Hi have a Whirlpool "Slim-Twin" Washer/Dryer combo. The dryer works perfectly. The washer however will not start at ANY cycle type. The agitator will also not turn, although I don't know if it's even supposed to turn before a cycle has started. I am not really sure what to even check. Any ideas would be greatly appreciated. Thanks!
I've been researching this model a little bit, I think there are 2 fuses inside, but I dont know where. If I have to take mine apart, I'll let you know.. Did the machine ever run, or did you just get it. Is there 2 cords to your machine a 220 cord and a 110 cord, or does the washer just run off the 220, but your washer doesn't work, so you dont really know, but if it has two cords, could you let me know, so I can find the end of mine ha..thanks chuck
Item #2986 (OEM Part)
$10.70
Thermal fuse. If the dryer overheats, this device stops the flow of electricity to the heat source and/or the entire dryer. It is located on the blower housing and cannot be reset. The most common cause for overheating is a vent tube clogged with lint, a birds nest or other debris.
Manufacturer Number 3392519
More
In Stock
Quantity:
http://www.repairclinic.com/PartDetail/Thermal-Fuse/3392519/2986#repairHelpVideoTabs
There
can be many reasons why your dryer will not start or turn...
The
most common causes are the belt breaking or jumping off, or the motor
going bad...
Here are a couple of tips that I wrote will help
you to figure out why your dryer will not run...
Dryer Repair
- The Dryer
is not Turning
Dryer
Repair - The dryer
will not start
heatman101
