Question about Ryobi Garden
Correct way to install the line spool . Do you remove the plastic sleeve that keeps the line in. I have tried withit without it still can't get it right?? Its an old ryobi ret402a
  • Pak Kambling Apr 02, 2012
    Hi, I also have the same problem. Could you share how did you managed fix it? Thank you in advance.
I only just found this solution and it is just what I need. Thank you Jerry.
Posted on Dec 07, 2011
Correct way to install the line spool of an old ryobi ret402a trimmer. Do I have to remove the plastic sleeve that keeps the line in? I have tried with and without it but still can't get it right.
Posted on Apr 24, 2012
How do I load the string?
Hi j_janes....
1 Press the lock and rotate the spool counter-clockwise or some will remove the center knob.
2 Remove the locking ring if your weed eater has one.
3 Take off the automatic feed button.
4 Wipe away any dirt and debris.
5 Push down on the spool to release the locking tabs.
6 Remove the spool from the chamber.
Restringing the Weed Eater
1 Feed one end of the line into one of the holes of the spool, and secure the end that was inserted
2 Wrap the line in the direction of the arrows. Do this until until you fill the spool up with line.
3 Secure each of the lines into its own upper and lower grooves.
4 Re-install the spool into the chamber from which it was removed.
5 Pass the lines into the left and right holes and snap the spool into place.
6 Once the spool is in its sleeve and fed into its left and right eye holes, pull both ends simultaneously.
7 Reinstall the locking ring if necessary, reinstall the center knob.
Please take time to rate me
Jul 03, 2011 | Black & Decker String Trimmer Cordless 12"...
Line installation
Hi bluemontel52...
Hi
Jul 03, 2011 | Poulan Weed Eater Rte115 4.5 Amp Electric...
How to replace string on te475y
Hi jtl91370...
Try this solution...
Jul 02, 2011 | Poulan/Weed Eater No. Te475 952711797 17"...
How can i strimmer wire on a ryobi plt 3043ye
Hi alice louise
Try this method
Jul 02, 2011 | Ryobi 15" Electric Factory Reconditioned...
I need to replace wire on an electric weed eater auto feed 15 inch
Hi deanko1
Jul 01, 2011 | Homelite Garden
I like to know how to wier the line om my poulantrimmer model ppo25\
Hi rlgingas...
Some you will have to remove the center knob.
Jul 01, 2011 | Poulan/Weed Eater No. Te475 952711797 17"...
How do we add line to the trimmer?
Hi jeff clar0
Jul 01, 2011 | Husqvarna 28cc Gas Line Trimmer
Steering wheel changes
Here is the simple steps to change the old steering wheel and install the new one.
Remove the Original Steering Wheel
1.Read instructions that come with the steering wheel, and gather the following tools: screwdriver, pliers and a puller.
2.Point wheels straight ahead.
3.Disconnect battery or pull horn fuse before removing the old wheel. This prevents the horn from shorting out or blowing during installation.
4.Remove the horn mechanism by doing one or more of the following steps: Press down on the horn cap or ring and turn; remove the emblem cap from its snapped-in position by grabbing it and pulling it toward you or prying it loose; or if the horn ring is secured by screws that are concealed in the rear side of the wheel spokes, use a screwdriver to remove the screws and the ring.
5.Remove horn wire or spring-loaded metal plunger from plastic housing by either pulling straight out on the metal plunger or, on most models, by twisting the plastic sleeve to the left and then pulling out. Cut the wire off the plastic sleeve and keep the sleeve for later use.
6.Remove the shaft-nut retainer clip, if it is present, and keep for later use. Remove the shaft nut, which holds the wheel to the shaft.
7.Mark the shaft at the twelve o'clock position so that you will know where to position the top of the new wheel.
8.Insert a conventional puller into the two tapped holes which appear in the hub of the old wheel and pull off the steering shaft.
9.Remove the original wheel.
Installing the New Steering Wheel
1.Place the small tubular metal sleeve down over the steering shaft.
2.Position hub on splined shaft, making certain that the shaft is properly positioned using the mark you made in step 7. You may have to rotate the plastic horn contact tube slightly to align it with the appropriate hole through the hub.
3.Insert plastic sleeve and spring from step 5 without wire into plastic horn housing. If the plastic sleeve extends above the top bolt surface of the custom hub, cut down the sleeve so that it is 1/8-inch below the top of the hub. Remove sleeve.
4.Insert through the plastic sleeve the wire lead that was supplied in the wheel kit. One end will not pass through the sleeve. This bell-shaped end will go into the horn contact housing. Insert the sleeve and wire into the housing and lock into position.
5.Route wire around the hub from the ten o'clock position to about the two o'clock position to properly align wheel. Position post cover and wheel on hub. Make certain that the wire lead passes through the appropriate holes in the two o'clock position. Using the three shoulder bolts provided, fasten the hub, post cover and wheel together, but do not tighten.
6.Check wheel for proper positioning. If correct, reinstall the shaft nut from step 6 and tighten. Reinstall shaft-nut retainer clip. If the retainer does not fit into the groove on the shaft, tighten the nut until it will fit as originally located.
7.Remove shoulder bolts and reinstall them through the retainer ring with the fiber side toward you. Tighten the shoulder bolts with caution - excess torque will result in damage to the hub. The shaft nut, if correctly tightened, will firmly hold the hub and wheel assembly on the shaft.
8.Connect wire lead to the connector on the retainer ring. Position spring on center nut. Align the dimples of the horn cap with reliefs in fiber material and push into the dimples past the fiber. Turn cap left or right until tight.
9.Reconnect battery or replace fuse.
Sep 09, 2010 | 1991 Honda Accord
How do you repace spool
yes becoase it is improtante to replaceit
May 03, 2010 | Worx 12" 4.5 Amp 2 In 1 Grass Trimmer/In...
Water dispenser not working
The reservoir is in the back of the fridge compartment behind the bottom crisper. The inlet and outlet tubes are permanently crimped into the resevoir. I cut them off, drilled out the inlet and outlet on the reservoir, and then used hose clamps when reinstalling.
Nov 26, 2008 | GE (PSS26MSRSS) Side by Side Refrigerator
Garden Logo
1,098 people viewed this question
Top Ryobi Garden Experts
Jim Parker
Jim Parker
Nick Olsen
Rexter1
Are you a Ryobi Garden Expert? Answer questions, earn points and help others
