Question about Vacuums
My bissell bagless vac has no vaccum. ihave
My bissell bagless vac has no vaccum. ihave cleaned out the hose and it still has not helped.
  • Anonymous Mar 24, 2014
    shop vac vaccum hose removal
  • 328 Answers
Have you checked the main dust channels from the hose leading into the bin? Have you brushed clean the main filter cones? Make sure all the filters have been properly cleaned *(and if washed make sure its completely dry before puttng back into the machine.) Also please check the beater bar, especially the dust channel behind it as it can get clogged badly.
Posted on Mar 06, 2009
  • 408 Answers
You will have to clean the filter and clean the main motor.  I had this issue on mine and the main motor was so full of dust bunnies, that it stopped it from creating a vacuum.
My vacuum lost it's suction power. I've looked to see if it's clogged and the container is clean. What's going on?
That type of vac is notorious for stopping up where the 90 degree turn is. You may need to access it from the vac head by removing the beater bar or take it apart where ever you can access the turns and hoses.
Feb 19, 2011 | Bissell Healthy Home HEPA Bagless Upright...
The 1st time i used the vac the brushes are not turning
Hi there Vaccum Guru from VacuumSpot.com.au here. Wow that is ****, however it's just not your problem. Take it back to the place you bought it from and ask them to replace it. Bissell are a good machine and have great backup, this should not be a problem.
Hope this helps :)
Oct 13, 2010 | Bissell 5770 Healthy Home Bagless Upright...
Vaccum problem
No sound at all? or the motor runs but no vaccuum?
did it stop while using it? might have overheated due to dirty filters... strange that the light comes on but no motor at all... that would suggest to me that the motor is shot...
Here is a link the the manual.. there is no reference to any user accessable fuse or breaker...
Peace,
Mar 07, 2010 | Bissell 6594 PowerForce Bagless Upright...
Bissell 3750-T Bagless Upright Vacuum motor is hot, noisy, and smells like it is burned out, but still working. Can I replace the motor?
There are threee filters inside this unit. Be sure all three are clean. You can't clean the Hepa filter. You can only replace it. You may even try pluging it in and running it (not while vacuuming the carpet) without the filters to see if it is clogged up anywhere. It's not uncommon to **** up an object that doesn't fit though the vaccum hose very well and for that item to cause hair etc to catch on it and plug that hose. Before you know it you have a big plug in that hose. The hose detaches easily. Look through it.
Feb 24, 2010 | Bissell 3750 Lift Off Bagless Upright...
Vaccum works but will not **** up anything. i have cleaned hoses and filters
have you checked to see if the belt is attached to the brush roller? That's a common problem. Check your belts
Feb 10, 2010 | Bissell LiftOff Revolution Pet Vac 37602...
No suction on Bissell Powerforce Bagless. Have thoroughly cleaned
Make sure you unplug before cleaning turn vaccum upside down check roller
for hair and strings wrapped around brush if this does not help clean out cylinder gently knocking dust out or use a duster to stick up inside lightly cleaning and check filter
Sep 30, 2009 | Bissell 6594 PowerForce Bagless Upright...
Bissell vaccum problem
Could be plugged, check the hose and at the bottom by the brush roll, the inlet maybe clogged. Also check the filter under neath the dirt tank. There are filters above the dirt container, clean those out. If after that it is still loud, then maybe the motor fan or bearins are bad and will have to be replaced, part #2031214 sells for around $55.
Jan 16, 2008 | Bissell 3594 CleanView PowerTrak Bagless...
BISSELL POWERFORCE BAGLESS UPRIGHT FOOT HOSE IS TORN
Take the top cover off, unscrew where the hose hooks onto the back, then you can get to it.
Nov 18, 2007 | Vacuums
Vacuums Logo
64 people viewed this question
Top Vacuums Experts
AskDyson
AskDyson
D. Floyd Kolb
D. Floyd Kolb
Are you a Vacuum Expert? Answer questions, earn points and help others
