Question about Philips GOGEAR SA6045 MP3 Player
Everytime i hook my gogear to a computer or any other source it says do not disconnect and freezes. i have tried the tip that said hold the volume button up and the computer says not compatible with windows. if there is any help out there please. because i really want more songs on my mp3 player
  • 8,596 Answers
If you are using a computer that is Running Windows Vista, you need to get the latest version of the Philips Device Manager from Philips website, and upgrade the firmware to make it compatible.
-Tha Mp3 Doctor
Posted on Mar 07, 2009
Stuck on start screen
Try this: disconnect the player from the computer, turn it off, hold in the volume + button, and reconnect the player to the computer while holding the volume + button in. Keep holding the volume + button for an additional 5-50 seconds. Windows should eventually go into recovery mode and revive the player- it will pop up a window that says Found New Hardware Wizard
Then get the firmware upgrade
Jun 24, 2008 | Philips GOGEAR SA6045 MP3 Player
Cant turn my gogear on it Freeze´s
WARNING: this process will erase all songs off the GoGear.
Disconnect the GoGear from computer.
Turn the GoGear off.
Hold in the volume + button.
Reconnect the GoGear while holding in the volume + button.
Continue holding the volume + button.
After 5-50 seconds, Windows will pop-up a "Found New Hardware Wizard." - complete the wizard (BTW, you can take your hand ff the volume + button now).
Good To Go (Gear)!
-Tha Mp3 Doctor
Mar 26, 2008 | Philips GoGear HDD060 MP3 Player
It keeps say plug mp3 back t pc
First, try resetting the GoGear by pressing the Power on/off and Volume + buttons simulataneously and holding them (preferably do this when the player is on; the reset is successful when the player shuts off).
If that fails, Back up all the files on the GoGear and perform a Repair:
1) Open up Philips Device Manager (Start --> All Programs --> Philips) - if you don't see it, then re-run the installation CD or grab the "Device/Firmware Manager" from the Philips website
2) Click on the Repair Tab, and look for a msg that says connect the player while holding the volume + button
3) Disconnect the GoGear from the computer and turn the GoGear off (if you haven't done so already) - hold in the volume + button and continue to hold it as you reconnect the GoGear to the computer; after holding the volume + button for up to 20 or 30 seconds, a window will open up saying that your device is being repaired (now you can let go of the volume + button); after the repair is successfully complete, your GoGear will be good as new.
In the future, even though it's a pain, use Windows' "Safley Remove Hardware" feature to safely remove the GoGear from the computer before disconnecting.
Also, see the warning on Philips website about Windows Media Player 11 and this device.
-Tha Mp3 Doctor
Feb 01, 2008 | Philips GoGear HDD6330 MP3 Player
Please help
WHEN that fails, Back up all the files on the GoGear and perform a Repair:
-Tha Mp3 Doctor
Jan 30, 2008 | Philips GoGear HDD6330 MP3 Player
I need Help
I would recommend you to get the firmware upgrade on the device..that usually happens when your device firmware is corrupted...If after you done a firmware upgrade your device doenst work properly contact the manufacturer...
Thank You
Computerrep
**Rate accordingly..
Jan 01, 2008 | Philips HDD1630 MP3 Player
Can not download music
Try repairing the device before performing the firmware upgrade:
Make sure you back up all songs on the GoGear before attempting this solution.
1) Back up all files on the GoGear
2) Open up Philips Device Manager (Start --> All Programs --> Philips)
3) Click on the Repair Tab, and look for a msg that says connect the player while holding the volume + button
4) Disconnect the GoGear from the computer and turn the GoGear off - hold in the volume + button and continue to hold it as you reconnect the GoGear to the computer; after holding the volume + button for up to 20 or 30 seconds, a window will open up saying that your device is being repaired (now you can let go of the volume + button); after the repair is successfully complete, your GoGear will be good as new
Now you can do the firmware upgrade that will prevent this problem from occuring in the future. Open up Philips Device Manager and click the Update tab. This problem was caused because most GoGear's were designed for Windows XP with Media Player 10 (which is no longer the latest standard).
-Tha Mp3 Doctor
Jan 01, 2008 | Philips GoGear HDD075/17 MP3 Player
It freezes up and wont read
-Tha Mp3 Doctor
Dec 28, 2007 | Philips SA5125/37 MP3 Player
Cant delete music
-Tha Mp3 Doctor
Mar 15, 2007 | Philips GoGear HDD6330 MP3 Player
Freezing problem
-Tha Mp3 Doctor
Sep 02, 2006 | Philips GoGear HDD084 MP3 Player
Freezing
-Tha Mp3 Doctor
Aug 10, 2006 | Philips HDD1630 MP3 Player
Philips GOGEAR SA6045 MP3 Player Logo
44 people viewed this question
Top Philips Audio Players & Recorders Experts
Gyula Lacz
Are you a Philips Audio Player and Recorder Expert? Answer questions, earn points and help others
