Question about Arris DSR922
Have a DSR 922 that I can not get W5 to program in the satellite list. When I highlight it and push enter it all ways returns to the current satellite I was on, insted of letting me move the dish to the W5 location to set it in memory and save. All the others work OK. Have not had any programming service for a few years. Only use it for the free service and a Pansat FTA receiver. Do you think it needs a hit and if so how can I do it since I have no provider.
Do not know if I solved the problem yet. Went on Skyvision site and somebody had the same problem. They told him he would have to do a Master reset, and reprogram all satellites and east/west limits. Just haven't had time to do this yet. Will let you know if it works.
Posted on Mar 07, 2009
How do I set position on my lowrance hdi 7
The GPS will automatically triangulate your position and display it on the map screen.
If you have your cursor turned on the the map screen will remain centered on the cursor.
while on the map screen push the Menu key and then the Enter key. If you notice the pop up window when you push menu you will see the first field highlighted will be to return to current position or something similar. By pushing enter you are selecting this option and the unit will display your current position on the map screen.
Oct 17, 2014 | Lowrance Elite-7 HDI...
Boot order change to boot from cd on thinkcentre m57p
I beg to differ........
AS SOON AS you press the Power On button, start tapping on the F12 key. Tap in 2 second intervals.
If you hear beeps ignore them. They are Stuck Key Error Code beeps, and it is you that is doing it.
In the Startup Menu do you see CDROM listed?
You cannot use your mouse anymore. You have to use the Keyboard.
Use the appropriate arrow key, and highlight -> Start
Press the Enter key.
Now use the appropriate arrow key, and highlight -> Start Sequence
What does it state on the Right side?
The right side, and the bottom is the Navigation guide. Does NOT state navigation guide.
If you see the various boot devices listed in an order, you need to highlight the first boot device;
Or,
You need to highlight CDROM.
Using the appropriate key to Change Value (Look at navigation guide at bottom), move CDROM to the Top of the list.
Key is usually the Page Up/Page Down key; or +/- key.
(Plus { + } / Minus { - } key)
If you can only highlight the first boot device in the list currently, highlight it; then use the appropriate Change Value key, to move it in the list.
Move it until CDROM appears at the Top of the list.
(Note* You may have to highlight the first boot device, then press the Enter key; then use the Change Value key )
If you can highlight CDROM, then just use the appropriate key, and move it to the Top.
(You may have to highlight CDROM, then press the Enter key. Then use the Change Value key)
After you have moved CDROM to the Top of the list, press the Enter key.
Now select Save Settings, or Save and Exit.
I'm looking at the HMM (Hardware Maintenance Manual), but it does not go into very much detail for BIOS Setup.
I'll need your eyes. Tell me what you see, and what is going on; if the above is not correct.
Post back in a Comment.
Regards,
joecoolvette
Apr 11, 2013 | Lenovo ThinkCentre Computers & Internet
How to program channel without remote
First be aware that if you are using an antenna this television has an analog tuner which is no longer capable of receiving any digital signals which is the only channels being broadcast as of June 2009. If you have a cable or satellite receiver then here is the procedure for auto programing your channels. Make sure your active cable/satellite is plugged into Ant 1 (Antenna 1) on the back of your set.
On the front panel push the menu button until the "Channel" is highlighted. Then push either the plus button or the down button to highlight auto program.
Once that is done push plus or up and the set will automatically tune in all the available stations
Zashiban
Jun 04, 2010 | Sony FD Trinitron WEGA KV-27FS100 27" TV
How to remove subtitles from sony bravia tv screen
You can download the user manual here.
http://www.retrevo.com/support/Toshiba-57H84-TVs-manual/id/311ag813/t/2/
The closed caption feature has two options:
• Captions—An on-screen display of the dialogue, narration, and sound effects of TV programs and videos that are closed captioned (usually marked as “CC” in TV listings).
• Text—An on-screen display of information not related to the current program, such as weather or stock data (when provided by individual stations).
To view captions or text:
1. Tune the TV to the desired program.
2.Press MENU, and then press x or • to display CUSTOM menu.
3. Press y or z to highlight CC, and then press ENTER.
4. Press y or z to highlight CAPTION or TEXT, and then press Enter.
To turn off the Closed Caption feature:
Highlight OFF in step 4.
Apr 09, 2010 | Toshiba 57H84 57" Rear Projection...
I need to reboot my Dell, due to a virus. I can't find my CD, so help!
Hello, I can help you. Follow the steps below:
1) Immediately after pushing the power button, Press F8 to go to the Advanced Options Menu. Use down arrow buttons to highlight REPAIR YOUR COMPUTER and Press ENTER.
2) Follow the On-Screen Directions to Restore Your Computer to Factory Settings.
NOTE: By doing this, you will lose all previously save work as well as any other programs, etc. you may have added to your computer. It will return your system to the state in which it was from the factory.
3) When you have completed the Restore, you should then go to your Dell Support Website and Download/Install any & all current updates for your system.
4) Install an Anti-Virus Software Program to prevent further Virus Attacks.
5) Go to the Windows Updates Website and Choose Automatic Updates.
That should do it for you. Be sure to follow the steps in the order in which I have listed them above. GOOD LUCK!! Lucky4lynn2 :)
Mar 18, 2010 | Dell Inspiron 1525 (dndppa1_3) Intel Core...
DSR 922- to begin with it wouldn't shut off, no function will work with the remote, unplugged it and replugged it and now there is nothing but the inspirational channel on G3 217. H20
IF the receiver lost its sat settings you had, you best check the internal battery. the lithium battery should be 3.70 volts...if its dead you need to replace it, without interupting the power source...this will also cause you to lose your unit ID number. then you won't be able to subcribe to programming...the 922 can be repaired if the battery dies.
Jul 09, 2009 | Arris DSR922
How to load w5 satellite manually in my 4d-922 receiver
Lost W5 & X4 on myDSR922 how can i get them back?
Apr 08, 2009 | Arris DSR922
Dsr 922 no dc light on g1 etcs
you are not on the satellite. need to reporogram or fine tune these satellite into receiver.
Oct 11, 2008 | Arris DSR922
Need parts for dsr 922 4d satellite receiver
have a few receivers one with front cover tacked on as bracket broke all receivers are working and in great shape accept the one with the face plate tacked on but it works like a gem also will be listing on ebay soon
Apr 13, 2008 | Televison & Video
Motorola dsr 922 satellite receiver
Sorry , I have a Motorola DSR 922 problem which has nothing todo with a phone. I was crusing around looking for online help and did not relise this was a phone only site.
Mar 07, 2008 | Motorola Mobility RAZR V3
Televison & Video Logo
315 people viewed this question
Top Arris Televison & Video Experts
Electro Med Services...
Are you an Arris Televison and Video Expert? Answer questions, earn points and help others
