Question about Canon EOS 40D Digital Camera
LCD says "firmware update program" when battery is inserted..
It also says "update file cannot be found. Please check the memory card and reload the battery and try again."
It shows up when I insert the battery, even when the camera is off. It wont let me go to menus or anything.
The memory card I am using is one I used in my older Rebel Xt and is a Lexar Professional CF
I JUST took it out of the box like this, is there an easy way to fix this or do I need to send it back?
    Scholar:
  • 55 Answers
You probably put a firmware update on the memory card for your old Xt.  You need to open the memory card on your computer and delete the old firmware update.
Posted on Apr 25, 2009
Charged the battery for 1st time when i installed it camera is frozen, error message reads firmware update program, update file cannot be found check memory card and reinstall battery.
Not being there to look at it, I would say, turn it off, hook it up to your computer using USB, and turn the camera on. It may recognize the network and reflash you're cameras firmware.what ever you do, do not turn it off in the middle of flashing or your camera ma become a brick.
Mar 28, 2016 | Cameras
Pdr m700
Hi Lorinda,
There are a few different reasons why your camera may not be reading the memory card.
Troubleshooting such problems can be a little tricky, especially if no error message appears on your camera's screen.
The cause and solution may include one of the following:
    ·The card may not be the right type for the camera: First make sure the memory card you are using is compatible with your camera. For example, a SDHC memory card often will not work with older memory card readers. Even though SD memory cards are similar in size and shape to SDHC cards, they use different software for managing the card's data, meaning older readers sometimes cannot recognize the SDHC cards. Sometimes you can solve this issue by updating the memory card reader's firmware to give it the ability to deal with SDHC cards. Check the Web site of the manufacturer for your memory card reader to see if new firmware is available. It is also a good idea to check with your camera's manufacturer (on it's website) to see if an updated version of your camera's firmware is available.
    ·The card is not fully inserted in the camera. Turn off the camera, insert a card into the slot, then push to seat it.
    ·The card or a file on the card may be corrupt. Photo file corruption can occur when the battery power is too low when writing a photo file to the card, or when the memory card is removed while the camera is writing a photo file to the card. One way to check if it is the card or your camera is to try moving the memory card to a computer, then try accessing the photo file directly from the computer to see if the file actually is corrupted, or if your camera is just unable to read a particular file.
    You can also double check this issue by using another memory card in your camera and see if it works as it should. If the memory card is unreadable on any device, the next step is to reformat the memory card. Look through your camera's on-screen menus to find a "format memory card" command. However, keep in mind that formatting the card will erase all photo files stored on it. Some cameras just work better with a memory card when that memory card is formatted inside the camera. If you do reformat the card, make sure to let the process finish itself before removing the card. Removing a card during formatting may damage the card.
May 01, 2014 | Toshiba PDR-3300 Digital Camera
Stuck on please wait
Check your current firmware version before beginning:
  1. Turn on the camera.
  2. Tap the menu tab at the bottom of the monitor to display the setting controls and tap Setup (wrench icon)
  3. Tap Firmware Version in the Setup menu(wrench icon)
  4. The cameras firmware verison will be displayed.
  5. Turn off the camera.
Basic Download and Installation instructions: (New firmware versions contain all previous versions.)
Windows
  1. Create a new folder with an appropriate name on your computer's hard disk.
  2. Download F-S4300-V12W.exe to the folder created in step 1.
  3. Run F-S4300-V12W.exe to create the folder titled S4300Update, containing the following:
    • firmware: folder containing the firmware.bin file
    • firmware.bin : the firmware located inside the firmware folder.
  4. Insert the memory card containing the firmware folder into the camera and turn on the camera.
  5. Tap Firmware version in the Setup menu and follow the instructions displayed to upgrade the camera's firmware.
  6. After the upgrade is complete, turn the camera off and remove the memory card.
  7. Check the Firmware version item in the setup menu to confirm that the camera's firmware has been upgraded.
For detailed instructions, please see the PDF files below.
