Question about HP Computers & Internet
When pc is turned on get repeating long beeps
  • 62 Answers
Long beeps means somthing wrong with the RAM
Open computer case
ground your self (touch something metal)
Chech that the ram sticks are in the slots on the motherboard secure.
Posted on Mar 06, 2009
Acer aspire zs600 Has Black Screen and Beeps 6 times, then repeats beep...
You might want to start in the safe mode. Right after you reboot your computer keep pressing f8 and it should start in safe mode. Once there you could then possibly see if you can solve the problem.
Good luck,
Marty
Jul 15, 2014 | Acer Aspire ZS600-UR308 - Core i3 3220 3.3...
One single short beep pc turns off for some sec and turns on repeating th beep
Most probably your processor is getting overheated due to dust on the cooling fan and heat sink. Remove them and clean. Before putting them back remove old thermal pase and apply fresh one. If you are not familiar with these things then go to a technician.
Nov 26, 2013 | Acer Aspire X3200 PC Desktop
Mercury PI865D7 Motherboard system is won't turn on. I Checked SMPS and RAM. it's also a good then what's the problem for this....And Coming high pitched Bee Sound Repeatedly.....
Hello the manual can be downloaded here:
http://www.mercury-pc.com/downloads_list.php?productid=684
Check the ram modules, and the graphic card.
How many beeps comes, when you start the pc ??
Here is a list of beep codes:
http://www.computerhope.com/beep.htm
One long beep is a ram module failing.
Try insert one module, and reboot.
The problem could also be, the power supply.
Here is a fault finder guide:
http://www.tomshardware.co.uk/forum/261145-13-perform-steps-posting-boot-video-problems
Best of luck
Jan 23, 2013 | Computers & Internet
Why does my computer beep when I turn it on?
Here is a list of what beeps may mean:
1 long, 2 short Video adapter error: Bad or improperly seated video card Repeating beeps Memory error: Bad or improperly seated RAM 1 long, 3 short Bad video RAM or video card not present High-frequency beeps Overheated CPU: Check fans Repeating high/low beeps CPU: Improperly seated or defective CPU 1 short DRAM refresh failure 2 short Parity circuit failure in the first 64KB of RAM: Likely a bad RAM IC, or possibly one of the hardware tests has failed
Once you have identified what the beeping means you should contact the type of pc you have and ask what to do.
PCHELPSTER007 from youtube
Jun 25, 2011 | Computers & Internet
When I turn on my pc it beeps three times and there is no signal to the monitor. What do the beeps mean?
hi,
please write your beep description
ex: one long beep two short beep
repeating short beep
Sep 11, 2010 | Gateway 838GM (RB838GM) PC Desktop
WHEN I TURN IT ON, THE COPUTER STARTS BEEPING
that sounds. are memory problem related :
Beeps Meaning 1 long, 2 short Video adapter error: Bad or improperly seated video card Repeating beeps Memory error: Bad or improperly seated RAM 1 long, 3 short Bad video RAM or video card not present High-frequency beeps Overheated CPU: Check fans Repeating high/low beeps CPU: Improperly seated or defective CPU
May 10, 2010 | Computers & Internet
My presario 1600 just beeps when I turn it on...
there are 4 kinds of beeps that the pc produce when you turn it on, base on your beep it is indicating that the memmory is damage,
a single beep means the pc is ok
and your beep is memmory damage
a long beep pause and then beep long again means video card damage
if the beep sound like a firetruck the processor or memmory is over heating
Sep 24, 2009 | Compaq Computers & Internet
WHAT DOES 3 BEEPS MEAN WHEN I BOOT UP MY K7T266 VER1 0 MOTHERBOAR
*Turn off your PC
*Remove your RAM
*Clean it with cotton cloth
*Attach the RAM
*Turn on you PC.......
Repeat steps untill it will run normally.....
Jan 27, 2009 | Computers & Internet
Spilt a drink
I don't know if I can solve this here. But the beeping noise is your pc trying to tell you what is wrong with it. Somewhere there are pc beep codes. http://www.pcstats.com/articleview.cfm?articleID=1223 If these can't help you just put "computer beep codes" into google. Here they are:
Beep Code: Description of Problem: No Beeps Short, No power, Bad CPU/MB, Loose Peripherals One Beep Everything is normal and Computer POSTed fine Two Beeps POST/CMOS Error One Long Beep, One Short Beep Motherboard Problem One Long Beep, Two Short Beeps Video Problem One Long Beep, Three Short Beeps Video Problem Three Long Beeps Keyboard Error Repeated Long Beeps Memory Error Continuous Hi-Lo Beeps CPU Overheating
Dec 08, 2008 | Compaq Presario 5000 PC Desktop
HP ZD8000 won't come on
Try to change the RAM and see if that helps the beeping. Normally, repeating beeps mean bad RAM. Not sure what the problem is with the disk drive, seems to be a mechanical problem. Thanks, Lolita
May 15, 2007 | HP Pavilion zd8000 Notebook
Computers & Internet Logo
182 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
