Question about HP OfficeJet 7110 All-In-One Thermal Printer
HP Officejet 5510 all-in-one Fax just stopped working. Can get no dial tone.
  • Anonymous Apr 26, 2009
  • 2,120 Answers
Check the phone line with a regular phone.
Posted on Mar 07, 2009
Can not send or receive faxes. Have successfully performed and passed the 6 components of the HP Fax test. Can hear dial tone when attempting to fax.
Dial from printer to your mobile phone sense the ring then send the fax sense the fax tone if fax tone not hearing you replace formatter ...
Sep 08, 2011 | HP Officejet 5610 All-In-One InkJet...
5510 all in one, my fax has stopped working. I reinstalled the 5510, the wizard set up my fax, it rings, picks up, BUT doesn't do anything else. Try to send and it sounds like it doesn't dial out? It...
First, I would suggest suggest you reset the FAX. If resetting does not solve the problem, you can then read and follow instructions on this link;
1. Remove all of the paper loaded in the main input tray.
2. Press the power button to turn off the HP fax product.
3. Disconnect the USB cable from the back of the HP fax product.
4. Disconnect the power cord from the back of the HP fax product and from the electrical
outlet, and then wait one minute.
5. Reconnect the power cord to the electrical outlet.
6. Reconnect the power cord to the back of the HP fax product.
7. Press the power button to turn on the HP fax product.
8. Reconnect the USB cable to the back of the HP fax product.
9. Replace the paper in the main input tray.
10. Use the HP Fax Test Service to try to send and receive a fax.
Good luck.
Mar 24, 2011 | HP Officejet 5510 All-In-One Thermal...
Officejet 6310 fax does not work incoming or outgoing
Hello sir; would you take one phone hook up with this phone jack,if there have dial tone,that's means fax modern defective, if no dial tone that's means this phone jack is not active.
Jan 26, 2010 | HP Officejet 6310 All-In-One InkJet...
When I turn my hp officejet 5510 all in one ink cartridge it says the print cartridge error see the product documentation for detail copy fax, scan are all blinking.
When lights stop blinking, you have solved the problem.
Nov 28, 2009 | HP Officejet 5510 All-In-One Thermal...
Hp officejet 5510 fax issues
Have you run through the setup procedure detailed in the User Manual? Unfortunately it is far too large to post here. Can you receive faxes OK? If you don’t know just dial your fax number from any phone and see if it answers and you can hear fax garbage noise down the phone. If so then that is a positive sign. If you get stuck then drop me an email to and I can email you a full check and test procedure for this model.
Jul 16, 2009 | HP Officejet 5510 All-In-One Thermal...
HP OfficeJet 4215 can not send fax
Check for dial tone at the fax machine
Plug in a telephone on the cable from the wall.
Do you get a dial tone?
Something is wrong with the fax machine.
Call the phone company or a telephone repairman.
May 27, 2009 | HP OfficeJet 4215 All-In-One InkJet...
Machine shows "phone off hook"
Hi there
check where your phone cale goes into the machine you will proberbly find two sockets one marked phone and one marked line the phone line needs to go into the one marked line and a phone handset in the one marked phone if this is correct try ringing yor line that the fax is plugged into see if you get a ring or engaged tone if you are getting engaged unplug the fax and try again if this now works the chance is that the modem board in your fax has failed and will require replaceing
Regards AL "alstech"
May 18, 2009 | HP Officejet 5510 All-In-One Thermal...
Office jet all in one printer 4215
If you are using speed dial to dial the fax number, the HP Officejet
might be dialing too fast or too soon. To solve this problem, try one
of the following:
Try manually dialing the fax number from the HP Officejet front
panel, or from an attached phone. For information, see send a
fax using monitor dialing
on page 43 or send a fax manually
from a telephone
on page 43.
Re-create the speed dial setting and insert some pauses. For
information, see create individual speed-dial entries on
page 56.
If your telephone line has a PBX system, make sure you are dialing
the number for an outside line before dialing the fax number.
The receiving fax machine might be having problems. To check this,
try calling the fax number from a telephone and listen for fax tones.
If you cannot hear fax tones, the receiving fax might not be turned
on or connected, or a voice mail service could be interfering with
the recipient’s phone line.
May 07, 2008 | HP Officejet 4215v All-in-One Printer
HP Officejet v 45
Do you actually have a dial tone on the phone line?
It will still dial without a dial tone.
Plug a phone into the line ans check for the presence of a dial tone. I suspect that to be your problem.
Mar 31, 2008 | Computers & Internet
HP 5510 Faxing problem
hello jeremy
some guides and help from there site here see if this will help you .
Feb 22, 2008 | HP Officejet 5510 All-In-One Thermal...
HP OfficeJet 7110 All-In-One Thermal Printer Logo
109 people viewed this question
Ben Johnson
