Question about HP DeskJet 6840 InkJet Printer
Replaced the black cartridge on my 6840 (which had been working fine until now when it ran out of ink). I keep getting a message that there is a problem with the right cartridge and to remove and replace which I have done to no avail. Thanks to anyone who can help. I noticed that when I insert the color cartridge I get a "soft" click which I don't get with the black one. Holden
  • 4 Answers
It seems to me thar the contact pin in the cartridge slot is broken,try to clean the printer contact with cotton moistened with water ,if it doesn't work service your printer
Posted on Mar 07, 2009
Black Cartrige Missing
Did you use a brandname ink cartridge - or is it a knock-off brand? If it is a brand name - then the cartridge is most likely defective. If it is a knock-off brand - some printers do not recognize the electronic in the cartridge and therefore don't see it as one being installed.
This may also help
Dell 922 AIO Black Ink Cartridge Missing Message
May 02, 2017 | Dell AllinOne Multifunctional (v515w)...
Computer cannot communicate with printer
Check if your printer is up to date. Just go to http://bit.ly/ghfW8H to download the firmware update.
Also, make sure that you're using genuine Lexmark cartridges. If there's an error message on your screen that your black ink is low even if you replaced it, you won't be able to print or scan. It will send a busy signal or communication not available to your computer. If this is the case, replace the cartridge.
If it still doesn't work work, try to reinstall the software: http://bit.ly/d3ftso
May 11, 2012 | Lexmark 90T9105 - Pro 901 All-in-1
I have replaced black ink but printer keeps telling me to replace black ink cartridge
If the it's a remanufactured cartridge (not genuine), the printer will not detect the ink in the cartridge.
If it's genuine, you might want to give Lexmark's technical support a call to have the cartridge replaced.
May 05, 2012 | Lexmark X4650 InkJet Printer
My black ink ran out so I replaced the ink
Hi:
I have used the printer series that you have for years, and once in awhile, I get a new cartridge that won't immediately print. Often, there is just a bit of dried ink residue on the print head, and that won't allow the cartridge to work correctly.
Some simple things to try are :
1) Remove the black cartridge. and take a damp paper towel and gently swab the print head area. Next, apply some pressure to the sides of the black cartridge, until you see black ink oozing out of the print head. Repeat if needed. Once the ink starts flowing, blot off the excess, and install the cartridge.
If you can't get ink to flow, then the cartridge might be bad. Most of them have an expiration date on the packaging.
Mar 31, 2010 | HP DeskJet 960c InkJet Printer
PIXMA ip1600 I have installed a new Canon Black
You will need to hold the button under the light until it stops flashing. This should resolve your issue
Sep 17, 2009 | Office Equipment & Supplies
Why won't my CX9400F recognize Epson ink cartridges
The Epson CX9400F printer seems to require replacement of all the color ink cartridges, even if only the Black is empty.
I print almost exclusively in Black, but with my first change of Black, I was forced to change all the color. At the time I thought Epson did not provide completely filled color ink cartridges.
Just yesterday, I replaced Black and the printer complained it did not recognize the rest of color cartridges. So I replaced all the other color ink cartridges and now it works fine.
You might want to check out www.clickinks.com for cheaper, mail order alternatives which are Epson ink compatible, if you are not in a hurry.
ew
Feb 23, 2009 | Epson Stylus CX9400 Photo Printer
Black and white not printing correctly, color is fine
If you are not using Epson ink, your printer will do this. Epson printers hate knock-off ink. Always use Epson ink if you want to keep your printer working properly. To solve the problem you are having, try cleaning the ink tubes. Make sure you re-install them properly. Hope this helps. Charlene
Feb 10, 2009 | Epson Stylus CX3810 All-In-One InkJet...
No black print
I just installed a new black ink cartridge and it won't print. My new color one will. It worked fine until it ran out of ink and I replaced it with a new one.
Dec 06, 2008 | Dell A940 All-In-One InkJet Printer
Dell 922 All In One Printer wont print
did you remove the seal of new catridge. bye
Sep 24, 2007 | Dell 922 All-In-One InkJet Printer
HP DeskJet 6840 InkJet Printer Logo
123 people viewed this question
Seeker5211
Seeker5211
