Question about Intertherm P3RA-048K Air Conditioner
Where do the filters go on the Intertherm MGH055AB?
I moved into a modular home. It has an Intertherm
Furnace which is collecting lots of dust and spreading it throughout the house. The filters were not in it. Does anyone know what kind of filters I need to purchase and where they should be placed?
Thanks, Kathie
    Scholar:
  • 144 Answers
The filters on an Intertherm usually go on the inside of the front panel
Posted on Mar 06, 2009
Intertherm electric furnace modular home
Will be to clean each contact-switch and scrape the contacts and use wd40 and spray of air and remove all rust, its possible that exist another options of failure.
Jun 17, 2012 | Heating & Cooling
How to install an intertherm furnace filter for MGHA-070AAFC-02
Hi, this is a 4 ton package unit, most filters are in the home. There should be a drop down grill somewhere in the home, maybe more then 1. If not, the filter would go on the blower back side of the evaporator coil. Remove the panel and see if it has a slot for a filter.
Shastalaker7
Nov 07, 2011 | Intertherm P3RA-048K Air Conditioner
Where can i buy filters for a intertherm furnace in zebulon nc or raliegh nc?
I am not familiar with your area in particular but furnace filters are normally available at home and harware stores. Most air filters are 1inch thick, or close that dimension. You should measure the length and width and find one of the same size. Don't worry about high effeciency filters, all the furnace needs is a basic filter.
Oct 16, 2010 | Heating & Cooling
I have a Nordyne/Intertherm electric furnace #E2EH-012 in a mfg home I just moved into. The Handy Man removed a 16 x 20 x 1 filter (very dirty) from "somewhere". I'm not sure where a replacement filter...
The filter will go in to the backside (inside) of the cover with fins in it. There is a 1" (approx) bend (lip) there to hold filter in against backside of cover, in front of air vents. You may have to bend it slightly to get it in there but it will eventually fit in there snug. Incoming air will then be filtered as it is drawn through that filter, into blower area.
As far as fan switch goes, "auto mode" will be used when furnace is on, and fan will come on & off as necessary to dissipate heat as required. "Ventilate", should be basically same as "On", where the fan comes on to circulate the air throughout the home, just for airflow, and you control it manually.
So, when using furnace, have fan in "auto Mode".
Oct 10, 2010 | Heating & Cooling
We have an Intertherm furnace in our manufactured home which is apparently a replacement furnace as this is not the brand showing on the original paperwork for the home. Problem is that it is very loud. ...
That is a common furnace for manufactures homes and yes they are loud....that is because there is no return duct on the unit and the fan sits jsut inside the door so the noise is not contained...
short of moving the furnace there is not much you can do about it...yes it stinks I agree with you... wish I could give you better news...
heatman101
Aug 08, 2010 | Intertherm P3RA-048K Air Conditioner
Where are the furnace filters in my older furnace?
Open the door to the airhandling unit inside the closet by lifting upward on them. There should be two filters located on top of the A coil.
Dec 05, 2009 | Heating & Cooling
I NEED A FILTER FOR MY 1991 HOBILE HOME FURNACE IT IS A INTERTHERM MODEL FEH-015HA-04 NOROYNE SERIAL FEH 9105-00229
Best things to do is find your Return grill in the home.
Get a measuring tape and measure the Hole size with the grill removed, Or filterback grill whatever the case.
Then simply go to a home retailer with the size, or in rare cases you may want to consider a Hogs hair washable filter that can be cut to size, to fit it perfectly.
Oct 21, 2009 | Intertherm P3RA-048K Air Conditioner
I think I have the wrong air filter in electric furnace
Measure the width and length, then buy a filter that size.1" is correct for thickness.
The arrow points into the return. Not into the room.
Feb 18, 2009 | Intertherm P3RA-048K Air Conditioner
Smoke coming from furnace
You may have something (paper,dust, etc.) on the electric coils. There may also be a short in the element.
Mar 24, 2008 | Intertherm P3RA-048K Air Conditioner
Intertherm P3RA-048K Air Conditioner Logo
1,402 people viewed this question
Top Intertherm Heating & Cooling Experts
Dennis Boxerman
Dan Webster
Dan Webster
Bill Long
Are you an Intertherm Heating and Cooling Expert? Answer questions, earn points and help others
