Question about Compaq Presario 700 470024-192 Notebook
Fix black screen
Black screen fix...everything works except for lp screen....i can hook up to monitor and works that way...it has been dropped but it worked after that....a few weeks later it quit completely. i done the take battery and hold power? button down and it made it start working again except for screen......$^&%^*&& HELP ME PLEASE #@%^&&^%^&*
  • Compaq Master
  • 5,660 Answers
Computer got you stressed?....................Life getting you down?...
Feel like if one more tiny problem comes up, you're just going to end it all?
.........GET OVER IT!
"$^&%^*&& HELP ME PLEASE #@%^&&^%^&*"
Don't ever come to this website, and post that again
Help me please?..................Yes
Moving on................
An external monitor works
Good. This way you know the problem is either the Video Cable, or inside the Display Assembly.
Video Cable:
With the Compaq Presario C700 series of Notebook PC's, the Video Cable connects to the motherboard; in an area under the Keyboard, and Switch Cover.
(Above the F4 key)
It then leads under the left Hinge, and up into the Display Assembly.
From there a small cable branches off, and connects to one side of the Screen Inverter.
The main part of the Video Cable, goes on to connect to the back of the LCD screen.
Example of Video Cable,
http://www.amazon.com/G7000-Compaq-presario-Video-cable/dp/B005NEPKTE
The large connector on the Right side, connects to the back of the LCD screen.
The smaller connector shown at Bottom connects to the motherboard.
The small cable leading up to the Top/Left, connects to the screen Inverter.
http://www.ebay.com/itm/New-COMPAQ-Presario-CQ50-CQ60-HP-Pavilion-G50-G60-G70-LCD-INVERTER-486556-001-US-/281024427508?pt=LH_DefaultDomain_0&hash=item416e5c75f4
Just from repeated normal opening, and closing of the laptop; the Video Cable may become pinched, and pulled on. Sheath of Video Cable also hardens over time, and this also adds to the equation.
However, this laptop has been dropped. There's a real good chance of a problem with the Video Cable.
Pulling on it can lead to the connections coming loose.
Motherboard side, screen Inverter cable, and LCD screen side.
Procedure is to go through the various connections, and PHYSICALLY check them. Try to plug them in tighter.
Motherboard connection:
1) Remove ALL power. Remove the AC adapter (Charger), and Battery.
2) Disconnect the Keyboard, HOWEVER do not disconnect the Keyboard Cable from the motherboard.
Once Keyboard is removed from Palm Rest Cover, take the LCD screen side, and roll the Keyboard over.
Bottom side up, lay on Palm Rest Cover.
3) Now remove the Switch Cover.
The Switch Cover is the wide strip of plastic, above the Keyboard, and below the Display Assembly.
The Switch Cover is just that........a Cover.
No wires attached.
Physically check motherboard connection.
Reinstall power. Turn laptop on.
No change?
Remove ALL power again.
LCD screen side connection and screen Inverter connection:
4) The plastic frame in front of the LCD screen, is the Display Bezel.
Remove it.
Right behind the Display Bezel, and mounted on the bottom/middle of the Screen Frame; is the screen Inverter.
Just physically check the screen Inverter connection, but go on to the LCD screen side connection.
The LCD screen is an assembly of layers. These layers are held in the factory set position, by a metal Screen Frame.
Resembles a picture frame.
Attached on either side of the Screen Frame, are Brackets.
The brackets are attached to the Hinges, and the whole assembly is just referred to as a Hinge.
There are screws that hold the Hinge brackets to the Screen Frame. There are also screws that hold the Screen Frame together.
Be SURE as to which screws you remove. You do not want to remove the Screen Frame screws.
Remove the screw that hold the Hinges to the Screen Frame.
Tilt the Top of the LCD screen forward towards you, and physically check the LCD screen side connection; of the Video Cable.
Lay the LCD screen back, put a screw in on each side, to temporarily hold the LCD screen in place.
Reinstall all power. Turn the laptop on.
Still no joy?
Remove the Video Cable.
The Video Cable needs to have a continuity test performed, with a multimeter set to OHM's. (1K)
Every wire in the Video Cable is checked.
No reading on a wire indicates a stretched/broken wire.
An assistant should also be used, to gently wiggle the Video Cable while checking.
An intermittent reading on the multimeter indicates a stretched/broken wire.
Or take the Video Cable down to the nearest small computer repair shop, and have the resident tech check it for continuity.
Should only be a coupla' bucks.
The Video Cable MUST be ruled out, before going on........
5) Video Cable checks out OK, or a replacement is used; and still no display on laptop's internal monitor, the screen Inverter is next in the diagnosis.
To test a screen Inverter requires a sensitive multimeter. Read fairly expensive,
http://www.fonerbooks.com/test.htm
Due to this, the ease of accessing to replace, and the usually low cost; the screen Inverter is just replaced.
6) If the new replacement screen Inverter brings no joy, then the problem is the LCD screen.
