air pressure to change a switch by air pressure to operate the machine when full of water
Dec 27, 2010 | Kenmore 22622 Top Load Washer
Why did my LSE7806ACE WASHER STOP FILLING
Hi…
If I get you correct, the hot water is not coming into the machine or it is not working at all.
Let me know
Thanks
Smith
Aug 13, 2009 | Maytag LSE7806A Top Load Stacked...
Hoover 750lb
if its a top loader check for timer/timer module fault.front loader check carbon brushes in motor
Feb 18, 2008 | Frigidaire GLTF1670A Front Load Washer
Washer filling up improperly
Well its definately not your water level switch, so that only leaves your water fill valve at the back of the washer, the cold valve is stuck open by debris. hope this helps
May 18, 2007 | Whirlpool LSR5132PQ Top Load Washer
Whirlpool LCR7244H Top Load Washer Logo
175 people viewed this question
Dan Webster
Dan Webster
Sal DeAngelo