Macintosh
  1. Download F-S4300-V12M.dmg.
  2. Double-click the F-S4300-V12M.dmg icon to mount the disk image titled, F-S4300-V12M.
  3. A folder titled S4300Update, containing the following files, will be created inside the disk image:
    • firmware: folder containing the the firmware
    • firmware .bin: the firmware
COOLPIX S4300 1 2 firmware update Nikon Knowledgebase
Mar 28, 2014 | Nikon COOLPIX S4300
Can i update camera firmware through a printer dock?
Kodak does not suggest a firmware upgrade through a printer dock. Instead, they recommend using an SD card (memory card).
First:
  1. Click Download, then save the firmware file to your computer desktop.
  2. Double-click the *.exe file. When the WinZip Self-Extractor screen appears, select a folder or accept the default location, then click Unzip. The firmware file unzips to the specified folder.
  3. Note the location of the *.FW file, then close the WinZip Self-Extractor.
Instructions:
  1. If you have pictures/videos on your camera's internal memory or on the memory card, save them to your computer.
  2. Ensure that your camera batteries are fully charged.
  3. Turn off your camera.
  4. Insert the memory card into your computer or into a card reader attached to your computer.
  5. Verify that the memory card has at least 100 MB free space.
  6. On your computer, select the removable drive associated with the memory card or card reader.
  7. If a System folder does not exist on the memory card, create one. From the removable drive window, select File > New > New Folder, then name the new folder System.
  8. Copy the *.FW file from your computer into the System folder.
  9. Remove the memory card from your computer or card reader, then insert it into your camera.
  10. Turn on your camera, then follow the instructions to begin the firmware upgrade. The upgrade takes approximately two minutes to complete.
  11. When "Upgrade was successful" appears on the LCD, select Delete Upgrade File to delete the firmware file from the memory card.
  12. Turn off your camera, then turn the camera on to activate the new firmware.
Feb 07, 2014 | Kodak EasyShare P880 Digital Camera
FIRMWARE for Sanyo xacti vpc-hd2000!?
Updating Firmware on Xacti HD2000
This page explains how to download and install the firmware update for the VPC-HD2000.
  • This firmware is for the VPC-HD2000 only. Please do not install it on another model.
  • By installing this firmware Greek, Swedish and Finnish will be added as new menu languages. (Please notice that for this purpose the menu languages Traditional Chinese, Simple Chinese and Korean will be deleted!)
    It is not necessary to install this firmware update when there is already the possibility of choosing Greek, Swedish or Finnish as menu language! Please check this before continuing with the update.
  • Before updating the firmware, please read through the explanations on this page.
  • Make sure to update the firmware in the order shown below.
  • The camera might not boot up properly if its power is turned off during the firmware-updating procedure.
  • Please read the accompanying licensing agreement before downloading this firmware. Downloading the firmware automatically implies your acceptance of the licensing agreement.
Requirements:
  • SD memory card (henceforth referred to as "card") with capacity over 8 MB.
  • Fully charged lithium ion battery.
  • Additionally, you need one of the items listed below:
    (i) A SD memory card reader (henceforth referred to as "card reader")
    (ii) A dedicated USB interface cable (shipped with the camera).
CAUTION
Be sure not to take out the battery during the updating procedure (this lasts about 60 seconds).
Avoid operating the buttons on the camera or closing the monitor unit during the updating procedure.
I) Preparing to update (copying the firmware onto a card)
Step I.1: Format the card on your camera*
  • Turn the camera on and set the "REC/PLAY"-button to "PLAY"
  • Press the "MENU"-button.
  • Move joystick to the left and select "OPTION MENU 3".
  • Move joystick to the right and select "FORMAT". Press the "SET"-button.
  • Select "FORMAT". Press the "SET"-button.
  • Select "YES". Press the "SET"-button.
    *CAUTION
    If you format a card, all images and data stored on that card (whether protected or not) are deleted! Please be sure to move or copy important images and data to a PC or to another card!
Step I.2: Download the Firmware*
  • The firmware can be downloaded here.
    icon_dl1.gif Firmware Update XACTI HD2000
    s313n081.bin (7.5 MB)
    *CAUTION:
    Please be sure to download the file onto a hard drive and not onto a removable location such as a card reader.