HP Support > Compaq Presario C700 series of Notebook PC > Manuals > Service Manual,
http://h10025.www1.hp.com/ewfrf/wc/manualCategory?cc=us&dlc=en&lang=en&lc=en&product=3559331&
Scroll down, and click on -
HP G7000 Notebook PC and Compaq Presario C700 Notebook PC - Maintenance and Service Guide
At the top is the Adobe Reader page number box
Page 21 is the start of the Illustrated Parts Catalog.
The next page shows you an exploded drawing of the laptop.
Page 58 - Keyboard
Page 61 - Switch Cover
Page 63 - Display Assembly
http://armbrust.dyndns.org/tips/presario700/
http://www.youtube.com/watch?v=nALcYwgVCZk
The F700 HAS wires to the Switch Cover. The C700 does not.
Just posting to give you a hands on look, instead of just a Service Manual.
02:59 - Here you can see how I described LEAVING, the Keyboard Cable attached to the motherboard, and just rolling the Keyboard over onto the Palm Rest Cover.
In Spanish, but a 'Picture is worth a thousand words', they say,
http://www.youtube.com/watch?v=55Wcej_K3ag
Not the Presario C700, but shows in better detail on releasing the Lock Clips (Detents), at the Top of the Keyboard,
http://www.insidemylaptop.com/hp-2000-laptop-disassembly/
Specifically photos in Steps 9 through 11.
Regards,
joecoolvette
(You won't need an ESD wrist strap for this procedure. However if you have one, wear it by all means.
IF, you remove the Palm Rest Cover, then you better be wearing an ESD wrist strap; and have it's alligator clip attached to a good ground source )
Posted on Apr 06, 2013
SOURCE:
Screen replacement/screen is cracked
You can get a replacement screen from this WEV site.
LCD screens and Inverterswww.lcdparts.net
Jun 14, 2012 | Acer Aspire One PC Notebook
Laptop monitor blacks out but works fine with an external monitor
If your laptop appears to boot up and the hard disk LEDflashes, then the problem is probably a back light fault. This can be a faultyinverter or a faulty CCFL lamp. Please click on this link and follow myinstructions to identify the fault and possible fix :- http://www.fixya.com/support/r3598095-faulty_laptop_lcd_screen
Mar 12, 2012 | Dell Computers & Internet
1501 inspiron boots up, but screen is black
Try this, hook up your LP to a diftrent monitor, using the "Blue conextion cable", if you can see windows opening up, it's in you Hardware. If not then it might be in your software, try reformatting it, but use the reformat as as last resort only. Doing the reformat you will lose ALL data. If it opens and you see it on a dirrent monitor then it time to replace your LP monito.
Apr 17, 2011 | Dell InspironTM 1501 Notebook
My HP Compaq mini 110 has a half striped screen...Everything works except for the fact that the screen is half white and a little black...I had recently dropped my computer from a couple inches off the...
The screen polarization has gone bad. it is not worth the trouble. if it is laptop take it to a tchnician to be replaced. They are usually extremlely pricy and cost almost as much as replacing the laptop and will probably be an upgrade as well. if it is a laptop you can always use the external monitor port and use a different monitor.
Nov 03, 2010 | Computers & Internet
Dropped MSI Wind. Cannot see anything in display.
Depends on the total amount of damage caused when dropped.
Oct 20, 2009 | MSI U100-279US 9S7-N01152-279 N270 1.60GHz...
LCD Screen
Sounds like the new Samsung LCD screen is bad. The back-light on the Samsung LCD may be burned out. Check out this website; http://www.lcdsearch.com/
Mar 30, 2008 | Computers & Internet
Proview PRO576 error message "mode not supported" and will show nothing else
Okay, we got a fix by having another monitor hooked up to our computer and going in to display and changing the display settings to a lower setting. The screen resolution - turn it to lower - I guess somehow - the setting was too high for our monitor. Don't know how it changed itself though. Anyway, change it to a lower resolution then re-hook up your monitor and see if it works. The reslution can be pushed back up until you notice the problem again.
Mar 05, 2008 | Proview PRO576 15 in. Flat Panel LCD...
Hooking up ps3
Check system in TV Format Setup:
NTSC or PAL N
Dec 28, 2007 | Onkyo TX-SR803 Receiver
Help
If the monitor was dropped, most likely you damaged the internal components that provide the picture, whether LCD or CRT. Try connecting it to another computer. If this doesn't work, check the monitor's display settings or operating system display settings for contrast or brightness. NEVER open up the monitor, because there is a high voltage capacitor that stores voltage even when the monitor is off and could kill you if it discharges.
Jun 11, 2007 | Envision EN-7220 17" Flat Panel LCD...
Compaq Presario 700 470024-192 Notebook Logo
132 people viewed this question
Top Compaq Computers & Internet Experts
Thomas F. Schneider
Alun Cox
Are you a Compaq Computer and Internet Expert? Answer questions, earn points and help others
