Question about Nintendo DS Console
How do you fix bent pins on a Nintendo ds?
Or does anybody fix that in the South Bend, IN area?
SOURCE:
  • 4 Answers
SOURCE: Fixing nintendo ds lite card slot
u would probobly have to go get a new one or send it off to be fixed and get a reconditioned ds
Posted on Feb 28, 2008
xedcom
  • 127 Answers
SOURCE: nintendo ds
I would say you to send it to repair but that cost money and you have nothing to loose actually so first option is to try it yourself. You need a straight long tweezers like the second from top in the picture.
And a flashlight to iluminate the internal slot1 where the pins are. Then check which ones are bent and try to repair them carefully with the tweezer being more careful not to broke any.
In case you find any broken pin then you have to send it to repair at nintendo or to another videogame repair shop as it need desolder the whole broken slot1 and replace it with a good one no matter if new or used as long as it is good.
Good Luck...
Posted on Aug 02, 2008
SOURCE: nintedo ds lite
Yes it can can cost anywhere from $20 up
from any Repair shop
Posted on Sep 06, 2008
xedcom
  • 127 Answers
SOURCE: ds old slot pins bend
Its difficult to repair that without right tools, and even with the tools is still hard to do it.
Depending on how much bent are the pins you would need to rectify the bad pins with very small pliers or tweezers and a flashlight, you can also desolder the bent pins and take em out the slot to repair one by one and insert again in the slot. The most of the cases you would take the risk to break pins and then need to try the next solution.
Replace the whole Slot1 buying it on ebay or other place, or you can take it out from a parts DS, but you should need a soldering iron, blade and patience to get the slot1 out of the mobo. The ideal tool is a hot air soldering station but its very expensive. Or you can get a parts DS with good mobo and replace it for your bent slot one which is the best option.
Posted on Sep 28, 2008
DLBurkhart
  • 210 Answers
SOURCE: nintendo ds lite - son
The part with the damaged pins is the slot-1 port. I know it seems rediculous, but it is too impractical for most people to attempt a repair to this part.
However, if you are savvy enough to attempt the repair of the damaged pins on your DS Lite, here are my recommendations:
1) Cut a flap in the slot-1 port cover and straighten pins.
2) Replace the main board.
3) Remove the slot-1 port cover and straighten pins.
4) Remove the damaged pins from the slot-1 port and straighten.
5) Replace the slot-1 port.
All of these recommendations require disassembling the DS Lite using a specialized triwing (or Y) screwdriver and a lot of patience. The following video will help in disassembly: http://www.youtube.com/watch?v=HQlTpTLUyFQ.
Recommendations 3 to 5 all require solder work. Recommendation 3 requires solder work for 4 solder joints, 1 at each corner. Recommendation 4 requires solder work for up to 17 solder joints, one for each damaged pin. Recommendation 5 requires solder work for all 21 solder joints
Posted on Jul 10, 2009
Hiya have bent the piuns in my daughters ds are u ablke to fix this and how much would this be thanx
Try finding something like a small screwdriver, or a small set of tweezers that you can use to bend the pins back. Be careful since they can easily be broken off, or bent further if you use too much force.
Oct 23, 2012 | Nintendo DS Lite White Console
When i insert in a game in my nintendo ds lite it says there is no game inserted and when i insert a gba game into it it works please help me! thx
Check the SLOT 1 for bent pins. You will need to look inside the slot, preferably with a torch and see if any pins are bent out of shape. If you see any bent pins, use a small screwdriver to gently bend the pin back to where it should be. Check also for any foreign items in the slot which may prevent correct contact.
Mar 10, 2011 | Video Game Consoles & Games
Nintendo ds not charging
The metal in the end you plug into your ds must be bent. This happened to me. Just use pliers or scissors to bend it back.
Aug 19, 2009 | Nintendo DS Console
Nintendo DS lite Slot 1 bended pins
You can do it yourself by removing the casing, check out this youtube video. http://www.youtube.com/watch?v=vRzTgfo2PsM
Please rate my responce
Jun 03, 2009 | Nintendo DS Lite Console
How do you remove and open the ds card slot?
You push down your DS card to get it out ,and to put it in you take the card you want and push it in slot 1.
Jan 06, 2009 | Nintendo DS Lite Console
Nintendo DS not reading games
Some pins were bent in my son's DS. I used a mini LED light and an open paper clip as a pick to bend them back into line.
I then got an Emory board (nail file) and wet the tip in alcohol, the board is the right thickness to just reach the copper pins. I went in and out gently as I worked my way across the lot and kept wetting the file with alcohol. All the games worked like it was new. be sure to do this upside down so the alcohol drips out the slot along with the filings. good compressed air blow after you are done to get all the strays out of there.
The pinds are copper and they do oxidize and the games left in gets moisture trapped between the game and the pin causing some corrosion. Maybe diddimilar metals by alloy but wither way this fix works ! : )
Sep 21, 2008 | Nintendo DS Lite Console
Ds old slot pins bend
Aug 14, 2008 | Nintendo DS Lite Console
Nintendo ds
Good Luck...
Jul 30, 2008 | Nintendo DS Lite Console
Nintendo ds lite won't read card
had this problem, i looked into where the game goes and one of the little metal teeth was bent, so i took a long toothpick and gently pushed it back over now it works fine. Be careful that you dont break it off though.
Feb 08, 2008 | Nintendo DS Lite Console
Nintendo DS Console Logo
781 people viewed this question
Top Nintendo Video Game Consoles & Games Experts
Raj Patel
Julian Wainwright
Ekse
Are you a Nintendo Video Game Console and Game Expert? Answer questions, earn points and help others
