Question about GE Profile 26.6 cu. ft. Side-by-Side Refrigerator with Dispenser TFX27PRBWW
Water on Floor Outside Freezer (Side by Side)
GE Profile TFX27PR Side by Side (10 years old)-water on floor near freezer. Tried putting hot water with baking soda in freezer drain in the back which is obviously clogged. Entire bottom of freezer covered with ice. Got rid of the ice. Hot water not even going down drain. Any other suggestions appreciated!
  • NYTerrier Mar 07, 2009
    Thank you, I put a wire in - it did not go far, and I was able to get 2 cups of hot water down, half a cup at a time (then it would overflow). It appears to hold a half cup at a time. It should be fine now. Thanks for the hlep.
  • Anonymous Mar 17, 2014
    Side by side frame between ref and freezer is hot
  • 700 Answers
Take a wire and run it through the drain until there is no resistance and then put hot water into it.
Posted on Mar 07, 2009
  • Todd Born
    Todd Born Mar 07, 2009
    THANKS FOR THE FIXYA!
Water appearing on floor be side by side refrigerator
Check drain line in the bottom of the freezer, clean and defrost the drain, run hot water until appears in the drain pan under the frig.
Jun 29, 2015 | GE Profile PSW26P Stainless Steel Side by...
I have an 8 year old GE Profile Side by Side TPX24PB Refrig that is leaking water in the freezer, but not the refrigerator. There is a slab of ice on the freezer floor, eventually water runs onto the...
The drain is clogged. Remove the bottom bin out of the freezer. Once done you should see a trough at the back. This trough will be filled with ice, remvoe the ice. Then you have to clear the drain. The best way I know of to do this is to force hot water down the drain with a turkey baser untill water flows freely. Then mix baken soda with water and pour it down the drain. http://www.appliance-repair-it.com/refrigerator-leaking.html
Sep 24, 2010 | GE Profile TPX24PBDCC Side by Side...
Water is leaking onto the floor directly under the freezer of my side by side g.e. refrigerator. Water is frozen in bottom of freezer floor. Is this a costly fix? Refrigerator is 10 years old.
Clean the drain pan and drain line in the back of the freezer section underneath the evaporator coil. Make sure water drains when you pour it in. If it doesn't - also clean drain tube on the back of the unit behind the cover. When done - put the tube exactly where it was.
Good luck! :)
Vlad
First Choice Appliance
May 17, 2010 | GE (PSS26MSRSS) Side by Side Refrigerator
GE Profile leaking onto floor
Clean the drain pan and drain line in the back of the freezer section behind the cover underneath the evaporator coil. (hint: use turkey baster with hot water) Make sure water drains when you pour it in. If it doesn't - also clean drain tube on the back of the unit behind the cover. When done - put the tube exactly where it was.
Good luck! :)
Vlad
Apr 19, 2010 | GE Profile TPX24PBDCC Side by Side...
First thing this a.m. we discovered a puddle of water on the floor on the left side of the fridge. This is not the first time....so we are wondering what is causing this? I am guessing about the profile #...
You have a plugged defrost drain.
Unplug refrig. Unload freezer. Remove shelves. Take back panel out of freezer. Use a turkey baster with hot (not boiling) water to flush water in the area of the defrost drain hole until it is clear and water will run through it into the defrost drain pan under the refrig. The drain is a hole about the size of a nickel, usually in the very back center, below the cooling coils. You can use the turkey baster to force water into and eventually through the drain hole. Remove ice from floor of freezer.
Re-assemble, refill freezer, and plug in. Now, when your refrig defrosts, the water will go out the drain instead of onto the freezer floor and out the freezer door onto your floor.
Aug 05, 2009 | GE Profile PSI23NCR Side by Side...
10 yr old GE side by side: freezer is leaking
Your drain is frozen up and so every time unit goes into defrost the water refreezes in the freezer's bottom. You either have to shut fridge off completely and let it dethaw or use hot water and an ice pick to hurry up the process. The drain is located in the very back of freezer. You will have to pull out the bottom drawer to see it. Good luck
Jun 10, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
GE Freezer Leaking
Open the freezer door, remove the bottom tray, smash the ice on the floor with your fist to remove it. Now get a glass of hot water and pour it into the trough which is at the bottom of the back wall of the freezer. Allow a few minutes for the ice to melt then remove it with an ice pick or scrrewdriver. Once the ice is out, pour more hot water into the trough. Now take a long tube ( an old washer fill hose works perfectly) and stick one end in the hole in the trough. Now fill your mouth with warm water and blow it very hard through the tube. Once the drain is clear, pour some hot water and a very little amount of bleach through the hole.
Apr 06, 2009 | GE Refrigerators
Freezer leaking on Ge Profile
The drain is frozen over and water cannot escape when it defrosts. You will need to remove the back panel inside the freezer and run some hot water down the drain until it has thawed. Hope this helps
Sep 24, 2008 | Refrigerators
Water leaking - GE Profile Refrigerator, Model: TPX21PRX
Check to see if the drain at the bottom of your freezer is plugged. When the refrigerator goes on defrost, the water has to go somewhere. Look below the coils in the freezer section and see if there is ice in the drain.
Jul 15, 2008 | GE Profile 20.7 cu. ft. CustomStyle...
Refrigerators Logo
285 people viewed this question
Top Refrigerators Experts
Sal De
Charles T Nevin
Charles T Nevin
richie46
