Question about Baby Lock Imagine
Tension settings I need help adjusting the tensions
    Problem Solver:
There is no tension setting on the imagine. That is the beauty of the machine.
Posted on Apr 12, 2009
I have a Necchi Omega 6147. How can I adjust the drop-in bobbin to use upholstery thread to sew heavy fabrics or leather?
You would need to adjust the tension screw so the tension is looser than usual. However, remember to mark the setting BEFORE making any adjustments so you will know where to return the original setting.
Bobbin Tension How and Why Tension is Adjusted
Understanding Bobbin Tension
Understanding Thread Tension Threads
Feb 10, 2017 | Necchi Sewing Machines
How do I set the bobbin tension
How to change the tension on a sewing machine?
Adjust your top tension if it's too tight. To decrease your top tension if it is too tight, turn your knob so the numbers are decreasing. Try ½ to 1 number lower, then test the stitches on a piece of scrap fabric. Continue until it looks even on both sides and you can no longer see the bottom thread on the top.
How to Adjust the Tension on a Sewing Machine: 13 Steps
www.wikihow.com/Adjust-the-Tension-on-a-Sewing-Machine Search for: How to change the tension on a sewing machine?
https://www.google.co.uk/webhp?sourceid=chrome-instant&rlz=1C1CHBD_en-GBGB719GB719&ion=1&espv=2&ie=UTF-8#q=Sewing+Machines+How+do+I+set+the+bobbin+tension ..try this link
Dec 04, 2016 | Sewing Machines
Try sewing but bottom thread on fabric is crumpING UP
needle thread tension is not adjusted up properly tighten the setting until you have resistance when you pull the thread to thread the needle
Oct 02, 2016 | Sewing Machines
What are the correct top & bottom tensions for this machine?
Both tensions are preset at the factory. Normally, the bobbin tension is the last one to adjust. Most often tension adjustments are made to the top thread. The factory standard setting for the upper thread is the midway point between the high & low numbers, however, each machine is different and may need slight readjustment.
The tensions are correct when both, the upper and bobbin, threads meet in the middle of the fabric. Tension is not static. Differing fabric weights, thread, or needle sizes may necessitate a change to tension. Lighter weight fabrics like chiffon will require a different tension setting than heavy fabrics like denim. Always test first on scraps of the fabric you plan to sew. Get the tension set the way you want it before you begin sewing your project.
Learn the Ins and Outs of Troubleshooting Sewing Machine Tension
Adjusting Sewing Machine Tension to Prevent Problems
How to Adjust Tension Sewing Machine
Mar 04, 2016 | Sewing Machines
How do I determine what tension to use?
Tension setting is trial and error. To learn choose two color threads same weight and manufacture. placing one in bobbin other top tread.
Set the lower tension to light. The lower tension has always been lower than the top.
Depending on needle size and material the upper needs to be set.
Use the images as a guide.
26050009-gmetzlbygkf20izcnwtcwtjv-4-2.png Hope this helps?
Jan 12, 2016 | Sewing Machines
How do I set bobbin tension?
Generally bobbin tension is the last thing to try to adjust on your machine. Most sewists adjust the bobbin tension ONLY if they are using very lightweight or very heavyweight thread in the bobbin. Most sewists will advise to make all possible adjustments to the top tension before tackling the bobbin tension to resolve issues.
Try searching YouTube videos or this may be helpful:
Setting the Bobbin Tension on your sewing machine
Liz Kettle adjusting your bobbin case tension 1 wmv
How to fix Tension Don Panic
Sep 27, 2015 | Janome Memory Craft 3000
How do I adjust the tension on the bobbin. My stitches are too loose.
Your objective is to have the top and bobbin tension equal. Once you have set the bobbin tension you will adjust the top tension until the knot is in the center of the fabric. A good starting point for the top tension is four.
I've attached a guide to help you set your tension.
Jun 02, 2015 | Sewing Machines
Bernina B550 QE upper tension
try adjusting the top tension one number or letter at a time till
the stitch look normal
if you have tried to adjust the top tension and no matter what
setting the top tension is on, it doesn't help, then the machine
needs to be serviced, to see if the machine needs any adjustment
or possibly that the tension dial needs to be replaced.
Dec 22, 2012 | Sewing Machines
Tension adjustments- bobbin metal or plastic-needle size- for sewing on jean cloth
Most machines can sew on jeans fabric, but you may need to go slowly or even hand-turn the needle when crossing thick seams to keep from bending or breaking your needle.
Bobbin: It won't matter if you use plastic or metal bobbins.
Needle: You should use a heavier needle - you can purchase 'jeans' needles, or use the heaviest sharp or universal needle you have.
Tension: For tension adjustment, you can follow the guidelines in your sewing machine manual but you'll also need to adjust the tension based on sewing on scraps of the fabric. If you are sewing light-weight denim, the settings are pretty much the default/normal settings. As you increase the weight/thickness of the fabric and seams to cross, you'll need to loosen your pressure foot tension. If you use decorative 'jeans' thread or topstitching thread, you'll need to loosen your needle tension.
*Always test on scrap fabric to make sure the stitches are forming properly. It is best to make small adjustments to your tension settings, then test, then adjust and test, until it is right. If you sew that weight of fabric often, make note of your tension settings inside your machine manual to save you some time the next time you sew.
I hope this helps.
Apr 01, 2011 | Brother XL-5130 Mechanical Sewing Machine
Sewing Machines Logo
174 people viewed this question
Top Baby Lock Sewing Machines Experts
Tally Girl
Tally Girl
Chris Wetmore
Jon Piercy
Are you a Baby Lock Sewing Machine Expert? Answer questions, earn points and help others
