Question about Westinghouse WRS3R3EW 33" 22.6 Cu. Ft. Side-by-Side Refrigerator w/ Plastic Freezer Basket, 4-Button...
I think the evaporation pipe is clogged. how do I unclog it?
How do fix it
Posted on Mar 06, 2009
Ice in the drain. Where does the drain pipe empty?
Usually into a pan under the condenser coils on the bottom of the refrigerator. Sounds like the drain is pinched or obstructed, since it should drain without a problem. The water is evaporated from the pan by the heat from the condenser coil.
Mar 28, 2015 | Refrigerators
How to unclog KFCP22EXMP drain line
You could... run a pipe cleaner upward from the drain tray, Jeannie. I'll bet that it's frozen, though.
Aug 12, 2014 | KitchenAid Pro Line Series Counter Depth...
Why does my air conditioner leak water on passager side floor
The Evaporator box has a Drain tube, this is blocked and not letting the water drain off ,hence the build up of water in the box which will overflow into the passengers side .
The drain tube needs to be unblocked to let the water drain off.
Jun 12, 2014 | 2001 Mitsubishi Montero
Nissan quest sunroof drain clogged
open your skylight and feel in the front corners for muck stuck infront of the drainage holes. Use a pipe cleaner or other wire to poke through the holes and the water should drain out. It is a little difficult to see the holes but just feel around.
Apr 18, 2013 | 2004 Nissan Quest
Whirlpool duet sport is clogged. Water is bypassing the detergent dispenser, and leaking out of the washer. No water is entering the washer. HOw can it be unclogged?
If you take the drawer out you may be able to gain access to where the clog is, if not remove the lid of the machine and you will see the fill hose from the drawer to the tub. You may be able to remove the pipe without removing the dispenser housing or you may be able to get to the blockage by removing the pipe from the drum.
Dec 28, 2012 | Whirlpool Washing Machines
Condensation water is leaking out of the bottom of the unit on all sides
Hello, usually a clogged condensate line or cracked condensate pan will cause this. try using a wet/dry if you have one to unclog the drain by attaching the hose to the end of the condensate line, the line will be made of PVC pipe. if this does not help than the condensate pan under the evaporator coil is cracked and will have to be replaced. in some cases if your unit uses a condensate pump that could be the problem aswell if it;s clogged or not pumping.
Aug 18, 2011 | Carrier 38CKC036 Air Conditioner
Drainage problem-water is coming out of the air vent inspite of the drainage pipe
The drain pipe may have come loose or it is clogged. I bet on it being clogged. They are not difficult to unclog, using something like a flexible Zip Tie about 18" - 20" long and small enough to fit into the drain tubing. It will help to **** out the clog.
Hope this helped you solve the problem.
Apr 25, 2011 | LG Heating & Cooling
'I" have water leaking on
You didn't say inside or outside. If it is inside, your overflow on the evaporator is clogged, a small pipe on the pass side coming out of the firewall, stick something in there and get it unclogged. If it is outside, how much water? Is it coolant or water? Is it from the evaporator or the radiator. Front or middle? Check it out, find out where it is from and what it is.
Feb 03, 2011 | Mazda MAZDA6 Cars & Trucks
Wet passenger floor pan
clogged drain line for the a/c evaporator, use a stiff wire or pipe cleaner to unclog line. Located on passenger side underneath car nest to firewall. Good Luck Tim
Oct 19, 2010 | 2005 Chrysler Sebring Conv
Overflow draining to the sink
it's supposed to drain out the same drain pipe your sink uses. If it is overflowing into your sink, then your drain pipe is clogged. Your sink probably overflows when your disposal runs too, right? Unclog your pipe and you're good to go.
Jan 11, 2010 | KitchenAid 24 in. KUDI01FLSS Stainless...
Westinghouse WRS3R3EW 33" 22.6 Cu. Ft. Side-by-Side Refrigerator w/ Plastic Freezer Basket, 4-Button... Logo
156 people viewed this question
Top Westinghouse Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Are you a Westinghouse Refrigerator Expert? Answer questions, earn points and help others