    The firmware file should be saved in a location where you can easily find it again later (e.g. save it on desktop of your computer).
Step I.3: Copy the file "s313n081.bin" to the formatted card (from step I.1):
The method of operation differs depending on whether you use a card reader (i) or a dedicated USB cable (ii).
(i) When you copy the downloaded files with a card reader: (1) Put the formatted card from step I.1 in the card reader. (2) Copy the "s313n081.bin" file created on your hard disk in step I.2 to the root directory of the card.
(ii) When you copy the downloaded files with a dedicated USB cable: (1) Connect the camera to your PC with a USB cable and turn on the camera. When you connect to your PC, please make sure the camera's USB interface is set to "Card Reader". (Please refer to "Setting the Connection Mode" on pages 7 to 8 of the Instruction Manual in the Xacti Software CD 1.0) Please make sure the camera is recognized as a removable disc. (2) Put the formatted card (from step I.1) in the camera and then copy the "s313n081.bin"-file created on your hard disk (in step I.2) to the root directory of the card.
(3) Remove the camera from computer.
Please read "Dismounting the Camera" on pages 9 to 11 of the Instruction Manual in the Xacti Software CD 1.0 for a description of how to disconnect the camera.
II) Updating firmware on the camera itself
CAUTION>:
Do not turn off the power during the updating procedure (this lasts about 60 seconds)!
  • If the power is turned off during the updating procedure, the update may not be properly completed and the camera may not start up.
  • To prevent the battery from running out during the updating procedure, please use a fully charged Lithium ion battery.
  • Do not remove the battery during the updating procedure.
  • Do not operate the buttons on the camera or close the monitor during the updating procedure.
Step II.1: Insert the card with firmware-update file (from step I.1) into camera
Step II.2: Turn the camera on and set the main switch to "PLAY".
  • The playback screen will be displayed.
  • If the camera is in SIMPLE mode, switch it to NORMAL mode.
Step II.3: Press the "MENU"-button.
  • The menu screen will be displayed.
Step II.4: Choose "OPTION MENU 3"
Step II.5: Choose "FORMAT" from the Menu Screen, but do NOT go into "FORMAT"
Step II.6: Move joystick to the left for more than 2 seconds.
  • The update screen will be displayed.*
    *No Update Screen
    If the update screen is not displayed, it's possible that the update file was not copied onto the card. Please refer to "Preparing to Update" to copy the update file onto the card and follow the updating procedure once more.
    If the main switch is set to "REC", the update screen will not be displayed. Make sure the main switch is set to "PLAY".
Step II.7: Choose "YES" and press the "SET"- button.
  • Updating will start.
  • During the updating procedure, the screen will show the message, "LOADING. DO NOT POWER OFF", and the access light will flash.
    Please do NOT turn the power off during the updating procedure! (this takes about 60 seconds).
Step II. 8: When the updating procedure is completed, the camera will turn off automatically.
  • Please remember to format the memory card once more before using it again.
Oct 15, 2010 | Sanyo Xacti VPC-HD2000 High Definition...
M getting "not enough memory" when playing media player.though my phone memory is empty an i updated my phone software recently... so plz let me know wat should i do
Please save your data and reload the firmware using nokia software updata.Ensure that you use Outlook to sync the contacts and not the backup from memory card.Whne we backup from memory card the corrupt files will get replaced
Feb 18, 2010 | Nokia 5220 XpressMusic Cellular Phone
Camera dont work
format your memory card.. it sounds like your programming file was deleted.
Jun 05, 2009 | Canon EOS Digital Rebel XS / 1000D IS...
QV-R40 camera
I had the same problem but managed to track down the firmware file qvr40.bin , copied it onto the mmc then updated on camera. All seems well now, so hopefully fixed the problem
Mar 15, 2008 | Casio QV-R40 Digital Camera
Canon EOS 40D Digital Camera Logo
135 people viewed this question
Top Canon Cameras Experts
TC CAMERA REPAIR.Com...
old marine
old marine
Are you a Canon Camera Expert? Answer questions, earn points and help others
